3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Key Ring Hex Bit
Key Ring Hex Bit
Hy everybody, this instructable describe the construction of a fantastic tool : the KEY RING HEX BIT
Step 1First operation : the sacrifice
first operation : the sacrifice
to realise this useful tool you have to make a sacrifice in Your socket wrench tools set : you take your Drive Sliding Tee Breaker Bar 1/4in and separate (with a hammer or anything else you want to use ...) the bar from the rest of the tool.
29 comments
Apr 30, 2009. 8:20 AMAkoi Meexx says:
Haha, nice! I'll have to make one when I get home from work. :D I have that bit set on the end, in the red case. Harbor Freight FTW.
Mar 26, 2009. 4:37 PMvotecoffee says:
If you want one without destroying a t-socket harbor freight sells a ring driver that ratchets for under 5 bucks. I think the t driver costs more than that. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95895 Another option would be to drill a hole in a 3/8 to 1/4 inch adapter, which are normally cheap and people can have extras lying around that they don't mind destroying, but drilling thm is pretty hard to do without messing up a good bit.
Apr 24, 2009. 9:15 PMzzoe says:
Votecoffee's link worked fine for me, but i still like your version better. Didn't have the bar in my (rather limited) set, so i'm looking for a substitute...i may have to get far clever, as i don't think my drill press is up to putting a big hole in a hardened socket. I like the design so much, i may buy a T/spanner/breaker bar just to pirate the parts. Thanks, again for the clever design.
Apr 10, 2009. 8:55 AMeltotoX says:
This is awesome!
Mar 27, 2009. 6:27 PMjames.mcglashan says:
small and handy
Mar 26, 2009. 3:35 PMLarryB says:
Very nice, another easy way is to add an "ACE" type key to your keyring. Sometimes it takes a tap with a hammer on the small blade outside the round part of these keys, but a 1/4" hex bit fits inside the hollow part of the key pretty nicely.
Mar 26, 2009. 11:13 AMMarrock says:
So long as you don't mind, I'm passing this one around to a few cycling blogs I frequent, brilliant idea.
Mar 26, 2009. 9:20 AMtrgz says:
So simple, and I think I have all the bits I need...
Mar 26, 2009. 6:38 AMelliedad says:
Dude idea too cool I'm totally going to use it
Mar 24, 2009. 9:25 PMleadpencil says:
brilliant!
Mar 23, 2009. 8:30 AMiPodGuy says:
As a school custodian, I bet this would come in handy for me.
Mar 21, 2009. 7:16 AMzzoe says:
Clever, cool, elegant. I often find that i need something opposite the leatherman, as, for example, when i need to hold the nut AND the bolt i'm turning. The swiss army knife was often too delicate in these situations, and now i find i believe that one should 'let a knife be a knife' at least mostly. I am unquestionably going to make one. Bravo.
Mar 19, 2009. 6:19 AMPhil B says:
This is very clever and very helpful for the person who needs a drive like this off and on during his daily routine, and who has a way of carrying the most frequently needed bits on his person. I would not worry too much about sacrificing the "T" handle breaker bar. Those are replaceable at stores like Sears or in many auto parts stores.
Mar 19, 2009. 8:27 AMryukyu says:
You could also just use a 3/8" to 1/4" adapter.
Mar 19, 2009. 9:41 AMchaosrob says:
Most definitely. But then you need to drill it. This is way easier! :-)
Mar 20, 2009. 9:21 AMchaosrob says:
Les, my comment was to the one I was a step under. "You could also just use a 3/8" to 1/4" adapter." That one would need to be drilled. I know that the "T" leaves a hole. Sorry for any confusion.
Mar 20, 2009. 2:53 PMewfw says:
Great instructable.
Mar 20, 2009. 7:22 AMkenbob says:
clean, simple, cheap, brilliant, and useful. I love it.
Mar 20, 2009. 5:46 AMjanet_aj27 says:
Nice! Very Very Nice. i must say, this is one of those utterly simple but Amazingly imressive innovations that will definitely come in handy to all techies and yet so simple that no one would have given it a thought. A+ from me
Mar 19, 2009. 11:08 AMbuteomont says:
Nice, simple, elegant. Does the wooden bead have any significance?
Mar 19, 2009. 4:12 PMjomaro says:
Brilliant. That's one of my most cheered engineering principles put into practice. The KISS principle. "Keep It Simple, Stupid!" And now I will give you an hint: Show around a Marina with a few of those to sell to boatowners... you will make a few easy bucks! Good luck and have fun!
Mar 19, 2009. 2:23 PMsammyBoy says:
love it - brilliant
Mar 19, 2009. 7:50 AMKarel Jansens says:
Brilliant!
Mar 19, 2009. 7:50 AMgmjhowe says:
I love simple ideas like this, and it obviously works well for you! Keep up the good work.
Mar 19, 2009. 6:23 AMPhil B says:
In addition to my previous comment, I have a Leatherman Crunch. It has a bit socket for hex bits, but you must remove the adjusting screw to use it and then hope not to lose the adjusting screw. (The Crunch features a Vise-Grip plier and the adjusting screw is for the plier.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lesrebnav
