3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Keep Your Mower Blade Sharp
Soon it will be time to mow the lawn regularly. A sharp blade on your rotary mower works so much better than a dull and nicked blade. This blade is freshly sharpened. The light/shadow contrast near the end of the blade gives the best view of the new edge in this photo.
Step 1My tool of choice
My tool of choice
I get a lot of use from my radial arm saw, including using it as a grinder to sharpen my mower blade.
18 comments
Feb 6, 2011. 12:50 PMfridgewrestler says:
Why go through the trouble? A file is faster (considering setup) and does a better job putting an edge on the blade.
Nov 28, 2010. 11:52 AMbaldigowski says:
That toll is called a 5 in 1 tool. It is used mostly by painters. The half-round cutout is for scraping/cleaning off the wet paint from a paint roller so you can reuse them. The point is used for glazing windows . The rest is self explanatory. Here in the US a good one is made by HYDE tools.
May 26, 2010. 8:42 AMflamesami says:
what is that thing that you are using to clean the blade? It looko ... interersting :-)...and very useful!
May 27, 2010. 12:33 PMflamesami says:
I'm English, but I live in Portugal, so no Lowes, Home Despot or big chains... instead we have small shops nationwide called "drogarias" where you can buy tools, nails and stuff if it can't be found in one place, there's the shop round the corner that might have it...waaay better than chain-stores, better service too they actually try to help, unlike the guy in the chain store who's just trying to sell stuff...forgive me for ranting.. :-)
Apr 28, 2009. 9:34 PMbilldan says:
Thanks for the tip. I have never seen a jig for a lawnmower blade and always used an angle grinder and this is a great way to get more use out of the saw.
Apr 29, 2009. 9:43 AMbilldan says:
I also have a power miter and it is great since it is very portable but it is only capable of cutting angles and is limited to narrow lumber as it was designed. The radial arm saw is much more versatile in that it can cut angles in 24" width stock and I have ripped 4X8 sheets of 3/4" plywood. I really like the radial arm saw for cutting the dado and the rabbit for cabinet construction. The table saw is not as fast when cutting a dado or a rabbit and you cannot see the results until your finished and turn over you material. If the blade is out of adjustment or dull and chipping the material it is not noticeable until your finished, so using a test piece is advisable. The radial arm saw has historically intimidated potential users with its open blade design. I will attest to the fact that a table saw is the most dangerous wood cutting machine in the shop and requires extreme attention to safety from the blade and the force of a kickback, which is capable of punching a 2x4 through a chain link fence after flying 10' past your hip. "WARNING" do not stand directly behind your material while pushing it through the table saw blade. I have seen kickbacks that almost killed the user. The radial arm saw has no hidden agenda. I have seen very good radial arms for sale as low as $25 for a barely used Powercraft 10" with a new blade. I bought that one and, many are available for $150. You can buy a new Craftsman for about $400 if you want it in the box ready for assembly.
Feb 21, 2009. 5:47 PMrimar2000 says:
I think that to sharp the mower blade is a very easy task, I do it "in situ" (without removing it) with the hand grinder. I stop the blade with a foot, that is sufficient.
Apr 14, 2009. 8:08 PMpfred2 says:
I use an angle grinder myself sometimes but I take the blades off my tractor. The angled part of the blade is on the top of the blade. Be a bit tough for me to get a grinder up there. Then sometimes I finish the blades up on a belt sander too.
Jan 11, 2010. 6:12 PMRainh2o says:
I have dealt with lawn mower engines on the side now for 15+ years and have NEVER seen one start "accidentally".  Not sure if they even could due to 1) you would have  to spin them up fast enough to generate a spark with the magneto and 2) build compression on a compression stroke.
If you pull the plug wire you will NEVER get one started anyhow so pulling the plug is redundant waste of time.
This is IF one would ever start by just twisting the blade by hand.  Think about how fast the flywheel spins when you pull the start cord.  Unless your underneath pulling on the blade like an old airplane I say it would never start.
Feb 22, 2009. 2:32 PMrimar2000 says:
My mower is electric, Phil, I take the necessary precautions. The grinder is 11000 RPM or so. I need all my fingers and toes for now. ;)
Feb 21, 2009. 1:39 PMthematthatter says:
step 7 doesnt sound too safe how do you stop the blade, with your hand?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
