K'Nex Breastplate/chestsheild
Introduction: K'Nex Breastplate/chestsheild
This is a knex breastplate/chestshield. Its very strong I tested it with my knex gun that had 6 rubberbands on it .You can make it bigger if you want. This is also my first Instructable but say what you want about it.
Step 1: The Shield
make this,simple right
pic 1: what you make
pic 2: a closer view
Step 2: Top Strap
now your making one of the straps
pic 1: make these
pic 2: make this to(there's 23 hinge things you can take some away or add more if you want)
pic 3: connect on top like this
pic 4:connect on top on other side like this
Step 3: Bottom Strap
now your making the second strap
pic 1: make
pic 2: attach like this on each side
Step 4: How to Put On
heres how to put it on
pic 1: unatach somewhere on the top strap put around neck and connect again
pic 2: unatach on one side of bottom strap put around back and connect again
Step 5: Done
now your done!!!!! any mods or suggestions welcome and if you need any help just comment.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    nice.you have no peices to build a good gun with!
    Then your gun must really not be that strong....
    I think this is good, but has some weakness, one of which is obvious - it is only connected to the outer frame by the corners, the rest is just hanging. May i suggest using an outer frame of white rod; yellow connector; white rod; yellow connector etc, then connect the yellow connectors to the whites in the plate with green rods? Also, a chain isn't ver comfortable to hold it up. Maybe use elastic, string or horizontal rods going over your shoulders? Besides these, it is very good, 5 stars
    White rod, yellow connector is not possible with the white connectors in is configuration, you have to replace the green rods in the corners with white ones and then make the edge with yellow connectors.
    i might try that and see if it works better thanks
    ...eh....you should use knex plates form those old sets, now those are good. this wont defend against my sword though. muahaha, im coming for you
