Keypad and SMS Based Dual Door Lock System
Introduction: Keypad and SMS Based Dual Door Lock System
Dual password lock system is designed to open lock via Keypad when available at home and via SMS when away from home in case the guest arises
The SMS feature also provide the availability to change password.
Step 1: Video for Easy Implementation
It will show the password and how we can change the password
Step 2: List of Components
With Quantity
Step 3: Circuit Diagram
along with name of component and connection
Step 4: CODE
Embedded C operated in Keil uvision software
Step 5: 1) Lock System
It can be designed used metallic with magnetic lock in actual door.
Here i have used a box which is connected to a 12v DC geared motor having 60 rpm. It is rotated clock wise or anti clockwise to close or open the door. The motor is being controlled by L293D ic which is known as motor driver IC.
Step 6: 2) Keypad Section
This section contains 10 switches numbering 0 to 9
Whenever the switch is being pressed logic "0" is being transmitted to the controller section to know whether the switch is being pressed or not.
Step 7: 3) GSM Modem
It is used to provide the SMS facility to the system as we are using dual facility for password using keypad and SMS
The SMS facility also provide us the option of changing the password as this option is not added in keypad
Step 8: 4) Power Supply
This unit provides power to the complete section which is designed using 12-0-12 transformer and rectifier section and capacitor 1000uf and regulator 7805
Step 9: 5) IC Section
Containing the IC of controller, EEPROM and motor driver
It is used to
  1. Store password
  2. Display on LCD whether correct or wrong password
  3. Verification of password
  4. For storing new password
  5. Verification of SMS
  6. Controlling of motor
Step 10: 6) Display Section
LCD 16x2 is used for displaying
  • Whether sms is received or not
  • Received sms is correct or not
  • Whether password is correct or not
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    Hello sir, we are trying to make this project but are facing some issue. Is there a way we can contact you or talk about the issue?
    Thanking you
    what is the approximate cost of this project. this is exactly what I need for my shop. awsome project.
    Do you want to purchase the project?
    and where are you from?
    Great project! Thank you for sharing!
