Step 8Finish gluing the kaliedocycle.
Apply glue to both of the small "Glue Me" flaps at one end. Turn the ends around, and carefully slide both tabs into the slit at the other end, closing the ring.
Gently hold the kaliedocycle together: this is a critical stage! Over the next several minutes, slowly flex this last joint in and out, little by little. As you do this, make sure that you also hold the ring together.
After about 5 minutes, the glue will be sufficiently dried. Set down the kaliedocycle and let it dry for at least 1 hour.
Add Comment
