Introduction: Key Hider in Reflective Garden Prism Globe - Beautiful AND Functional!
The inspiration for this Instructable is explained in the song/video....
Actually, my original vision for this Instructable was to use a BOWLING BALL (which is sitting in my kitchen, looking a bit forlorn and out of place). The plan was to drill a large hole in the bowling ball, and insert one of my prescription pill bottles in the hole as the hiding place for the key. The finished project was to be a breathtaking gazing ball/key hider.
Unfortunately, I don't own a Dremel - hence the compromise I had to make using my Mr. Cheapo poor-excuse-for-a drill on a styrofoam ball instead. Oh...and the CONFESSION - I almost forgot. (hanging head in shame) You probably don't really even need a drill if you're using a styrofoam ball. Yes, I'm pathetic, BUT when I saw that the prize for this contest is a Dremel, I ALMOST LOST MY MIND with excitement (not to mention almost having a "senior accident") at the thought that if, by some miracle, I won I could make a REALLLLY HUUUGE gazing ball key hider, thereby fulfilling my original goal!!!
But I digress....
Step 1: Assemble All Materials
Picture of Assemble All Materials
Materials needed for this Instructable:
- 4" styrofoam ball ('or whatever size you prefer)
- White school glue (I used Elmer's brand)
- 1 paintbrush - about a 2" width
- Bowl
- Water to thin glue. I used a ratio of 1/2 cup glue: 2 tablespoons of water
- Mirror tiles (available at any craft store), or you can use glass pebbles, which are less expensive, and can be found at the Dollar Store.
- Small cup on which you can place the styrofoam ball to dry
- Dremel or drill
- Key to hide
- Jewelry findings: 1 large jump ring, 1 cool, sparkly bead with a small hole, 1 head pin with a head larger than the hole of the bead, ball chain or
ribbon.
- Jewelry pliers (I prefer chain nose, or round nose pliers), strong scissors or wire cutter
Step 2: Mix Water and Glue, Then Paint the Ball With Glue Mixture
Picture of Mix Water and Glue, Then Paint the Ball With Glue Mixture
Combine 1/2 cup glue with 2 tablespoons water, and stir well, using a stick or spoon.
Using your brush, paint half of the ball and place on small bowl to dry. This may take an hour or so. Once the ball has dried, apply glue to the other half. Continue alternating sides, until both sides have at least four layers of glue and the ball is completely dry.
If you have a pet, such as a dog or cat, I'd strongly advise keeping this away till you've finished the project, lest it be mistaken for a big marshmallow.
It could get VERY messy!
Step 3: Start Gluing the Mirror Tiles Onto the Ball
Picture of Start Gluing the Mirror Tiles Onto the Ball
Glue the mirror tiles (or glass stones) onto the ball in a pattern that brings you joy. Leave the two ends of the globe unfinished. That's where the hook and the key will eventually be placed.
Step 4: Using a Drill - - or Not
Picture of Using a Drill - - or Not
Drill a hole in the top of the ball where you will screw in the hook, or just screw the darned thing in without the drill. Also, make an opening in the bottom where you will push in your key. Don't make that hole too big, as you want the key to fit in snugly.
Step 5: Squeeze Glue Into the Hole for the Hook
Picture of Squeeze Glue Into the Hole for the Hook
Let the glue "set" in the hole for a few minutes so it thickens up a bit, then screw in the hook, turning till it's in as far as it can go, without forcing it.
Once it's dry, you can add a few mirror tiles to cover the remaining uncovered area at the top.
Step 6: Insert Key and Add Jump Ring
Picture of Insert Key and Add Jump Ring
You've gone far enough when only the top opening of the key is protruding from the ball.
Gently remove the key, and add a few mirror tiles to cover any bare areas.
Now, using your round nosed pliers, open the round jump ring just enough so that it can slip over the top opening of the key. It's better to open the jump ring by just twisting the two ends, rather than pulling them apart, which weakens the metal.
Step 7: Place the Head Pin Through the Hole in the Bead
Picture of Place the Head Pin Through the Hole in the Bead
Then, put the plain end of the head pin through the jump ring.
Step 8: Using Your Pliers, Bend the End Pin.
Picture of Using Your Pliers, Bend the End Pin.
Create a loop to close the end pin, then continue to wrap it around itself two times to secure. If there is excess wire, use your wire cutter to remove it and try to tuck the end in, as flat as you can.
*Safety suggestion: place a towel over your hands when cutting the wire to prevent the wire from flying into your eye, or use eye protection. Keep kids and pets away till you finish cutting the wire. I always turn my head away from the "action" when cutting wire, as a precaution.
Step 9: The Final Step (and a Pledge!)
Picture of The Final Step (and a Pledge!)
Gently insert the key into its hiding place, then using the ball chain, or a ribbon, hang the sparkling key hider in your garden in a place that captures and reflects the rays of the sun, providing beautiful prismatic spots all around! It's particularly spectacular, if there's a breeze causing the globe to turn, reflecting little rainbow dots that appear to float through the air.
Oh, and if ever you forget your key and are locked out, you can always rest assured that you'll be "saved by the ball!" (Pardon the pun!!)
Hope you enjoyed this Instructable. It's my first one, and if I win a Dremel, I pledge to make an Instructable of a bowling ball key hider.
Now THAT will be something!!!
Step 10: The Song Lyrics!
Picture of The Song Lyrics!
THANK YOU INSTRUCTABLES AND DREMEL!!!!
tomatoskins (author)2016-09-14
This is great! I love the final look and all the refection points shown on nearby plants! Beautiful project and very nice presentation!
And thanks to YOU, I was able to create my first Instructable!!! Appreciate your support through the learning process!!
You are welcome! You have so many great ideas! Keep up the great work!
Thank you for your kind words!!!
Atha13 (author)2016-09-21
What a clever idea! I might actually try this! Thanks for an easy project and such a fun instructable!
Mama da Vinci (author)Atha132016-09-21
Thank you!! I appreciate your kind comment. It truly was a fun project to work on!
gm280 (author)2016-09-15
Clever idea and song. Bravo.
Mama da Vinci (author)gm2802016-09-15
Thank you!
You just made my afternoon!!!
Deplorable (author)2016-09-14
Nice. Can you add a picture of the bottom of the ball with the key inserted?
Mama da Vinci (author)Deplorable2016-09-14
Good idea! Thank you! Will do!!
About This Instructable
1,292views
16favorites
License:
More by Mama da Vinci:Plant Hugger DudeKey Hider in Reflective Garden Prism Globe - Beautiful AND Functional!
Add instructable to:
