Kegerator: GE WMR04GAVBB 4.5 cu. ft. compact fridge
 by Tauby
Step 6: Remove inner door panel
Break out the big guns!  I needed a reciprocating saw to get the panel off.  It had been glued on at the factory.  There are NO screws holding the panel on.  I had no consistant method of taking the panel off.  I just started cutting around the edges pulling little pieces off at a time.  Careful here.  The plastic is sharp and it may tear the weather strip around the door and/or cut you.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
