This is an easy 20min build Knex Gun, with a lot of power and an easy locking method*. It is very compact but still packs a nasty amount of strength!...
Slot the firing rod into the barrel so the yellow piece on the end of the rod is on the opposite end to the black piece at the end of the barrel. Fix...
PLEASE HOLD THE GUN AS SHOWN OR YOU WILL GET HURT! This gun is small, but that has its drawbacks. Be careful when holding the gun, you don't hold it...
Take out the blue 'connector' mini piece on each end of the gun (not the doubles in the middle) and the gun will not bend. Thankyou for pointing this...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
