K'Nex Differencial (Version 1)
4,534
10
23
Published
Introduction: K'Nex Differencial (Version 1)
Car differencial built from k'nex for k'nex vehicle by Forsterimages. Here is what your finnished diff. will look like. Also see version two.
Step 1: Parts Required
Here is a list of the parts you will need:
4 white connecters,
2 brown cog wheels,
2 grey cog wheels,
2 orange connecters,
4 navy rods,
2 yellow rods,
4 silver spacers,
8 blue spacers,
8 black connecters,
2 yellow cog wheels,
some blue tack.
Step 2: Step One
Take one of the white connecters and attach to black connecters opposite each other. Do this for times.
Step 3: Step Two
Take two of the pieces you made in the last step and connect them together using two navy rods. Make two of these.
Step 4: Step Three
Attach one grey cog wheel to the end of a yelloew rod and the slide two blue spacers onto the rod. Do this twice.
Step 5: Step Four
Attach two grey cog wheels to the end of a navy rod. Then place a blue spacer on each end of the rod. Place some blue tack around the end of the rod.
Step 6: Step Five
Now place a red connecter on each end of the part you made in the last step.
Step 7: Step Six
Take the parts you made in steps four and five and join them together as shown making sure to place a grey spacer o the ends of the navy rods. Do this twice.
Step 8: Step Seven
Now take the parts you made in steps five and six and join them together as shown.
Step 9: Step Eight
Take the other part you made in step six and attach it to the other side like in the last step.
Step 10: Step Nine
Now place on yellow cog wheel on either end and your done. Now you can attach two wheels. By (c)Forsterimages.
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Slow Cooker Challenge
23 Comments
Yeah I read the instructions. Proof of Concept
If you read the instructions, explain why the one you made looks nothing like the images in the instructable??! You're also the first person whose had any problems with it!!?
Listen dude, ARE YOU BLIND OR IS IT ME?!?!?!?!?!?!?!? That does look like yer differential, it has an axle shaft, drive shaft, gears, and a housin. WHAT MORE DO YOU WANT???!!???
IT'S YOU!!!!!!!!!! What are you doing with that grey rod???!! And that brown cog is NOT supposed to be locked!! I'm sorry but if you're a Yank this is nothing short of typical!!!
OK first off, im not a yank and yer dumbern a box of rocks
Proof of Concept
how many times do i have to say it? morn 3 million times? PROOF OF CONCEPT
First you built it wrong.
second stop yelling at people because you made it wrong and its your fault.
its pretty simple what hes done with it....its the same basic concept but hes got it locked with a wider axle..
hes done it right its just half of yours
And it took me 10 to 15 min to build. I built a proof of concept in 5 min.
I hate to say this but i built it and it went in circles
Don't tell me you've never heard of a differential?!!
Yes. It holds the navy rod that it's attached to in place.
It would be good to see this with an input shaft. Are the black cogs on the blue shaft locked on it or "free-wheeling"? L
It wouldn't make sense for it to be locked since that will lock the entire mechanism. One way to put an input on the system is to put gears around the entire differential and rotate the entire mechanism (the cage) around the wheel's axis.
Wikipedia says it better (w/ diagrams): http://en.wikipedia.org/wiki/Differential_(mechanical_device)
No it wouldn't make sense for them to be locked, but that's the way they look in 4,5,7,8 & 9. The main picture now shows them as brown with spacers. L
Yes they're brown and are not locked. Please say if there's anything else you don't undestand and i'll try and make the instructions more clear.
I get it now, it's just in some of the steps they're dark grey e.g. step 4. L
