Remove these ads by
Signing UpStep 1: Gather Materials
- 2 9v Batteries
- 1 9V snap connecter
- 1 12VDC Brushless Fan
- 2 220 ohms risitors
- Screw Driver Phillips head
- 8 Screws (23.73mm)L (2.71mm)W
- 8 nuts (6.24mm)
- 5 foot of 22 gage wire (60 inches)
- Paralax LM34 Temperature Sensor
- Paralax bread Board with minicontroller
- Paralax Basic Stamp program installed on computer
- Wielding Helment
- An Analog to digital transfer
- Power Drill
- 3/32 Drill bit
- 1 self leading wood drill bit 2â = 54mm
- Velcro
- Solder gun
- Solder wire
- 1 Roll of electrical tape
- Parallax Analog to Digital converter
Visit Our Store »
Go Pro Today »
I might use pic 5 as the opening pic tho. It has better contrast. I opened this -ible without a clue from pic or title what it was about.
Add a little 12 volt led lighting, and you're now a cyber-welding chainsaw wielder!
I applaud your efforts.
Not sure what they're teaching you there in Saint Charles Parish public schools, but soldering and safety don't seem to be high on the list ;-(
On the other hand, it LOOKS great!
Looks like that's a computer/electronics class, correct? Parallax is a useful tool, but unless using it is part of the assignment, consider using a slightly more dedicated set of circuits. maybe something like this(http://www.zen22142.zen.co.uk/ronj/ts.html)?
Now for anyone wanting to do this for WELDING... the simple answer is DO NOT DO IT.
Not only do we have the fume issues, but the spinning fan just made a massive opening in your helmet to let the UV radiation in. Even if it DOESN'T screw up your eyes... you're gonna have a nice circular spot of welders-sunburn on your chin.
And don't even get me started about the dangers of fans that close to our manly beards(well for some of us anyway)!
Finally, there's the issue of random loose wiring and EXPOSED CIRCUIT BOARDS to deal with.
I've been welding for years i could see me welding galvanized tread plate with this fan on NOT ! actually i founfd the best way to stay cool is a wet welding bandana lol
This would be an awesome fan for a costume though i've got a wizards costume i swelter in passing out candy this would be great might try it on that !
(And can you please turn that introduction image around on your PC, then re-upload it?)
I think I know what you were getting at here Kiteman, it seems the fan is pulling air from your working area and blowing it onto the users face, which would be directing all of those harmful gases from the torch and heating metal directly into your lungs -_- I would definitely turn the fan around so it would pull air from behind the wearer's head and out the front, keeping air moving at all times
or better yet, install it how it is, spacing it from the front of the mask inwards half an inch, don't cut a hole.. instead make some ducting so that it pulls air along the inside of the helmet, from behind the head.
One last thing that everybody should know, a temperature sensor is way over doing it, it would be annoying kicking on and off, and it's expensive. Just stick a 9 Volt battery and a switch in there.
By the way it is a great Idea, those helmets do get hot, I just think there are some safety issues that need to be fixed.
