3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Keyboard/Sudoku Rubik's Cube...dead computer contest
Step 5Important Details/Finished Cube
After its dry, all you need to do is lube it up and you'll be ready to go!!
Some Notes
I kept the 3 white sides so they converged at one corner, and same with the black (at the number 3)
The cube is actually more like a picture cube than a real sudoku cube, it just looks like one...so you will need extra algorithms to solve the cube:
     M' U' M U (5 times)...turns top middle clockwise 1, and front middle counter clockwise 1
     M U M' U' (5 times)...turns top middle counter clockwise 1, and back middle clockwise 1
note-M' is away from you
Hang on, this one is LONG
     R U R' U R U U R' U R U R' U R U U R' U R U' L' U R' U' L U U R U' L' U R' U' L...turns top middle 2 times
thanks to abunai59 from Youtube with the video "How to Solve a Picture Rubik's Cube!!http://www.youtube.com/watch?v=5xQ7qf0EAvY&feature=fvw
*EDIT: here is a way shorter algorithm for rotation of the top middle twice
     U R L U2 R' L' U R L U2 R' L'
thanks go to Gonazar for the short one!
i use them, so they work
final notes
the cube even stands on its own
i had keys that were long, from an ergonomic keyboard, so i used the dremel tool to cut them (see picture 4)
thanks for reading, good luck, post your picks, and leave your comments and questions if you need anything!
5 comments
Mar 29, 2010. 2:05 AMnaj_wolf says:
I used a single keyboard, here's the result:
Mar 30, 2010. 4:01 AMnaj_wolf says:
At first, I used a german keyboard. So some keys may be different from your keyboard.
I used the F-keys, numpad and number keys, A-I, the nine keys in the upper right of the keyboard (page up, down, pos 1, roll etc). On the last side I put the four directions, -, /, *, ';' and _ .
Solving the cube might be very tricky, so it's just decoration at the moment :D
thanks for your instructions! I modified it a bit, but it worked perfectly!
Mar 30, 2010. 4:06 AMnaj_wolf says:
Why do I try to describe it so hard... pictures tell more than words.
Sry for bad quality -> iPhone
Feb 26, 2010. 2:17 PMGonazar says:
Could you please explain the notation for the algorithms?
is ' up or down/cw or ccw?
Feb 26, 2010. 2:46 PMGonazar says:
More specifically when your talking about R or L is R' up or down same with L'
If you consider cw and ccw then R would be up while L would be down
or are both R & L down and R' & L' up
Feb 26, 2010. 2:58 PMGonazar says:
Never mind i figured it out, R and L would be opposite so according to the cw and ccw rules
also i found a faster way to spin the top center piece 180
(U2 being spin 180)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Overlord5
