Kamosage Knot
2,260
10
4
Posted in CraftFiber-arts
Introduction: Kamosage Knot
A Kamosage Knot is a basic knot used in Shibori. There are many different kinds of knots and techniques but this is a common one.
(this first image is not mine, found on flickr, all credit goes to Susan Barrett Price. The rest of the images are mine though!)
Step 1: Materials
You will need:
Scissors
Fabric, you can use any amount you want, the more you use the more knotting you will have to do. Also you should have natural light fabrics, 100% cotton is best, and wash it before you dye.
Thread: Strong thread, quilting strength works well, or you can use dental floss.
Step 2: Grip Your Fabric
bunch a little bit of your fabric, into a little mountain.
you can make bundles in any pattern that you want and in any size that you want. It will effect the look after you dye.
Step 3: Grip the Thread
Leave a little bit of a tail and hold it against your bundle.
Grip the rest of the thread tightly in your other hand, use three fingers but keep the pointer and thumb free.
Step 4: Wrap Around Thumb
wrap the thread around the outside of your thumb while holding the thread taught from your three fingers.
Step 5: Loop Around Middle Finger
Loop the thread from your thumb around the outside of your pointer finger.
using the end of the thread held against your fabric you make a triangle, keep the tension tight.
Step 6: Place Fabric
slip the fabric bundle into the middle of the triangle you made
hold onto the tail and keep the thread tight, the tension is important.
Step 7: Pull the Knot
free your pointer and thumb but continue to hold the thread in your three fingers.
while holding onto the bundle and the tail pull the thread and make the knot tight. repeat the steps to double up the knot, this will secure the knot.
if you can't pull it tight enough with just your fingers, wrap the thread around a pencil or something similar and pull tight.
It needs to be tight so that dye can't seep through and that is how the patterning is created.
Step 8: Cut the Binding Thread
cut the long thread to leave a little tail, now you should have two tails from the knot
You can then tie the tails together to keep the kamosage knot tight.
Repeat for as many knots as you want or your pattern requires.
And that's it!
Step 9: Finished Product!
My dye was a little weak and my fabric was more resistant to dye but this is the look that you get using just Kamosage knots!
Little sand dollars! with the right planning you can easily have a very cool designed fabric.
I also need to add that this also works with the bleaching of dark fabrics so if that's what you want to do you can still use the Kamosage knot
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    4 Comments
    A photo of the finished effect of dying with this knot would be nice. The photos of the steps of tying it are really good. Thanks for sharing.
    you're absolutely right! I should have an update with a dyed product up very soon, thank you!
    I use it for shibori dyeing of fabrics.
