3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
KNEX WIND MILL.......
This is a very simple knex windmill and can be yoused to make electricity but I didn't hook it up to a motor or anything......yet
Target climate:
outside on flat serfice with winds at least 10mph...but do not go over 50mph....I did that and it got blown away....plzz no harsh comments...i was only 11 yrs old wen i made this (;
I am not responsible for any injury's or misunderstandings for this knex model
(the pictures are sucky because i had a cheep web cam)
Step 1Get the knex parts
get the knex parts
you will need 1-2 sheets of paper depending on the size and some tape
look at the picture for the knex peaces
if you have trroble seeing the picture(s) then please let me know
27 comments
Jan 6, 2011. 9:39 PMzezoo22 says:
Design and beautiful
Thank you for this design
Jul 7, 2010. 5:41 PMrapidprototyping says:
good job making the rotors
Jul 7, 2010. 5:31 PMrapidprototyping says:
gear belts are the most effecient method of getting from the turbine to the generator. an old electric typewritter had gearbelt drives and 110 volve mini motors not sure if there induction motors or the kind that can serve as generator when turned. magnetic motors are they called? anyway we used these on several prototype centrifuges so they work great on samall projects may be smaller motors on r c controled cars or some thing. erector sets had those pully wheels and a ruberband this things prototype it's about the ideas it generates isn't it. it's generating right now ideas!!!
Jun 5, 2010. 2:24 AMmoishyb says:
I can't see the 'blue connector to rod' piece.
Jan 24, 2010. 2:26 PMmholler says:
Motor PLEASE?
Jan 26, 2010. 9:44 AMKnexpertevan says:
to add a generator all you need is a small DC motor from a toy or something. hook it up however (that part is easy) then if you spin it, it acts as a generator and produces a small amount of electricity.
Mar 13, 2010. 3:53 PMthe inventor says:
i used this technique with a wind turbine of my own, however the outcome was a puny 0.3v with strong wind. but its a start.
Jan 24, 2010. 2:25 PMmholler says:
I really appreciated this design. However, I need to know how to add a motor. Please provide me with instructions at holler141415@netzero.net.
Thanks!
Dec 6, 2009. 6:27 AMbaconman says:
the pics are kinda messed up its hard to see the k-nex
Feb 4, 2009. 4:33 PMteeitei says:
i also need to know the proper materials as i also cant get it properly
Jan 18, 2009. 7:11 PMtoddstivers says:
this is great can you put a motor on it
Dec 17, 2008. 8:10 AMknektek says:
i made another one but handle-powerd with corks.
Nov 17, 2008. 9:54 AMoh_my_my05 says:
cud u plsss tel me abt d parts in dis pic....as i cant get t properly...its Urgent!!!
Apr 5, 2008. 2:34 PMKiteman says:
How do you plan to connect it to a generator?
Check your spelling, there are some bad mistakes in there - yoused should be used, for instance.
Apr 5, 2008. 9:12 PMxtank5 says:
I would attach a motor/generator by using a K'nex motor and K'nex gears. Or I would use the white 8-way connector and green connector pegs to make my own gears. Then if I didn't have a K'nex motor I would use epoxy or super-glue to attach a motor of my own to one of the white "gears". Another method is to attach the motor directly to the shaft. You could do this by using epoxy to attach it to one end. Or if you are so compelled, you could drill a hole in the end of the K'nex shaft and super-glue the motor shaft into the hole. Voila!! You would then have a generating station made of children's toys and various electronic equipment. Of course somebody would have to figure out all of the circuitry that comes after the generator in order to make it charge batteries or run laptops, for example.
Nov 12, 2008. 3:23 PMhunk586 says:
i have a knex moter but how do i put it on and how will it make electricity??? cause wont the knex moter just make it go so plz tel how
Nov 12, 2008. 2:42 PMhunk586 says:
can u show me how to put in a moter i built 1 different than yours after i put a moter in it ill put it on youtube so u can see it
Aug 5, 2008. 4:08 PMturtleshane says:
ok i want to make this thing produce power... how do i do this.... how does a wind mill make power basicly.
Sep 6, 2008. 4:53 AMwally33 says:
hook up a geared dc motor so that one turn of the windmill equals a high amount of the motor shaft this will give you electricity through the motors terminals. I tested this by putting a motor in a vice and putting the shaft in the chuck of a drill. spin it up and sure enough you should get power. its just a matter of getting the right gear ratios and torque
Sep 6, 2008. 7:04 AMturtleshane says:
thanx
Aug 9, 2008. 12:10 PMMetallurgy says:
I tried to make one..didn't turn out so well..I tried to make a tide turbine..same princible as a windmill, but it faces one direction and the "wings" are more in length that widith. -_ -_ -_ -_ -_ -_ -_ -_ sorta like that..pleh, hard to show with text.
May 13, 2008. 5:33 PMFenris The bbw says:
I'd like to see this in action. Pretty sweet.
Apr 16, 2008. 3:05 PMpls says:
thats a great idea
Apr 6, 2008. 6:47 AMarrow shot says:
its cool, but its use for energy is low. id use it to power, mm...maybe a knex contraction that i dont feel like using batteries for.
THIS is what i think you need
Apr 6, 2008. 7:06 AMxZCodmaNZx says:
LOL
Apr 5, 2008. 4:53 PMGorillazMiko says:
I would like some pictures, but it's a nice idea.
Apr 5, 2008. 2:16 PMPbyrd says:
Put the motor on because it is cool now but it would be way cooler when it generates electricity. I voting on it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:meming
i like lots of stuf so......
