This Instructable is for building a kids toy crane.  I call it a toy, but it is really a heavy duty machine for a kid of any age.  I designed this crane for my son who was a crane fanatic at the time.
The crane is built mostly from wood and uses various screws, nut, bolts, caster wheels, and a variety of other parts.
I will try to give as much information as possible so you can build something similar.  Believe me that your kids are going to love this thing.  It may take some time to build, but the results are worth it.  What else are you going to do with your spare time.
Step 1: Tools and Materials You Will Need
Materials
This is a fairly long list of materials, but you may be able to use some parts that you already have.
MATERIALS LIST
WOOD
  • 1 - 3/4" x 60" x 60" baltic birch plywood
  • 1 - 1/2" x 8" x 12" baltic birch plywood
  • 1 - 1/4" x 3" x 12" baltic birch plywood
 HARDWARE
  • 17 of 1/4" x 4" carriage bolts - home improvement store
  • 1 of 1/4" x 4" carriage bolts - home improvement store
  • 4 of 1/4" x 5" carriage bolts - home improvement store
  • 1 of 1/4" x 6" carriage bolts - home improvement store
  • 10 of 1/4" flat washer - home improvement store
  • 4 of 1/4" flat washer - nylon or plastic - home improvement store
  • 12 of 1/4" lock washer - home improvement store
  • 2 of 1/4" carriage bolt caps - home improvement store
  • 34 o1/4" nyloc nut - Nylon-Insert Locknut 1/4"-20 Screw Size - home improvement store or McMaster (404) 629-6500 http://www.mcmaster.com/ part# 90640A129
  • 12 of 1/4" - 20 x 1-1/4" panhead straight bolt - home improvement store
  • 4 of 1/2" flat washer - home improvement store
  • 1 of 1/4" - 20 x 1-1/2" cap screw (allen wrench or slotted head) - home improvement store
  • 1 of 3/8" x 3-1/2" carriage bolt - threaded on end only - not all-thread Home Depot or other home improvement store
  • 2 of 3/8" flat washer - home improvement store
  • 1 of  3/8" nut - home improvement store
  • 1 of 3/8 nyloc nut - home improvement store
  • 1 of 1/2" x 3 foot long steel rod - home improvement store
  • 1 of 1" x 1/8" x 3 foot aluminum bar stock - home improvement store
  • 10 of 1-5/8" coarse gold #8 deck screw or regular #8 wood screw - home improvement store
  • 5 of 2" coarse gold #8 deck screw or regular #8 wood screw - home improvement store
  • 4 of 1-1/4" #6 pan head wood screws - home improvement store
  • 4 of 1-1/4" (32mm) washer head #2 square drive coarse screws (for pocket holes) - not needed if attaching the seat top by other method - home improvement store
  • 2 of 1-1/4" #8 - 32tpi machine screw (for attaching sprockets to 1/2" rod) - home improvement store
  • 3 of 2" #8 - 32tpi machine screw (for tapped holes in modified caster wheel and attaching sprocket on bike crank) - home improvement store
  • 3 of #8 nyloc nut - home improvement store
  • 1 pk of 1/4'' -20 Threaded Inserts - order 1 pack of 10 - 2 are needed Woodcraft - 800-225-1153 http://www.woodcraft.com part#12K50 $5.99
MISCELLANEOUS
  • 1 pk of 1/2" rare earth magnets - order 1 pack of 10 - 8 are needed Rockler Woodworking and Hardware - 1-800-279-4441 http://www.rockler.com 30810 $8.29
  • 1 of 1/2" copper pipe x 5-feet long - home improvement store
  • 10 feet of 1/4" nylon rope - home improvement store
  • 1 plastic hook - home improvement store
  • 1 of Steel Ball Bearing, Flanged Double Sealed For 3/8" Shaft Dia, 7/8" Od McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6384K354
  • 2 of 1/2" inner diameter / 1-1/8" outer diameter roller bearing - for transfer rod McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 60355K46
  • 1 Miscellaneous 1/2" inner diameter shaft lock collar McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6432K16
  • 1 of 18 tooth #35 sprocket with 7/8" bore diameter - for caster McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6280K21
  • 2 of 10 tooth #35 sprocket with 1/2" bore diamter - for transfer rod McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6280K322
  • 1 of 16 tooth #35 sprocket with 1" bore diamter - for foot crank McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6280K385
  • 1 pk Miscellaneous nylon spacers - 1/4" inner diameter, 1/2" outer diamers, 3/4" long - approximately 26 needed, but come in pack of 100 McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 94639A505
  • 1 of 2-inch diameter smiley face superball - Local Craft Store
PEDALS AND BIKE PARTS
  • 1 ea Pedals Pyramid Barefoot Pedals, 1/2 PN# 41021 BikepartsUSA A Bicycle Inc. - (877)-727-8731 http://www.bikepartsusa.com SKU: 01-117564 $9.99
  • 1 ea Bike Crank Pyramid 3-1/2 PN# 21016 crank BikepartsUSA A Bicycle Inc. - (877)-727-8731 http://www.bikepartsusa.com SKU: 01-97559 $7.29
  • 1 ea Bottom Bracket Pyramid BMX, 1-pc, 24 TPI, BB set PN# 22240 - bottom bracket BikepartsUSA A Bicycle Inc. - (877)-727-8731 http://www.bikepartsusa.com SKU: 01-98783 $5.99
CASTERS
  • 3 of 3" Casters, Non-Locking, Non-Swiveling with 4 Hole Mounting Plate Woodcraft - 800-225-1153 http://www.woodcraft.com part# 141052 $11.50
CHAIN
  • 4 feet of #35 roller chain McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6261K294
  • 4 of #35 chain connecting link McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6261K191
  • 2 of #35 chain half connecting link McMaster - (404) 629-6500. http://www.mcmaster.com/ part# 6261K261
All wood pieces were finished with wipe-on polyurethane.  It works great and makes touch-ups easy. Make sure to use multiple coats.
Tools
The tools I used on the project were as follows:
  1. Table saw - JET
  2. Band saw - GRIZZLY
  3. Oscillating spindle and belt sander - RIDGID
  4. Cordless drill - MILWAUKEE
  5. Drill press - DELTA
  6. Random orbit sander - PORTER CABLE
  7. Router - PORTER CABLE
  8. Router table.
  9. Pipe cutter for copper pipe.
  10. Hacksaw or cutoff saw
  11. Sanding block
  12. Screwdrivers and wrenches - CRAFTSMAN
Not all of the tools in this list are required, but will make the construction much easier.
Here is a link to one of the Craftsman wrenches I used.
I wish I would have had this Craftsman sander for sanding the larger wood pieces in this project.  My other sander was going out while I was finishing up the last pieces on this project.
NOTE: If you plan on using any tool for a project please make sure you are familiar with the tool and all of the dangers associated with it. If you are not familiar with a tool then you should ask someone who is to show you the proper way to use it. A lot of communities have classes at local colleges on the proper use of tools and machinery. There are also local woodworking clubs that offer classes at very reasonable rates for beginners. I highly recommend using these resources for your safety and for the most efficient use of the tool.
SAFETY FIRST
Always wear eye and hearing protection.
Always work safe with the proper safety equipment and guards on your tools.
1-40 of 51Next »
redpepper237 says: Dec 1, 2012. 8:42 PM
when I was 5 I loved theese things!
ride on toy dude says: Mar 21, 2012. 11:24 AM
I have 5 siblings, all of them younger, so this would be a great project as a present or something...
Petar92 says: Nov 15, 2011. 11:35 AM
This is great!! Wonderful idea and project...I see this kind of things in public places... Great work!!
stevemoseley (author) in reply to Petar92Nov 15, 2011. 8:16 PM
Thanks. I appreciate the comment.
DELETED_explosionist says: Jan 28, 2011. 12:44 PM
(removed by author or community request)
stevemoseley (author) in reply to DELETED_explosionistJan 29, 2011. 7:11 AM
Thanks for your comments. Some people have told me I should build one of these large enough for a full grown adult. It's tempting . . . .
stevemoseley (author) says: Jan 19, 2011. 5:13 AM
A 29 page PDF plan set and materials list that you can print are now available on my web site for the Kid Crane. Some parts are to scale to use as a template.
http://www.buildandcreate.com/
Let me know if you have any questions.
Steve
kazlak5000 says: Jan 3, 2011. 1:46 PM
this very good instructable this very good instructable this very good instructable .......
derte84 says: Dec 23, 2010. 2:57 AM
You should write books!
jwolski says: Dec 21, 2010. 7:01 PM
I remember seeing these plans for sale online a few years ago. I'm glad they're free now!
jwolski in reply to jwolskiDec 21, 2010. 7:07 PM
Yep, found it! http://lumberjocks.com/projects/11180
montana.christopher says: Dec 21, 2010. 6:22 AM
Wonderful!!! I think youhave made a great project. I am going to send this on to my Pop who would love to build this for his grand children. My only thoughtbecause im a big mature kid is a pedal gear with some type of movement on the ground. I would say that would be off the charts. Great Great Great stuff thanks
EmmettO says: Dec 16, 2010. 5:09 AM
I get the impression that you've worked with plywood construction before! If not, you strike me as a machinist. What program did you use to make the plans for this?
stevemoseley (author) in reply to EmmettODec 16, 2010. 5:30 AM
In answer to your questions:
I've worked with plywood a bit.
I'm a civil engineer by day and like mixing the wood and metal parts.
Autocad was used for the plans originally.
western in reply to stevemoseleyDec 19, 2010. 9:24 PM
Leave it to an engineer to go this far for a toy. :)
Fantastic crane and excellent instructable.
Who had more fun, the boys with the crane or you dreaming it up and making it?
stevemoseley (author) in reply to westernDec 20, 2010. 8:55 AM
Let's say we all had fun with this one.
Most adults have to sit down on the crane and try it out the first time they see it.
sikamikan says: Dec 20, 2010. 4:36 AM
wonderful instructable
torino6669 says: Dec 20, 2010. 4:20 AM
This is totally awsome!!! I'm going to have to make one for my Great Niece. She may be a girl, but she's a boy @ heart. (GRIN) I'm not an engineer, however my Dad is a retired Electrical Engineer. I say that only because of my experience in dealing with my Dad, I can see your engineering skills come through when you wrote this instructable. Very concise, informative & well written. It's just totally fantastic & will be a great help when my Dad & I build this for my Great Niece. (HUGE GRIN) Thanks for the structable & Merry Christmas
WingDings says: Dec 20, 2010. 3:12 AM
This is a beautiful thing, and well presented. Excellent work.
skiedra says: Dec 19, 2010. 11:24 PM
This is a superb instructable! Thank you for sharing and keep 'em coming :)
uNiq1 says: Dec 19, 2010. 9:40 AM
How much did this whole project cost. or how much would it cost for someone who doesn't have any tools/wood/experience? I've been looking for something to do over the summer!
stevemoseley (author) in reply to uNiq1Dec 19, 2010. 7:24 PM
I think you could build one for under $200 (US). It depends on where you get your parts and what you would need to have shipped. Most people taking on a project like this would probably have some of the parts themselves.
eligriggs says: Dec 19, 2010. 11:38 AM
Excellent work, thanks for sharing.
Can you take your crane a step further by building a low to the floor, two-section 'ring' to fit around the crane platform, with marked positions for geometric shapes that could receive matching building blocks? Then the child could have games that would have him moving and placing the blocks by size, colour, number, symbol or alphabet, all around his crane.
If you inset pairs of rare earth magnets in the bottoms of the blocks and the matching block places, the blocks should self align as they are lowered the last few inches. Slightly smaller, bottomless blocks, to allow for the needed top rings for the hook, could also be made for stacking, adding another dimension to the games.
You can also add a sliding, notched 'push/pull stick' to the right side, that would allow him/her to simply push the cable out, from a few inches to about a foot, so the cutouts could be staggered, making it more challenging to pick-up and place the 'building blocks'. You can allow for the pulling in of the cable a few inches as well.
By building the block ring in two sections, storage is made easy, simply place the top sides together and let a few magnets inset for this purpose, hold it together. A cutout handle should be included.
stevemoseley (author) in reply to eligriggsDec 19, 2010. 7:22 PM
That is a great idea.I will have to look into that after the holidays and explore that expansion of the crane. Thanks for the detailed explanation.
janettetsmith says: Dec 19, 2010. 4:26 PM
Cool.  What a wonderful thing to make for your son, heck, I'd find a reason to use at my age.
old_code says: Dec 19, 2010. 3:30 PM
It's obvious that you've taken a great deal of time to prepare this Instructable; detailed parts list (with contact numbers, too), clear photos, clear diagrams, thorough instructions.
This looks like a heck of a lot of fun too! And truly an heirloom.
Thanks.
handprints says: Dec 19, 2010. 1:27 PM
What a great piece of work! I love it.
sniffydogs says: Dec 19, 2010. 12:14 PM
WOW! Extremely well-made! Your grandkids could easily enjoy this some day. It would also stand up to heavy use in a day care, plus it looks very safe.
niv_pei says: Dec 19, 2010. 11:57 AM
this was one of my dreams as a child
rogercaplan says: Dec 19, 2010. 9:45 AM
that is awesome - I remember also being obsessed with cranes at some point as a child, I would have loved this...
Foxtrot70 says: Dec 18, 2010. 4:58 PM
Hey Excellent Carpentry!!! The kids will love this one; the most important accessory...have you made a wrecking ball for it? Probably a modified bowling ball would do the trick. Remember what Red Green says, " If its not broke... your not trying hard enough!" Hey just trying to help... us guys gotta stick together, no matter the age. :)
michaelgohjs in reply to Foxtrot70Dec 19, 2010. 8:07 AM
a wrecking ball would be great..but then..safety first..
psst..add a shield
michaelgohjs says: Dec 17, 2010. 9:15 PM
looks very very professional
is it very heavy? would putting it on a mobile platform be practical?
stevemoseley (author) in reply to michaelgohjsDec 18, 2010. 4:58 AM
Thanks for the kind words.
It is pretty heavy which makes it nice and stable. I don't think it would be as stable if it was on a mobile platform. It slides around very easy on carpet so it isn't hard to move around.
michaelgohjs in reply to stevemoseleyDec 19, 2010. 8:06 AM
Oh...ok
but i am sure looking at your son have fun with it pretty much eliminates the need for it to do any practical work
brocks411 says: Dec 18, 2010. 9:14 AM
Wow very nice! I had one very similar to this when I was a kid and loved it. Mind you, it did clutter up my room for many years afterwards!
tornadoboy says: Dec 18, 2010. 5:45 AM
Awesome work! I you could rig up a working claw instead of the hook on the end that would be awesome too!
stevemoseley (author) in reply to tornadoboyDec 18, 2010. 5:55 AM
That's a great idea. I had thought about making a small electromagnet to hang from the hook with a battery pack in the seat compartment.
captain Jack says: Dec 17, 2010. 9:31 AM
absolutely gorgeous woodwork!
Mike73 says: Dec 16, 2010. 10:37 PM
That is so awesome. I wish I would have had something like this when I was little :-)
1-40 of 51Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
