Kemo M172n USB Charger Hacking
428
4
Posted in OutsideBikes
Introduction: Kemo M172n USB Charger Hacking
About: I own and run kLite.com.au, I make dynamo lights and live to ride and see different places....
Hey got some hardware info on modding the Kemo M172n USB dynamo charger, its largish but quite a cheap USB charger made in germany, that I have modded to 930mA output...attached are some pics of how its done...
Basically I removed the switch at top, or if your careful, you can, once switch is loose up top, clip the 3 switch terminals, and re-use that switch...
however, you need to bridge the contacts left on the main board, (left by switch) so the its allways in USB mode...so bridge center contact to right contact of switch (at board level)....
now its always in USB mode, we simply are adding a 'booster cap',(50v 100uf bipolar) IN SERIES with the input...
as per circuit diagram...the main switch now offers the boost cap, or bypass the boost cap to offer 500mA or 930mA @5v USB output,. from any Shimano, SON or SP hub. Questions are fine...
if you want a OFF, in the mix just use a SPDT switch w center OFF...
So when testing it was sometimes hard to find a 'load' to charge that pulls over 900mA....if you plug in your half charge iphone for testing it won't pull 900mA, so some may think the mod don't work...don't' get caught by this...use your meter to test your load pulls at least 1A...then you will have a correct test to see if you can get 930mA....as allways guys, its power, so stay away if you don't know what your doing...
green thing is a switch unit for LIGHTS or CHARGER, and connects to the Dynamo hub
enjoy
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    Hello, and welcome to the Instructables community!
    It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables.
    Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable.
    Successful projects on Instructables include:
    - clearly written details of a finished project with instructions
    - proper spelling and grammar
    - pictures of the project that you took yourself
    I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note.
    Also, we like to feature and reward pro memberships to really well done projects. If you want to see what we look for, check out here!
    Thanks for your submission and we hope to see your project published soon!
