Keyring Charging Cable (1 Minute, No Cost [except the Cable])
18,717
315
23
Published
Introduction: Keyring Charging Cable (1 Minute, No Cost [except the Cable])
About: I like to make / fix / improve "things"...
Today I stumbled upon this clever idea on indiegogo.com:
https://www.indiegogo.com/projects/incharge-the-sm...
First thought, as always: "Wow, why didn´t I came up with this idea?"
Simple, clever, cheap and really solves some (first world) problems. So if you like it, please support those guys.
Second thought: "Well, I got a short charging cable, so why not make it a keyring cable...".
So off i went to plunder my bargain bins and about one minute later I had my own perfectly working keyring charging cable.
Step 1: Materials and Tools
Pretty overseeable:
- Short charging cable (mine was from Amazon Basics)
-Scissors
- Piece of bicycle innertube (preferably from a road bike, diameter fits perfectly to those somewhat bulky Amazon Basics plugs, optionally you can use a simple rubber ring and wrap it around the plugs a few times, probably won´t look as sleek, but will work, too)
Step 2: To Do
Cut a section of the innertube matching the length of your USB-plug.
Slip it over the USB-plug.
Bend your cable and slip/squeeze the Lightning-/Micro-USB-/or-whatever-else-plug into the rubber cover.
(Optional: Glue the rubber cover to the USB-plug on one side. Didn´t try that yet, works fine without and you might encounter problems finding a glue which works for [soft] plastics and rubber as well... Tell me if you found a working solution!)
Attach to your keyring.
That was easy, wasn´t it? :)
Have fun!
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Creative Misuse Contest
    23 Discussions
    I have one of these Nokia cables that I might use. These are bombproof?
    A single thought occurred: why not use an O-ring!
    They look pretty slick
    Absolutely love the idea though.
    Seems to me that an O-ring would tend to roll/slide off of the plugs. But worth a shot.
    I'm going to do this tomorrow, but instead, I'm going to wrap each end in heatshrink with a little earth magnet underneath so they snap together.
    is there a risk of the magnet messing with the phone's our other device's function?
    From my experience, which includes the past 9 years in electronics repair, small magnets would cause no issues on modern (solid state) devices.
    Please post a pic or link if you have finished your build.
    I´m a big fan of rare earth magnets. That approach also leaves the cable itself unaltered, maybe I will try that, too.
    Will do. I'm just waiting on my short USB to come in to do it. Also, I got a 12 pack of small magnets at Home Depot for this.
    Wow, thanks for all the nice comments!
    Can´t believe so many of you viewed my little sudden inspiration! :D
    I hope you found it helpful :)
    Thanks for the recommendations regarding glue, but using only the "rubber sleeve" works like a charm and leaves the cable itself unaltered, which I like. Think I will stick with that for now.
    I also like the ideas of using velcro or magnets heatshrinked to the plugs.
    Please post photos or link to own `ible here!
    Regards
    Great idea! Nice, simple, cheap and effective. I think a good alternative to the bicycle tube would be a velcro strip with epoxy on the back to ensure that it stays on, so that way it's easier to take apart the cable :)
    I like it!
    Look at a clear glue called E 6000.
    it is the best multi purpose glue ever.
    made by Fabricado por Eclectric Products
    i buy this in 10.5 oz Caulking gun tubes. the E6001 is a slower thicker version.
    Just LOVE this !
    Slim
    H2Hold by Devcon would be a good glue
    Awesome idea and easy to carry, thanks
    yaly
    3 years ago
    I guess using velcro (a side on each plug) would be neater and slicker.
