Kidney Stone Paperweight
CraftArt by
688
4
7
Posted
Introduction: Kidney Stone Paperweight
I’m going to be walking you through the steps to make your very own kidney stone paperweight. I made this one for my dad for Christmas because I know how much he loves kidney stones!
Step 1: Create a Kidney Stone
I made this stone with my right kidney, but you could use your left one if you like. Now, you want the stone to be large enough that it’s easy to see but small enough that it doesn’t cause you crippling pain on its way out. I nailed the former but overshot it on the latter. Oops!
Step 2: Encase the Stone in Resin
I used this “crystal clear” epoxy resin, although I learned after the fact that it only stays clear if you pour it in increments of less than a quarter inch. I did the entire thing in two one-inch pours, and the heat generated by the curing process discolored the resin, turning it yellow. Oops!
You should use a mold that is made for casting resin so that you can easily remove the block once it’s done curing. This mold was supposedly ok to use with resin, which I guess it was. It just wasn’t reusable with resin. Oops!
Step 3: Create the Initial Kidney Shape
Now that you have easily removed your crystal clear block of resin from the mold, cut it into a projection of a 2-dimensional kidney shape. I used my bandsaw for this step.
Step 4: Kidney Edges
Then, trim off the edges at about a 45º angle, bringing it closer to a 3-D representation of a kidney.
Be careful to prevent the warm resin shavings from sticking to your bandsaw bearings and hardening in place, or your saw might not want to start the next time you use it. Oops!
Step 5: Sand Your Kidney
Begin sanding the resin, first removing any saw marks, and then removing all of the scratches from the previous grit level. I sanded mine with 80, 120, 200, 600, 1000, and 2000 grit paper.
Step 6: Polish Your Kidney
Once you’ve exhausted your sandpaper options, switch to rubbing compound. I used these polishing wheels by chucking them into my drill press.
Step 7: Make Your Kidney Shine
After polishing the entire paperweight with rubbing compound, it should look something like this.
Now you can move on to polishing compound. This will give your kidney a glossy shine, and if you neglected to get all the bubbles out when you poured, your stone will appear to be floating in a sea of resiny stars.
Step 8: Admire Your Kidney Stone Paperweight
And that’s it! Now every time you use your paperweight, you’ll remember all of the fun times you and your stone shared together.
That paper’s not going anywhere. Thanks, kidney stone!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    6 Comments
    AAAARRRRRRGGGGGGGGHHHHHHHHH!!!!!!!!! THIS brought back painful memories! I already got one - and, thank God, it's MUCH smaller... =(
    I...... Love........This
    I love the amount of 'oops' in your instructable. That pretty much sums up my making style. :) Welcome to the community!
    Uhh, I guess i can miss out on those fun times. On the other side this has to be one of the most personal gifts ever. You can proudly claim "I made this!". Reminds me a bit of this comic: https://i.imgur.com/7UREjKh.png
    Oh, and welcome to instructables :D
    Haha, I hadn't seen that comic before. Poor little gall bladder. :-)
    That's a pretty paperweight :) That was a neat gift idea!
