K'NEX Star Wars TIE-Fighter
2,493
35
72
Posted in PlayKnex
Introduction: K'NEX Star Wars TIE-Fighter
About: Hello! I am mechatronics graduate and have always had a passion for making things. This started at an early age with LEGO and K'NEX. I think it's great to create. From useful stuff to art or toy. The ibles...
"Can you fly a TIE Fighter?"
- "I can fly anything."
Finn and Poe Dameron
And once you build this TIE for your own, you can learn how to fly one too! In this instructable we will show you how we designed and made this K'NEX TIE Fighter from the Star Wars movies. It reassembles the First Order TIE-figher more than the original TIE, since the colour of the wings is different.
GWorks started with the wing design, but asked Linkin_J_Knex for help with the cockpit in one of the comments under an ible. He then made a clever way to create a spherical shape, in the right scale to the wings, with 4-way connectors and ball joints. Therefore, this collaboration was formed. We are both Star Wars fans and both K'NEX builders on Instructables and like this spaceship a lot.
The actual model was built and photographed by GWorks, and is about 30 cm (1 foot) high. It is completely symmetrical, and therefore Step 3: The Wings has to be executed twice, apart from assembling. The model features laser cannons, dual engines and the possibility to display it on a stand, while showing information about the TIE. The Steps in this instructable are accordingly:
  1. Parts Needed
  2. The Cockpit | Made by Linkin_J_Knex
  3. The Wings & Assembly
  4. The Display Stand
Each step has an appropriate Finn quote to keep the theming right ;)
Step 1: Parts Needed
" ...You need pieces"
"I need pieces, yes"
Poe Dameron and Finn, deciding who's going to build the TIE...
You will need the following to make the TIE figher
Knex pieces: Buy at K'NEX User Group / K'NEX sparesK'NEX spares
Rods:
  • 124x Black rod (16 mm)
  • 34x Silver rod (32 mm)
  • 9x Black rod (32 mm, for aestethic purposes)
  • 2x Flexible purple rod (32 mm, for aestethic purposes)
  • 1x Blue rod (52 mm)
Connectors:
  • 7x 8-way black connector
  • 2x 7-way blue 3D connector
  • 2x 4-way silver 3D connector
  • 32x 5-way grey connector
  • 3x 5-way dark grey connector (for aestethic purposes)
  • 13x 4-way Black connector (otherwise, the model will become green-ish)
  • 12x 3-way dark grey connector
  • 11x 2-way (V-shape) grey connector
  • 63x 2-way (long-shape) brown connector
Clips/Other:
  • 1x Blue spacer (½ width)
  • 53x Black clip with rod end
  • 36x Clip with Ball end
  • 16x Hinge part Black
  • 4x Clip with Socket end
  • 1x Clip blue
  • 2x Interlocking clip Tan/brown
  • 2x Ball and socket Large
  • 2x Stub axle Grey
  • 2x Headtop Translucent red
Panels:
  • 10x Tri panel mini silver
  • 2x Tri panel small silver
  • 2x Square panel small silver
Wheels:
  • 1x Wheel 25 mm Open centre black
Other:
  • 1x A4 Size paper and a colour printer
Step 2: The Cockpit | by Linkin_J_Knex |
"Han Solo, the smuggler?"
- "No! The K'NEX builder!"
Finn and Rey, discussing what Han Solo's role actually was...
In this step you will start your TIE-Fighter, by making the cockpit. First you start by making an internal connection for between the wings. Then you attach the cannons, the front part, and the spherical 4-way connectors. Later you add additional connectors and the back end to make the sphere complete. Then you add the thrusters and lastly you finish with closing up the bottom (but so that it can still be displayed)
Linkin_J_Knex designed the base of the Cockpit, GWorks altered it and built it for the final model.
Step 3: Wings and Adding Them
"We'll figure out how to build it. We'll use the Force"
- "That's not how this instructable works!"
Finn and Han Solo [irritated]
Because you still have to put it together self, and even make the wing TWO TIMES, because they are identical. You start by making the middle using a rather special piece that GWorks bought on KnexUserGroup, then you add the rest of the wing, the typical 6-arm shape of the wing connections and the dark edges.
Once you made two of these, you can add them to the already built cockpit.
Step 4: Display Stand
"I've already fixed it."
- "Well can you un-fix it?"
Rey and Finn, discussing whether to mount the TIE fighter on the display stand, or to play with it.
In this last step, you will build the display stand. The model is sturdy enough to stand on it's own, and to fly around with, but you can also choose to put it on the stand, to show it off to all your friends and family. Make sure you print out the .pdf file that is attached at the end of this step, cut it out, and attach it to the stand.
Happy building!
May the Force be with you!
Linkin_J_Knex & GWorks
2 People Made This Project!
  • Spotless Contest
    Spotless Contest
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
72 Comments
It's complicated, I give you that. I hope the instructions are clear enough if you'd like to build it. If you ever have problems or doubts, write me and I'll see how I can help you.
And nope, it's not a set. I designed it together with Linkin_J_Knex. He did the cockpit and I did the wings. Later I put them together and made the instructions.
Then why it has a plate that deceibes it? Is that personalized
I took that idea from LEGO UCS sets (Ultimate Collector Series). It looks pretty official, but no, I made it. Here you can see how I do it: https://knexflux.net/p639
In earlier versions I would give hints that it was made by me. (Manufacturer: GWorks Engine Corporation or something similar) Nowadays I leave that, for more professional looks :) And thus so comes the confusion, haha.
All of the pieces on the K'NEX website is only in inches, not mm. What do I do?
I guess convert the lenghts. But since I'd like to give a useful answer:
- 16 mm Black rods are the same as Green rods and are three quarters of an inch
- 32 mm Silver/Black rods are the same as White rods; one and five sixteenth of an inch
- 52 mm Blue rods are two one quarter of an inch
- Use Metric...
- 86 mm Dark grey rods are Yellow rods; they are three seven sixteenth of an inch
- This is getting more ridicoulous
- 128 mm Green or Red or Tan rods are five one eight of an inch
- 190 mm Grey or Black rigid rods are seven and one quarter of an inch long.
Or, you could have checked KnexUserGroup, which lists both dimensions.
Man, I really hate "Standard" measurements.
Yes, I did check KnexUserGroup, but many of them are not on sale. The other website is currently ongoing maintenence.
The KnexSpares website should be back online again :)
No,KnexUserGroup don't have a very good 'sale' stock. Also the Bulk-buys I don't consider very good.
On the other hand, KnexSpares' bulk buys are more interesting
Why can't K'Nex sell it in their own website, this shouldn't be that hard!!!
I don't know why K'NEX doesn't produce metallic coloured pieces anymore. I think it's a shame.
Well, unfortunately, it's hard to buy individual pieces. If you don't have some (metallic) K'NEX already, building my models is pretty hard.
I don't know what standard is, I use metric, like I think 85% of the world's population. The Imperial system doesn't make sense to me.
Yes, I agree with using metric. Standard measurement is what America uses. I live in America, so everything on the website is in Standard Measurment.
I also don't want to use the green ones because a green Tie Fighter wouldn't make sense.
All of your knex starwars models look really close to the real thing. Most people wouldn't have all the colors to make this model, but still is awesome.
This shows when I go to your profile, but no where else. It was great fun making the cockpit :) and amazing ible as usual! Im stunned :D
Hmm, it isn't showing under my favourites either
I'll check the settings in the edit section.
I'll probably also change the collaboration -> solely build, but I want to change it back once I know what is the problem
Bet you're jealous, I found some PURE BLACK white sized rods and yellow sized rods (insert cool face emoji here) xD I know how in love you are with your black/dark pieces xD
They are in the heads of K'NEXMEN :P So I have a few of those black rods. But yellow-sized too? I didn't know about that. Or are they dark grey with dots?
Apparantly, there are also shiny-gold yellow/white-sized rods :P Ooooh
(well, the white ones are again in Knexman heads... the 86mm (I just checked) I don't know.
