i got the idea when i popped off a key from my key board and looked at its shape, and it fit perfectly on my Rubik's cube
*thanks to the editors for the feature*
*thanks to all of you that have voted!!!*
Remove these ads by
Signing UpStep 1Materials
a Rubik's cube (maybe the one that your stickers are falling off of =D
a tube of epoxy, or other strong plastic on plastic glue (I used clear drying)
guitar pick or razor blade
two (2) keyboards, one black and one white
small fan
clamps
fingernail polish remover/goo-gone or similar product (to remove residue from stickers)
thin wood or cardboard
flat head screw driver
needle-nose pliers
rubber/latex gloves
tooth picks
face mask (cause the epoxy smells)
six (6) plastic bags
spare thin cardboard, or something else to mix the epoxy on
dremel power tool (recommended but not necessarily needed)
roll of paper towels
lots of time
does it only involve rubiks strategies or Sudoku Strategies as well?
I used the F-keys, numpad and number keys, A-I, the nine keys in the upper right of the keyboard (page up, down, pos 1, roll etc). On the last side I put the four directions, -, /, *, ';' and _ .
Solving the cube might be very tricky, so it's just decoration at the moment :D
thanks for your instructions! I modified it a bit, but it worked perfectly!
Sry for bad quality -> iPhone
I don't understand how you removed the 'cubbies' from the Cube.
I am kind old and slow so sometimes I don't understand , do they just pull off? and in what direction do you pry them off??? If you can make this old guy understand, I sure would appreciate it...James
is ' up or down/cw or ccw?
If you consider cw and ccw then R would be up while L would be down
or are both R & L down and R' & L' up
also i found a faster way to spin the top center piece 180
U R L U2 R' L' U R L U2 R' L'
(U2 being spin 180)
and thanks for the faster algorithm!! that is way quicker than the one i found!! =D
once my computor breaks i will make this(: haha
