Step 7Sew top and bottom to sides
Look at each of the photos below very closely and you will see the progression of steps. Upi will pivot and then continue your seam, and you can see how you will make a turn and your stitching lines will be perpendicular to each other.
Continue this pattern until you have sewn the top to the sides.
You will repeat this same series of steps with the bottom mosaic as well. The only difference is that you will leave a 6" opening along the bottom so that you can stuff the sculpture. In the end you will stitch this opening closed by hand.
Add Comment
