3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Keyboard Thumbtacks
Keyboard Thumbtacks
Old hacked up keyboard keys + push pins = awesome keyboard thumb tacks! In just a few minutes I modified some keys from old keyboards, hot glued push pins inside of them, and presto, made some keyboard thumbtacks.
Step 1Materials
Materials
This project only requires a few things:
  • liberated keyboard keys
I got mine from the fine folks who work at the Computer Museum of Austin during Maker Faire Austin this year, but you can take any old keyboard and wedge a screwdriver between the keys and the keyboard to break them off.
  • map style push pins
The heads of thumb tacks are just too large to fit inside the well on the back of the keys. Classy map push pins are the perfect size. I used something like this.
  • Dremel tool, or a pair of pliers, or small hand saw, or an exacto knife
  • drill with drill bit to match the diameter of the head of the push pin. Mine required a 3/16" drill bit.
  • hot glue gun
47 comments
1-40 of 47next »
Apr 15, 2010. 11:00 PMsorjynx says:
 nice revolutionary and techy idea.. i got bunch of broken key and now i got a great innovation for them
Apr 4, 2010. 10:44 AMTreknology says:
Warning! From the left in the reject box, #2 is an ALPS switch top and #3 is a Cherry switch top. I don't recognise the other two off the top of my head,
These are extremely valuable and are proving harder and harder to find--and a well worth something on eBay for people trying to built "just the right keyboard".
The four in the lower "OK" boxes are obviously from membrane keyboards--so go for broke.
I mention this here, because in your Part 1 Instructable, it seems you have used Cherry and ALPS tops as well
Jan 17, 2010. 10:21 PMPoeDunkMae says:
Great idea!
Dec 14, 2009. 6:36 AMman58562 says:
Cool idea.  I have a great boss that just doesn't get the idea of dual monitors.  The second mopnitor he uses as a post-it board.  I'm going to use this, plus I'm planning on gutting a dead LCD and replace the screen with cork board.  I get another working monitor and he keeps his post-it holder and geek-cred is slightly upped.
Dec 7, 2009. 4:31 PMAspenHarper says:
 GREAT IDEA!!! THANKS A LOT!
Dec 7, 2009. 3:22 PMcomander01 says:
April Fool's idea--- Drill a hole in the TOP of the key. Follow the rest of the instructable but glue the tack to the keyboard and replace the key. When someone hits the key, they stab themselves! Instant Comedy!
Dec 7, 2009. 10:20 AMozh says:
Veeeerry cool idea. I think I'm going to convert keys into fridge magnets also :)
Nov 3, 2008. 1:12 PMcowscankill says:
Nice! Ju*t wi*hed I didn't pull out the "$" on my keyboard...
Dec 6, 2009. 10:30 AMMehehehful says:
rofl
Dec 2, 2009. 8:56 AMfreekofnature says:
it might be better to not push the pin all the way so that you have more of the sharp pointyness
Dec 2, 2009. 8:43 AMfreekofnature says:
hey i was wondering if you could just glue on the pin without drilling the whole
Sep 22, 2009. 5:57 PMjmacfarlane823 says:
hehehe i like the magnets idea, the thumbtacks will work great too:P i just got 6 or 7 keyboards from my school, so i have over 700 keys to use *evil laughter*
Sep 19, 2009. 3:02 PMdollywild says:
Very cool- I think I will make some for the co-worker gift exchange. Would be a cool gift for a kid, too, using their mane letters.
Jul 28, 2009. 3:36 AMJames Longpaw says:
this is a great Idea! I was wondering what to do with my old dead keyboards, now I Know what to do.
Apr 18, 2009. 6:39 PMdjpolo98 says:
you also can put magnets on the place of the pin
Jan 24, 2009. 8:17 PMKopolis777 says:
This was in a popular science magazine. Props man props!
Dec 28, 2008. 3:47 PMBill in Detroit says:
This would be especially cool with old terminal keyboards ... more keys, different words, usually double-shot (letters slower to wear off).
Dec 11, 2008. 5:53 AMChico says:
I loved this idea and I tried it right away. I made a couple of discoveries, it's hard to cutoff the plastic with the Dremel, so I just used the wire wheel on my grinder (a wire wheel on a Dremel would probably be too weak). The wire wheel chewed off the excess plastic within seconds and I gripped the keys with a pair of pliers to hold them securely (and away from my fingers). The other thing was that it's dangerous to push the push pin into the key with your bare finger (mine had to be jammed in there a little bit). A thimble works great for that!
Dec 27, 2008. 11:07 AMthatfeller says:
gripping the shaft of the pin with needlenose pliers is as safe as the thimble, and has two advantages for some of us guys: a) it doesn't dull the end of the pin, and b) they're more likely to be in a guy's toolbox than a thimble.
Nov 3, 2008. 10:03 PMduckducrot says:
Love this idea. I'll try this with little button magnets. I use a metallic message board. I plan to adhere the magnets with extra-strength permanent glue dot adhesive. These would make nice, inexpensive holiday (for me, Christmas) gifts. Up-cycling is so in right now.
Nov 6, 2008. 7:43 AMbustedit says:
i like the magnet idea - w enough keys you could even leave messages on the fridge, spellt out!
Nov 7, 2008. 12:03 PMBicycleman says:
Great minds think alike, I had the same idea when I saw this instructable! I'm thinking using keys from a laptop (if I find any) would be nice for magnets as they are thinner. I think the thickness of the magnet will make the key stand out just enough to look good but not so much as to be knocked off when brushing past the fridge. I like the big keys with complete words like "home" and "enter". Used keyboards often have worn out unreadable blank keys. It would be cool to paint in new words or characters like "hope" or smileys so that people wonder what kind of keyboard they're from.
Dec 25, 2008. 11:55 AMDerin says:
My dad types so much when I look at his keyboard i see some of the letters are polished unlike mine which is still textured and dull.
Nov 8, 2008. 11:45 AMRMConstruction says:
Lol, even before i read the comments i thought of spelling things out with them...
Dec 9, 2008. 2:27 PMdz0004455 says:
that is very very cool!
Nov 7, 2008. 3:04 AMpaulareno says:
Not the smartest thing but if you have alot of experience with drills and power tools like me and from the looks of it Noah aswell you should be fine. Ps, drilling your fingure really does hurt :(
Nov 14, 2008. 12:48 PMdigitaltripper says:
hehe...Yeah I tried to drill the carbon fiber outta the mount hole where a skid broke off in my blade CP+ R/C heli....Small bit, went thru the side of my index finger stopped at the nail....Yeah it hurt for awhile. I learned that 11.99 for the heli frame was cheaper than trying to repair it !!
Nov 8, 2008. 11:47 AMRMConstruction says:
*not rudely* how do you know? have you done it yourself? if so, ouch!
Nov 9, 2008. 2:26 AMpaulareno says:
Yeah i done it once when i was trying to trill a tiny piece of plastic, the bit jumped off the plasit and straight into my fingure and wow there was blood everywhere and my fingure hurt for like 3 weeks. i was about 10 yrs old at the time and from than on i have always used a vice while drilling ;)
Nov 10, 2008. 9:41 AMRMConstruction says:
Ouch... lol
Nov 7, 2008. 1:46 PMkewlkiwi says:
Brilliant idea! Great way to salvage *something* from the old keyboards that seem to collect in the closet.
This is an 'Ah-hah!' instructable...
Nov 3, 2008. 11:37 AMmysterygirl154 says:
If this was published on the third, how can that comment be on halloween? Great idea by the way
Nov 6, 2008. 7:56 PMpyrocop1 says:
The person who posted on Halloween has already built a flux capacitor from a earlier instructable
Nov 3, 2008. 2:25 PMjoejoerowley says:
Maybe a collaborator or something like that. idk. Strange. Lovely instructable none the less.
Nov 3, 2008. 1:55 PMskidude28 says:
Wow. That's kinda weird.
Nov 6, 2008. 5:08 PMbeauwalker23 says:
do not it this way! you will make a hole in your fingure!
Nov 6, 2008. 4:22 PMrattyrain says:
This is just wonderfully marvelous.
Nov 5, 2008. 8:35 AMhominid says:
noahw, Hi, this is really snappy and innovative, appeals to my OCD.
Nov 3, 2008. 3:55 PMGorillazMiko says:
VOTE NO ON 8 YEAH BOY GET SOME!!! Noah, you have kids?
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
892
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
