K'NEX Sebulba's Podracer
PlayK'NEX by
Introduction: K'NEX Sebulba's Podracer
In this Instructable I will show you how to make Sebulba's Podracer from the Star Wars universe! A podracer is a futuristic racing craft travelling at speeds of up to 1000 km/h (620 mph). Sebulba's racer is highly modified and features (illegal) weapons such as a flamethrower or a buzzsaw.
This model is about 50 cm long, 45 cm wide and 20 cm high. It comes with 2 Solar motors that turn around when sun/a bright lamp shines on one or 2 solar panels. The model took me about 2 weeks to build and 20 hours of video shooting and editing.
The steps are like this:
  1. Parts Needed
  2. Display Stand + Sebulba's Cockpit
  3. Building the Split-X Engines
  4. Wiring & Finishing up
Here you can see a video of the model, together with my Anakin's Podracer:
Step 1: Parts Needed
Buy K'NEX pieces at K'NEX User Group / K'NEX spares
  • 73x Black rod (16 mm)
  • 60x Silver rod (32 mm)
  • 16x White rod (32 mm)
  • 2x Orange rod (32 mm) Part of Solar Motor
  • 23x Blue rod (52 mm)
  • 12x Dark Blue rod (52 mm)
  • 15x Dark grey rod (86 mm)
  • 1x Flexi-rod Orange (86 mm)
  • 2x Green rod (128 mm)
  • 2x Purple rod (190 mm)
  • 1x Lila rod (190 mm)
  • 4x 8-way White connector
  • 15x 8-way Black connector
  • 8x 7-way Blue 3D connector
  • 9x 4-way Silver 3D connector
  • 9x 5-way Grey connector
  • 14x 4-way Black (Green) connector
  • 7x 3-way Dark Grey connector
  • 10x 2-way (V-shape) Grey connector
  • 2x 2-way (V-shape) Orange connector
  • 1x 2-way (long-shape) Brown connector
  • 112x 2-way (long-shape) Orange connector
  • 4x Clip with hole end dark gray (1-way connector)
  • 40x Black clip with rod end
  • 6x Silver clip with rod end
  • 8x Orange clip with rod end
  • 18x Clip with Ball end
  • 34x Clip with Socket end
  • 2x Clip blue
  • 5x Interlocking Clip Tan/bronze
  • 2x Hinge Black Half
  • 5x Clip with Splice end Orange
  • 2x K'NEXMAN Headtop Orange
  • 2x K'NEXMAN Headtop Translucent Red
  • 2x K'NEXMAN Mouthpiece Black
2x Tri panel small Silver
  • 2x Solar Motor Orange
  • 2x Solar Panel Black (1 is sufficient perhaps)
  • 2x Solar Connecting Cable
4x Gear small Dark Grey
  • 2x Hub/Pulley Small
  • 4x Hub Racing wheel (37 mm)
  • 2x Wheel Open Centre Black (25 mm)
1x A4 Size paper and a colour printer
Step 2: Display Stand + Sebulba's Cockpit
In this first building step, I will show how to make the display stand and the podracer driver seat/cockpit.
Like all models, I designed the display stand the last. But, in this model it's so crucial for the model's stability, that it's the first step in this instructable. Why is it so crucial? Well, podracers are basicly two jet engines with a little cart behind them (That's how I would describe it), so the engines are basicly hovering above nothing. Sebulba's impressive Split-X engines tend to fall over when they're put on the ground, so because of that we're starting with the display stand.
In the last step you will find the appropriate Print-file (pdf) that lets you print out the model's details. Let's continue!
Step 3: Building the Split-X Engines
Can we stand still for a moment and realize how cool Sebulba's Podracer sounds? I mean, it even has a mean sounding name: Dual Mammoth Split-X Engine. Here's a link to help your imagination:
Other than that: In this step I will show you how to make these mean engines. It starts off with the power connection that runs in between the two parts. After that you make the base for the split-x and attach them to the display stand. Add orange, black and white parts and you're done.
Because K'NEX offers a -very- limited amount of orange parts, I had to get creative. I tried a design with the Big Air Ball Machine tube-part, but the scale of the model went up more than I wanted. Then I knew it: The K'NEX Solar motors are orange too! I was lucky: My brother owned one too, so if you're reading this: I borrowed your Solar motor for a while! :D
That also meant I automatically implemented a rotating part into the model. I think it's absolutely great, even though it's not accurate to the original Podracer. In the original, no moving/rotating parts are seen. Still I think it's a great addition and as it's Solar: it will not cost you batteries!
In the last step I will show you how to install the cables and finish the model.
Step 4: Wiring & Finishing Up
In this last step you'll first attach the display information, after that you install the cables and the solar panels. To make the motors rotate, a pretty bright sun is needed. OR: alternatively you can use a halogen-lamp (I used my halogen-bureau lamp -> it gets hot) I'm not sure LED lamps will work, perhaps a LED spot light. Energy-saving light bulbs are unlikely to work.
Then you're model is finished! Don't forget to make those mean engine sounds :) Have fun!
May the force be with you,
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    These are incredible! After watching the video i thought you cheated and just made a set because of the discription plate... But you did not and here is another incredible star wars custom creation! nice work i look forward to more!
    Haha, I'll take that as a compliment ;)
    No, I design the description plates myself with nothing more than good 'ole
    - MS Word
    - MS Paint
    - Snipping tool
    No photoshop, nothing. Same applies for my video's. I just use Windows Live Movie Maker, believe it or not :)
    More coming, but first a rather unusual K'NEX build that no-one has tried before. It's a co-op with my brother and can be seen here: https://knexflux.net/p2295
    Nice! I found your Anakin podracer the other day, today I came across your Sebula podracer, your AT-AT, the Millennium Falcon.. wow, just Wow!
    How Sebulba's pod turned out, I like better, personally.
    Haha, thanks :) More goodness upcoming! Star Destroyer, AT-ST, A-wing, Y-wing and a DS-BM (you may figure out what that means)
    Thanks, glad you like it!
