Keeping Ants (and Lice) Out of Your Tree
Published
Introduction: Keeping Ants (and Lice) Out of Your Tree
I have a cherry tree that has a lot of lice every year. I don't like using chemicals to get rid of them, so I've been trying different methods. Last year I frequently sprayed the whole tree (it's a small one) with water to flush out the lice, but they kept on coming. Then I found out that ants are actually partly responsible for the lice, because they farm them. The lice produce a sweet liquid that the ants like, in return for that the ants protect the lice and carry them around. So I figured that if I can get rid of the ants I should also get rid of the lice (at leats partly).
This is a very short and simple instructable which would take less than 5 minutes to finish.
Step 1: The One and Only Step
I read somewhere that ants really dislike chalk, so I took one of my daughters chalk crayons and smeared it on the bottom part of the tree and the pole supporting it. I watched a little bit and noticed that not a single ant crossed the chalk, they all immediately turned around. Make sure you don't leave any unchalked traces, because they will find them. The only downside is that this has to be regularly maintained (put some new chalk).
This method could also be used to keep ants away from other places where they are unwanted.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    3 Comments
    great and environmental friendly solution! Another one is to use doubled-faced adhesive tape around the tree and the pole. It will not be washed off easiely during rain and ants can not cross it.
    Hi, I actually thought about using adhesive tape. In that case I would have used single-sided tape wrapped around the tree with the sticky side out. As I couldn't find any tape with a strong adhesive and didn't feel like going to the shop, I chose for the chalk :) I will see how often I have to refresh the chalk (which is only a minute of work and it doesn't rain here very often). If I have to refresh it too often I'll give a shot at the tape.
