Keypad Access 4x4 With Arduino
915
23
Published
Introduction: Keypad Access 4x4 With Arduino
About: Electronics Component - PCB [Design, Printing, Inserting] - Electronic Programming
The 4x4 keypad is a composite of 16 keys arranged like a matrix. The method used for accessing 4x4 keypad with matrix scanning method. The 4x4 keypad requires 8 pins to access it, ie 4 pins for the columns and 4 pins for the line. How the scanning method works is that the column pin takes the LOW logic interchangeably, then the line pin performs the readings in turn as well.
Step 1: Materials You Need
You will need:
  • Arduino
  • Keypad 4x4
  • Jumper Wires
Step 2: Pin Out
  1. PIN A3 --> pin to 0 row
  2. PIN A2 --> pin to 1 row
  3. PIN A1 --> pin to 2 row
  4. PIN A0 --> pin to 3 row
  5. PIN 4 --> pin to 0 colomn
  6. PIN 5 --> pin to 1 colomn
  7. PIN 6 --> pin to 2 colomn
  8. PIN 7 --> pin to 3 colomn
Step 3: Schematic
Connect each component as the picture above.
Step 4: Code
#include <Keypad.h> //import library keypad
const byte ROWS = 4; //number of colomn
const byte COLS = 4; //number of row
char hexaKeys[ROWS][COLS] = {
 {'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}
byte rowPins[ROWS] = {A3, A2, A1, A0}; //pin used for row
byte colPins[COLS] = {4, 5, 6, 7}; //pin used for colomn
//initialization variable
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
 Serial.begin(9600);
void loop(){
 char customKey = customKeypad.getKey();
 if (customKey){
   Serial.println(customKey);
Step 5: Output
Check the output!
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
