Keyboard Thumbtacks
 by noahw
Featured
Old hacked up keyboard keys + push pins = awesome keyboard thumb tacks! In just a few minutes I modified some keys from old keyboards, hot glued push pins inside of them, and presto, made some keyboard thumbtacks.
Step 1: Materials
This project only requires a few things:
  • liberated keyboard keys
I got mine from the fine folks who work at the Computer Museum of Austin during Maker Faire Austin this year, but you can take any old keyboard and wedge a screwdriver between the keys and the keyboard to break them off.
  • map style push pins
The heads of thumb tacks are just too large to fit inside the well on the back of the keys. Classy map push pins are the perfect size. I used something like this.
  • Dremel tool, or a pair of pliers, or small hand saw, or an exacto knife
  • drill with drill bit to match the diameter of the head of the push pin. Mine required a 3/16" drill bit.
  • hot glue gun
Step 4: Drill out a hole for the push pin
Next, drill out a hole to clean up the cut you just made with the Dremel and clear out a place where you can glue in the head of the push pin. The push pins I got required a 3/16" drill bit.
Be careful not to go all the way through and ruin the key, or drill into your finger.
Step 5: Put hot glue in the hole
Shoot some hot glue into the hole.
Step 6: Insert the head of the push pin
Carefully push the head of the push pin into the little pool of hot glue making sure to submerge it far enough so that it's good and stuck, but not too far so that an insufficient amount of the pin is left sticking out.
Use your pointer finger to hold the tack in place (vertically) as the glue sets.
Step 7: Repeat to make more
Make as many as you like and then use them on your cork boards instead of regular thumbtacks or push pins. They work they same way, but look cooler!
1-40 of 48Next »
swaroop911 says: Dec 23, 2012. 8:07 AM
awesome..! :)
sorjynx says: Apr 15, 2010. 11:00 PM
 nice revolutionary and techy idea.. i got bunch of broken key and now i got a great innovation for them
Treknology says: Apr 4, 2010. 10:44 AM
Warning! From the left in the reject box, #2 is an ALPS switch top and #3 is a Cherry switch top. I don't recognise the other two off the top of my head,
These are extremely valuable and are proving harder and harder to find--and a well worth something on eBay for people trying to built "just the right keyboard".
The four in the lower "OK" boxes are obviously from membrane keyboards--so go for broke.
I mention this here, because in your Part 1 Instructable, it seems you have used Cherry and ALPS tops as well
PoeDunkMae says: Jan 17, 2010. 10:21 PM
Great idea!
man58562 says: Dec 14, 2009. 6:36 AM
Cool idea.  I have a great boss that just doesn't get the idea of dual monitors.  The second mopnitor he uses as a post-it board.  I'm going to use this, plus I'm planning on gutting a dead LCD and replace the screen with cork board.  I get another working monitor and he keeps his post-it holder and geek-cred is slightly upped.
AspenHarper says: Dec 7, 2009. 4:31 PM
 GREAT IDEA!!! THANKS A LOT!
comander01 says: Dec 7, 2009. 3:22 PM
April Fool's idea--- Drill a hole in the TOP of the key. Follow the rest of the instructable but glue the tack to the keyboard and replace the key. When someone hits the key, they stab themselves! Instant Comedy!
ozh says: Dec 7, 2009. 10:20 AM
Veeeerry cool idea. I think I'm going to convert keys into fridge magnets also :)
cowscankill says: Nov 3, 2008. 1:12 PM
Nice! Ju*t wi*hed I didn't pull out the "$" on my keyboard...
Mehehehful in reply to cowscankillDec 6, 2009. 10:30 AM
rofl
freekofnature says: Dec 2, 2009. 8:56 AM
it might be better to not push the pin all the way so that you have more of the sharp pointyness
freekofnature says: Dec 2, 2009. 8:43 AM
hey i was wondering if you could just glue on the pin without drilling the whole
jmacfarlane823 says: Sep 22, 2009. 5:57 PM
hehehe i like the magnets idea, the thumbtacks will work great too:P i just got 6 or 7 keyboards from my school, so i have over 700 keys to use *evil laughter*
dollywild says: Sep 19, 2009. 3:02 PM
Very cool- I think I will make some for the co-worker gift exchange. Would be a cool gift for a kid, too, using their mane letters.
James Longpaw says: Jul 28, 2009. 3:36 AM
this is a great Idea! I was wondering what to do with my old dead keyboards, now I Know what to do.
djpolo98 says: Apr 18, 2009. 6:39 PM
you also can put magnets on the place of the pin
Kopolis777 says: Jan 24, 2009. 8:17 PM
This was in a popular science magazine. Props man props!
Bill in Detroit says: Dec 28, 2008. 3:47 PM
This would be especially cool with old terminal keyboards ... more keys, different words, usually double-shot (letters slower to wear off).
Chico says: Dec 11, 2008. 5:53 AM
I loved this idea and I tried it right away. I made a couple of discoveries, it's hard to cutoff the plastic with the Dremel, so I just used the wire wheel on my grinder (a wire wheel on a Dremel would probably be too weak). The wire wheel chewed off the excess plastic within seconds and I gripped the keys with a pair of pliers to hold them securely (and away from my fingers). The other thing was that it's dangerous to push the push pin into the key with your bare finger (mine had to be jammed in there a little bit). A thimble works great for that!
thatfeller in reply to ChicoDec 27, 2008. 11:07 AM
gripping the shaft of the pin with needlenose pliers is as safe as the thimble, and has two advantages for some of us guys: a) it doesn't dull the end of the pin, and b) they're more likely to be in a guy's toolbox than a thimble.
duckducrot says: Nov 3, 2008. 10:03 PM
Love this idea. I'll try this with little button magnets. I use a metallic message board. I plan to adhere the magnets with extra-strength permanent glue dot adhesive. These would make nice, inexpensive holiday (for me, Christmas) gifts. Up-cycling is so in right now.
bustedit in reply to duckducrotNov 6, 2008. 7:43 AM
i like the magnet idea - w enough keys you could even leave messages on the fridge, spellt out!
Bicycleman in reply to busteditNov 7, 2008. 12:03 PM
Great minds think alike, I had the same idea when I saw this instructable! I'm thinking using keys from a laptop (if I find any) would be nice for magnets as they are thinner. I think the thickness of the magnet will make the key stand out just enough to look good but not so much as to be knocked off when brushing past the fridge. I like the big keys with complete words like "home" and "enter". Used keyboards often have worn out unreadable blank keys. It would be cool to paint in new words or characters like "hope" or smileys so that people wonder what kind of keyboard they're from.
Derin in reply to BicyclemanDec 25, 2008. 11:55 AM
My dad types so much when I look at his keyboard i see some of the letters are polished unlike mine which is still textured and dull.
RMConstruction in reply to BicyclemanNov 8, 2008. 11:45 AM
Lol, even before i read the comments i thought of spelling things out with them...
dz0004455 says: Dec 9, 2008. 2:27 PM
that is very very cool!
paulareno says: Nov 7, 2008. 3:04 AM
Not the smartest thing but if you have alot of experience with drills and power tools like me and from the looks of it Noah aswell you should be fine. Ps, drilling your fingure really does hurt :(
digitaltripper in reply to paularenoNov 14, 2008. 12:48 PM
hehe...Yeah I tried to drill the carbon fiber outta the mount hole where a skid broke off in my blade CP+ R/C heli....Small bit, went thru the side of my index finger stopped at the nail....Yeah it hurt for awhile. I learned that 11.99 for the heli frame was cheaper than trying to repair it !!
RMConstruction in reply to paularenoNov 8, 2008. 11:47 AM
*not rudely* how do you know? have you done it yourself? if so, ouch!
paulareno in reply to RMConstructionNov 9, 2008. 2:26 AM
Yeah i done it once when i was trying to trill a tiny piece of plastic, the bit jumped off the plasit and straight into my fingure and wow there was blood everywhere and my fingure hurt for like 3 weeks. i was about 10 yrs old at the time and from than on i have always used a vice while drilling ;)
RMConstruction in reply to paularenoNov 10, 2008. 9:41 AM
Ouch... lol
kewlkiwi says: Nov 7, 2008. 1:46 PM
Brilliant idea! Great way to salvage *something* from the old keyboards that seem to collect in the closet.
This is an 'Ah-hah!' instructable...
mysterygirl154 says: Nov 3, 2008. 11:37 AM
If this was published on the third, how can that comment be on halloween? Great idea by the way
pyrocop1 in reply to mysterygirl154Nov 6, 2008. 7:56 PM
The person who posted on Halloween has already built a flux capacitor from a earlier instructable
joejoerowley in reply to mysterygirl154Nov 3, 2008. 2:25 PM
Maybe a collaborator or something like that. idk. Strange. Lovely instructable none the less.
skidude28 in reply to mysterygirl154Nov 3, 2008. 1:55 PM
Wow. That's kinda weird.
beauwalker23 says: Nov 6, 2008. 5:08 PM
do not it this way! you will make a hole in your fingure!
rattyrain says: Nov 6, 2008. 4:22 PM
This is just wonderfully marvelous.
hominid says: Nov 5, 2008. 8:35 AM
noahw, Hi, this is really snappy and innovative, appeals to my OCD.
GorillazMiko says: Nov 3, 2008. 3:55 PM
VOTE NO ON 8 YEAH BOY GET SOME!!! Noah, you have kids?
1-40 of 48Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
