KidWash: PVC Sprinkler Water Toy
Make a fun summer sprinkler toy from PVC to help the kids beat the heat.
total cost: $9.51
total time: about 1 hour
Step 1Go shopping
Go shopping
Head to your local hardware store and pick up:
2 ten foot lengths of PVC. (I used 3/4" but feel free to use other sizes, just be sure your fittings are the same dimension)
3 end caps
1 threaded hose connector
2 elbow joints (90 degree)
2 T connections
PVC Cement (I skipped on the primer, use this if you want)
32 comments
Aug 18, 2006. 4:05 PMBoss_Sauce says:
i use a pipe cutter on pvc-- always a straight cut, no "dust" or cut fingers-- like this one:
http://centralonlinesales.com/show_Product.asp?ID=599
Aug 20, 2010. 7:33 AMmce128 says:
Or you could use one of these since it's PVC.... http://centralonlinesales.com/show_Product.asp?ID=360 and save $10 and have something that's awesome for any kind of hosing as well.
Aug 8, 2010. 7:51 AMdublinsmaster says:
We made it, here in canada it cost about $40 bucks. but the kids love it just the same :)
Jul 10, 2010. 11:36 AMchs247 says:
I made a nice wide and tall one, and my kids love it. I painted mine purple as my daughters ask, it looks great. Thanks for the idea. Great job. In fact half of the guys in work want one for there kids.
Jun 23, 2010. 1:39 PMranex says:
my idea would be to make a stand but has T connectors that are big enough to had the full crossbar to go through, that way you can just make a bar that holds the water and the rest is empty, you could also make it so the kids could use it like a limo stick as previously mentioned
Jun 21, 2010. 9:52 AMballoondoggle says:
I made this last summer and the kids loved it - thanks a lot for the instructions! A drawback to the design, however, is that it is nearly impossible to drain the water out at the end of the summer. Due to the size and shape, it lived on our deck over the winter where that trapped water froze and destroyed one side. In making repairs, I added a threaded plug on the leg opposite the quick disconnect. Now I can drain water from one side through the connected hose and from the other through the threaded plug. My sister has asked me to make one for her daughter and as they have less storage space than I do I'll look at using all threaded connectors so that they can break down the unit and stand it in the corner of a utility closet.
Jun 19, 2010. 8:05 AMburningsuntech says:
Absolute genius! Us desert rats could use a cool water toy and this one looks super. Nice job on the instructable. Well documented. RA
Oct 8, 2009. 7:14 AMgvince4 says:
Thanks for this Instructable I made one this summer for my son he thinks it's great!  I put side holes at an angle and the whole thing worked well. To drill the holes I used my drill press and the smallest bit I could find I used glue on all but one  joint so I could put it away for the winter. Thanks!
"G"
Jul 12, 2009. 2:53 PMcpns72 says:
Perfect to make "rain" for my pond to listen and watch rain right in my yard. Love all those ideas/tips. Will post it with pixies later. Thank you.
Dec 27, 2007. 2:45 PMLoveMyPadres says:
Wait a minute...you can run water in PVC pipes? I'm not sure I've ever used it for that purpose before....huh.... Looks like a lot of fun, have to make one next summer!
Jun 30, 2009. 4:44 PMtannerr52 says:
i hope you were being sarcastic
Jun 15, 2009. 10:51 PMtoogers says:
that is the original purpose, it's for plumbing. if you could see through walls, that's one thing you would see. not to sound rude.
Apr 3, 2008. 9:10 AMGranny_Leah says:
I wonder if this would be strong enough for hanging tomato plants... Maybe with larger diameter pipes? I hate watering hanging plants.
May 22, 2008. 2:05 PMpicbuck says:
It probably will be if you don't use too long a piece of pipe. You'd want to use "Schedule 40" PVC pipe. "Schedule" refers to the wall thickness of the pipe. Schedule 40 is the white, thick walled kind in the plumbing department. Home Ripoff sells it, as do most hardware stores. Not the thin-wall PVC pipe, that's sold for irrigation (lawn watering) systems. Schedule 40 is for drainage, you probably have it in your house. It's easily cut by hand. You'd want a coarse (not fine) blade in a hacksaw, or a regular wood saw also works well--if sharp. But 3/4" is not rigid enough to support a load. You'd want 1-1/2" or 2". Or if you could go to the 3" or 4" sizes you're getting some pretty strong stuff. Though still not as rigid as galvanized pipe, into which you could also drill holes. And 3/4" galvanized pipe is really, really strong.
Aug 3, 2008. 10:44 AMDerin says:
there is also schedule 80
Jun 15, 2009. 10:49 PMtoogers says:
and don't forget schedule 120.
Jul 30, 2008. 3:26 AMsuperhands says:
Made on last night, worked REALLY well, I bought some cement but didn't use it - pressure was not enough to cause leaks. BTW for UK folks, I used overflow pipe from the DIY centre - its a little thin but is only £1.99 per length - I bought 3 plus a threaded elbow joint for a toilet overflow that has exactly the right thread for a hose spiggot. I couldnt find a 3/4 (22mm) end cap anywhere, so I used some thick plastic wrapped over the end and secured with Jubilee/Hose clips.
Jun 7, 2007. 8:33 PMlostinthesparks says:
what would you do if you wanted to make the pole like limbo and go up and down but still have water coming out ??????
Feb 28, 2008. 3:51 PMfizil says:
i would say just do a system that's an end cap, rain pipe, and hose connector. Then use what they use to hold limbo up.
Jul 22, 2007. 11:39 PMbikeparts24 says:
Made one of these and it worked great. I put a ball valve on the side where the hose is not. When I put it away, I just un-hook the hose, open the valve and tip it back.
Jun 10, 2007. 9:03 PMdchall8 says:
I made a dog wash just like this except shorter. It doesn't work the get the dog wet underneath, so I'm working on something else. Instructable is in development.
Aug 19, 2006. 7:42 PMdandersn2000 says:
I built one today and had a BLAST with my kids. It cost $2.48. We put a fischer price slide undertneath it to ende the afternoon. So much fun. I was thinking about drilling holes in the uprights, both inside and outside to make even more spray. GREAT IDEA.
Aug 21, 2006. 12:47 PMimpulse94 says:
I like that one. Kind of a different take on the shower spa I made from PVC pipe (an Instructable). This one gives me lots of ideas!
Aug 20, 2006. 11:46 AMjquinby says:
Many thanks for posting this. The whole thing went together in about 30 minutes. I'll be making another one when we visit some relatives next week. Our three-year-old loves it!
Aug 18, 2006. 11:13 AMTheThompsonFive says:
Nice! I bet you could get away without glueing the whole thing up, which would make it a lot easier to put away in the wintertime.
Aug 19, 2006. 6:51 AMegilwh says:
With water under pressure, you'll need to fix the joints somehow... but I agree. If you could use screwed joints, it would be possible to disassemble.
Aug 18, 2006. 5:11 AMducajjang says:
That's cool! And I guess, how about make an addition to side hole? I just create an account right now.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:discontinuity
