Introduction: K'Nex Automatic Pokemon Training Machine
Step 1: Part List
This is a list of... parts used in the machine.
Step 2: The Containment
1-Make
2-Make
3-Combine (left part is step 2)
Step 3: The Axel
1-Make
2-Make
3-Make
4-Combine 2 and 3
5-combine 1 and 4
6-Add what you just made to the Containment.
Step 4: Other Stuff
1-Make
2-Attach to main body
3-see those empty spaces?
4-add blue rods there
5-make
6-twist so it looks like that
7-attach right under the hinge
8-Make
9-attach
10-connect with a blue rod
11-make
12-connect to the hinge and thru the snowflake
Step 5: How to Use
1-what you should have now
2-put your DS/DSi under it
3-Line it up with the up button
4-With DS/DSi under it
5-remove the yellow rod there for easy access to the switch
OK..HOW TO USE!
1-place the Pokemon you want to train in the daycare
2-go to a place in cycling road where you cant move down.(path blocked by bridge, biker, etc.)
3-turn motor on
4-get on with your life
LOL JK if u play pokemon u have no life
5-come back and you will have an uber-leveled Pokemon!
Step 6: Troubleshooting
1-it does not press the button hard enough!-fix-put a hardcover book on top of the machine
2-the axel wont move!-make sure you built it right, and if you did, replace the batteries
Step 7: You're Done!
You're done! Again, much credit goes to I_am_Canadian.
