Keyless Dorm Entry
Keyless Dorm Entry
The basic problem behind this project was that keys are something very easy to forget or lose, and they are the only way into my dorm room. This is especially a pain when leaving the room for a short time, such as to go check mail or give something to a friend. It's a bad idea to leave the room unlocked, but a pain to take keys. A solution to this would be to provide another method of access with something easier to carry, or not even needing anything to carry anything at all. This must also be accomplished without modifying the door in any unauthorized way.
Step 1Solution
A device will be attached to the door that is able to lock and unlock the door by pulling the lock. It will do this when the correct number is typed in, or an ID is scanned. A school idea is much easier to carry around, and is required to get into the building anyway. And even without it, typing in the correct number requires carrying nothing additional.
44 comments
1-40 of 44next »
Feb 3, 2011. 4:09 AMrrrmanion says:
why not.. get another door, modify that, then replace it.. then put the original back when you go?
Dec 12, 2010. 8:14 PMmikebook says:
So I take it that this uses odd parity? Also, doesn't having the left most bit being the ones place go against most convention of binary? Finally, is the data in ASCII or is it raw binary to decimal data conversion?
May 15, 2010. 5:06 PMFoxtrot70 says:
Nice Instructable.  Definately need to secure the ribbon cable better.  There is another Instructable using RFID the author there had a chip implanted in his hand (same type used for dogs) all he does is wave his hand at the door and it unlocks as I recall it is on his car.  Possibilities with the chip are endless one has to decide if they want they want to get implanted.
May 20, 2010. 10:57 PMandrew_h says:
 I've done RFID too and i'd be keen to get an implant but so far i have been unable to find a 'medical grade' 125kz manchester tags in low quantities in Australia
Jun 17, 2010. 7:13 AMFoxtrot70 says:
Hey Andrew I would think that a vet would have these on hand, provided they are the same type. The problem then might be in Australia any medical laws in using a product designed for animal husbandry for human medical. Since they would be implanted into a canine it too would need to be "sterile" or of "medical grade". Mike aka: Foxtrot70
Jun 17, 2010. 3:56 PMandrew_h says:
I've found one now! They are on their way from America as i type. Hopefully within a week i will have one in my hand (literally)! Just trying to find/convince a medical person to do it for me. As you mentioned, because they are not certified for implantation in humans, most medical practitioners will not do it due to liability issues. I'm open to doing it myself but i'd rather that someone with medical experience done it for me. Even piercing shops seem to be reluctant though.
Jun 18, 2010. 8:24 AMFoxtrot70 says:
Can you send me apic of the chip?
Jun 18, 2010. 8:21 AMFoxtrot70 says:
Hey Andrew - Here is a comical thought...If I were going to implant one of these chips I think I would have it implanted in my second finger, that way when ever I used the chip I would be giving the device "The Bird" - LOL
Jun 18, 2010. 8:06 AMFoxtrot70 says:
Hey Andrew - They are concerned with infection and product failure. If you do it yourself, get in touch with a Vet or MD or even piercing shop and review insertion and sterilization procedures and local anesthetics, again this might be problematic as to who is administrating the anesthetic. You might try looking up the Instructable of the individual who made an RFID controller for his car and has chip emplanted in his hand he might be able to provide more information in this area.
Jun 18, 2010. 5:27 PMandrew_h says:
The chip i have bought is a HitagS 2048 from Brett @ http://www.sleepallday.org. He's a great guy, he helped me determine it's compatibility with the ID-12 chip. They are programmable to 'modes' and in particular he has programmed it to EM4102 standard for me (which can be read by the ID-12). I'm quite well aware of the reasons people seem reluctant to help out but failling to find someone to actually do it for me, i will be seeking propper medical advice on how to make sure i do it safe. The last thing i want is to have it get infected and end up in hospital to have it removed. I'ts sort of a catch 22 situation where if i get a medical person to do it for me, there is much less risk but they won't take that little risk. On the other hand, there is much more risk if i do it myself but i'll only do it myself if i can not find a 'propper' person to do it for me. So far 3 peircing parlours have declined my request to do it for me which seems odd. One of them is known as a more extreme peircing place too. I'm going to see if my GP will do it for me next.
Jun 19, 2010. 8:52 AMFoxtrot70 says:
Sounds like you have a good handle on everything. After looking at the various comments about implanted chips amazing the level of ignorance out there from all quarters. Since your project is a very limited one your personal identity security is not a question unless you decide later on to include internet access. Your project is really good one and pardon the pun...very handy!
Jun 24, 2010. 6:33 PMandrew_h says:
Well, it's done! I now have a HitagS tag implanted in my hand....
Jun 25, 2010. 6:52 AMFoxtrot70 says:
Hey Andrew - COOL BEANS! Tell me asbout the procedure. Currently do you experience any discomfort? Have you had a chance to try the circuitry? This is really exciting! - Mike
Jun 25, 2010. 4:38 PMandrew_h says:
Well i finally found a local piercer to do it for me. He was actually quite excited to do it - the very opposite of all the others. It was a very simple, quick and nowhere near as painful as i expected. He simply grabbed a 10g peircing needle (probably could have got away with a 12), peierced the skin and pushed it in till the tip was about where the end if the chip should be. Then he just twisted the needle about 90deg to open the hole a bit more. That probably hurt the most. Then he removed the needle and popped the tag in, giving it some help from the back of the needle. A little pressure and a couple of minutes later i was on my way with a bandaid to cover the wound. Note that this was a piercing needle, not a normal syringe type needle. On a pain scale out of 10 for me, only about a 2-3 and that was when he twisted the needle, other than that, it was about a 1. Within about 2 hours i barely even knew i had it done other than some tenderness around the injection site. Now, about 36 hours later its almost painless unless i have something push hard into the webbing where it pushes the implant in further. That should go with healing though. It took a while to get the smile off my face the first time i heard that gratifying 'beep' as the tag read on my door entry system after getting it done! the pic is a little deceptive, it looks like the injection site is in the webbing but it's not.
Jun 25, 2010. 6:16 PMFoxtrot70 says:
Hi Andrew - Pic looks great! Did the piercer use a local anesthestic? What was the cost of the chip and cost for implantation? When you wave your hand at the sensor, pardon me I have to ask this, do you command, "Open Seseme"? What is the furthewst distance you can be from the door sensor? Upon further consideration I think this would be rather secure, short of a retina scanner, no keys or access cards to loose. - Mike
Jun 25, 2010. 8:44 PMandrew_h says:
No anasthetic. Not really needed. The chip was US$10 plus shipping from sleepallday.org and they charged me US$35 to implant it but i suplpied my own sterile needle. It can be read through my hand by the ID12 but not much more than that. So about 3-4cm. That could be better with an external antenna though. I would not say it's any more secure than keys but it is definately more convinient. The tags CAN be copied so there is risks but with a read distance very short, someone would have to get pretty personal with me to read it and not only that, they would have to care and think it would be EASIER than just smashing my window or door down. It's not as if i use this for access to my bank account or something that would offer much reward if it was compromised.
Sep 6, 2010. 9:32 PMwillrandship says:
Cool! I have one question, though. Do electronics and other stores give you trouble when leaving by setting off alarms? That would seem to be the only problem after everything is said and done.
Sep 6, 2010. 10:26 PMandrew_h says:
No, not at all. They operate on different frequencies so there is no problems. Airport scanners are fine too.
May 23, 2010. 7:30 AMtristantech says:
All electronics no longer stocks the card reader!! :-(
May 22, 2010. 7:42 AMnerd12 says:
you said not modifying your door in an unauthorized way.
since when is this become authorized
the matron would kill you if you did this without its permission
May 21, 2010. 7:42 PMwesie42 says:
this was completely pointless, because in order to lock it in the first place you need a key, and you would be outside the door...so you would have the key anyways DER DUH DERRR
May 21, 2010. 6:17 PMdoughnutguy1 says:
you know, if someone was pissed at you and they wanted to trash your dorm they could just kick the door open o.O
May 20, 2010. 6:13 PMbaggins says:
Just one comment about the flowchart. You don't want to tell anybody that the PIN is wrong until they are done entering it, otherwise it would take significantly fewer tries to figure out the PIN.
Assuming your PIN is 9999 and the attacker works through numbers ascending from 1 on a numpad from 1-9.
Instant denial: 8+8+8+9 = 33 tries to break in
(the first three are eight because by once the attacker gets to 8 he knows the next digit is 9 and can proceed to the second digit of the code)
Denial at the end: 9*9*9*9 = 6561 tries to break in
May 20, 2010. 6:15 PMbaggins says:
Sorry, I misread the flowchart. I saw "mark key wrong" and didn't notice the "Unlock?" step just checked to see if the key was wrong.
May 16, 2010. 8:43 AMleinad23ec says:
Hey there, I am always amazed at the creativity of all members in this site, I love it. But I would just like to ask anyone, what career would I have to study in order to get the knowledge necessary to create something like this on my own.
I have a lot of ideas, but i lack the education to put it all together
I would to create stuff with circuit boards, or even little programming, how to read electric schematics and stuff, because the more interesting Instructables I find are solar energy, or ones like this from spare electronic parts!
Thanks in advance.
May 20, 2010. 10:39 AMcarriepatrick71 says:
Just get a book on electronics for beginners. Make: Electronics is a very good one that starts with the basics. www.amazon.com/MAKE-Electronics-Learning-Through-Discovery/dp/0596153740
From what I've seen, almost everything on Instructables is stuff that anybody can do. You don't need to get a degree to build a circuit board, you just need to mess around at home and read some books.
May 18, 2010. 2:00 AMSyko Pyro says:
Generally, Electronics Engineering with a major in your chosen area, for university. Or, a trainee/apprentiship.
May 20, 2010. 7:37 AMVarenberg says:
Why don't you just change the lock in a automated door lock, would make things a whole lot easyer, and cheaper if you think about it
May 20, 2010. 10:01 AMZovits says:
"This must also be accomplished without modifying the door in any unauthorized way."
He lives in a dormitory, where it's probably highly regulated what one can do with their room (including the door).
May 20, 2010. 6:59 AMardrhi says:
Ize in ur dorm rum eatin ur pi
May 16, 2010. 1:16 PMOruKun says:
 Wont you still need to have a key to close it, unless you have it automatically closes itself. Instead of using a string that just pulls it open, use a metal line, or straight piece of metal that can open and close the deadbolt.
May 16, 2010. 1:14 PMOruKun says:
 Wont you still need to have a key to close it, unless you have it automatically closing itself.
May 16, 2010. 1:20 AMMorriscow says:
 thats a deadbolt, dont you need a key to lock it?
May 15, 2010. 7:04 PMthatoneguydavid says:
great implementation of a card reader.
i do have a couple of suggestions however:
*move all of the electronics to the other side of the door (the locked side) and have only the card reader on the outside.  this way you would only have the card reader data bus exposed. i imagine that it is just serial, so maybe 4 wires, +/- RX and TX?
*add the ability to lock the door with the card.  this would mean changing your servo set up slightly.  you could probably still do it with one servo though.  And that way you could eliminate the need for the key all together.
I Hate Keys!
May 15, 2010. 7:29 AMArbitror says:
There is one problem though. I don't know what the level of stupidity there is at your dorm, but I would expect some moron to come and cut the ribbon...
May 15, 2010. 10:14 AMzack247 says:
like iamtoats said, put  some metal sheilding over it to protect it. only if they are smart will they test the wires after cutting them to trigger the servo and unlock the door
May 15, 2010. 1:07 PMArbitror says:
Most people with malicious intention probably isn't smart enough. But even if someone who would try to "hot wire it", could be stopped by using a signal that only the box on the outside can produce, that the electronics on the inside would recognize. That way you can only initiate that signal by entering the right code.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:JefffN
