KNEX Crossbow
2,341
Published
Introduction: KNEX Crossbow
About: I just like technology!
this is my design of a K'NEX crossbow.
It is simple and works well.
he shoots through 1 sheet of paper (slightly out how many rubber bands you use, 1 is very hard but the rubber band refurbished fast) You can use all types of rubber bands.
Step 1: The Middle
Step 2: The Firing Trigger
Step 3: The Handle
Step 4: Aiming
Step 5: The Nose
Step 6: The Bullits
Step 7: Firing!
here are the pictures to fire.
Step 8: The Final Step
you can make improvements if you like.
  • Planter Challenge
    Planter Challenge
  • Oil Contest
    Oil Contest
  • Pets Challenge
    Pets Challenge
17 Comments
It's okay, but could definitely use some work. the rubber bands wear out too fast, and it's not really powerful.
please send pictures if you made one I like pictures... XD
try making the triger a little better is hard to use.
you should put a stand to hold it if your in the ground.
i dont have a giant red peice or gray peice  what should i do?
 you could use 2 yellow pieces
i don't understand wat's new?
if u do it my way u pull the rubber band back behind step 4, stick the ammo in-between the two circle like conectors and let go of the ruber band and it goes flying. it is so cool i like do it with the longer ammo better though.
step five needs another photo i built it but took it apart cause i can't finish
ill make it and give you angles if you want.
pls do that if you want thnx
thats wicked easy too make! step 5 is so simple!
Try taking a photo from the side, I cant see a thing!
