loading
loading
Picture of Keith Haring Paper Chain
Walking between the Instructables office and TechShop, I often pass by a huge Keith Haring sculpture on Howard and 3rd (see image above by Franco Folini on Flickr).  Clearly, this sculpture has seeped into my subconscious and is manifesting itself in my newest laser cut creation: the Ketih Haring paper doll chain.
Step 1: Get Images
Picture of Get Images
Art Print Online, art print for sale, art prints for sale-28012005136091390.jpg
A quick google image search brings up hundreds of Keith Haring's drawings and paintings.  I picked a few that I thought would be easy to process for the laser cutter.
Step 2: Photoshop: Isolate Figures
Picture of Photoshop: Isolate Figures
Use the magic wand tool to select the background of each image and delete it.  Use the eraser tool to delete any remaining unwanted lines.
Step 3: Photoshop: Merge and Generate Mask
Picture of Photoshop: Merge and Generate Mask
Merge all the figures onto the same layer.  Go to Image>>Image Size and increase the resolution of the image (mine has a width of 7000px) so that the edges can be smoothed.  Select the background using the magic wand tool.  Select>>Refine Edge and set contrast to 100 and adjust smooth until you get the edge where you like (I used 100), you may also want to use the shift edge tool in the refine edge window.
Create a new layer and select the inverse (Select>>Inverse).  Then use the paint bucket tool to fill the selected area with a solid color.  Delete the background layer and save as a png (to preserve transparancy).  I've attached my png file (fig 5).
Step 4: Illustrator
Picture of Illustrator
Import the png into illustrator.  Use illustrator's live trace function to select the border of the shapes in the png and export the resulting vector files as an eps document.  I've attached my eps document below.
Step 5: Laser Cut
Picture of Laser Cut
Use masking tape to secure several sheets of colored tissue paper to a piece of scrap plywood.
Size the images according to the size of tissue paper you have (mine was ~20x26") and send to laser cutter.
Step 6: Assemble
Picture of Assemble
Use a gluestick to glue the hands of the tiny paper people together to make a chain.
bamslower2 years ago
Why did I only just find this tutorial after I finished college!?! I would have totally hogged the laser cutter making thousands of these :-P
