Kids Car Racetrack With Easy Wireless Timer Display
1,447
27
4
Published
Introduction: Kids Car Racetrack With Easy Wireless Timer Display
There are many projects out there for showing how to time cars going down various tracks...from Pinewood Derby to Hot Wheels. When my friend Dan decided to build a track and asked me if I could come up with a timer system, I found everything from professional systems to hobbyist ones, but they all had something that felt complicated. I wanted to come up with a system that was simple for others to make, inexpensive, flexible, and that would have an external display such as a television or tablet. From Dan's side, he didn't want to just build a track..he needed something that his kids could put away, which didn't take up a ton of room, and which could use anything from pinewood derby cars to custom lego cars. Together, in the end we came up with an addictively fun project which we'd like to share with the community, especially scout troops or others who would like their kids to build timers for their pinewood derby setups vs. purchasing a system.
In this instructable I will focus on the timer portion, though I'll note some of the design choices made for the track which made that portion special (such as being able to disassemble it) as well as how it affected the electronics decisions. I believe there are many tutorials out there for how to build the tracks themselves, so I want to focus on the timer.
This project has the following features:
  • The Track design is modular, in that it can be disassembled or reassembled with ease, and by kids.
  • Pinewood derby, Lego cars (which are amazingly fun!) as well as Hot Wheel cars all work
  • There are no wires running from the track. No need for a laptop plugged into the Arduino or anything like that. It's powered off of a simple USB power brick, like you'd use to charge a cell phone on the go. This is a game changer when kids can run back and forth, and around the track, without any tripping hazards
  • The time display can be shown on anything that can browse the web. We've had the display up on everything from a cell phone to a large screen smart TV (Which had an internet browser built in)
Ok, so in summary, how was this done? An ESP8266, break beam sensors, and a button. Which takes us to the next section...
(Update: Video added to show the project end to end! Second video coming soon of a verbal code walkthrough :))
Step 1: Parts List for the Timer
  • Adafruit Break Beam sensors (https://www.adafruit.com/product/216) - These come in pairs...a sender and receiver. You'll want a pair per lane you're planning on using.
  • Adafruit Feather Huzzah - (https://www.adafruit.com/product/2821) - If you're comfortable with an 8266 you can do this even cheaper, but the Feather Huzzah makes this drop dead simple to setup
  • Tactile switch / button - Just about anything will do here. This is how you 'start' the race
  • 22 gauge hook up wire (I recommend 2 strands/colors the length of the track you're building, plus about 4 feet for some extra wiring which is needed. We had a 10 foot track, and I bought 25 foot rolls of red, black, and green...I probably have half a roll each left.
  • Glue gun or epoxy to hold the sensors in place
  • Cell phone power bank - You should be able to get a small cheap one at a local store for under 10 dollars. If you prefer online, this one is way overkill but not a bad price: (http://a.co/i6D43m9). You just want a way to power the feather huzzah, and it really doesn't take much draw. Note: You can also use a JST connector battery such as a https://www.adafruit.com/product/2011...this would save you some space, but it's in exchange of battery life and price.
  • A micro USB cable to USB (you use this for the Feather Huzzah programming and from the power bank)
Step 2: Theory, and How It Works
Before I dive into the wiring, I want to discuss how it works, so that when you're hooking up things, you'll know how they fit in (and if you have better ideas or need to adjust it, you'll know now before you've soldered stuff :) )
The ESP8266 is the 'brain' of this...it'll run the program and look for 2 separate input sources...the start gate, and the end sensors on each lane. When the start gate hits the button, it starts a global timer...as each end gate gets tripped, the current value of the timer gets saved off for that lane.
One thing that becomes apparent when playing with these...is that some cars do not every finish. Or sometimes someone may want to run one lane...and not have cars on the other. To handle both of these scenarios, there is a timeout that is set to longer than any race should take. That way, if the overall timer hits that timeout, we can mark any cars that didn't finish as DNF (did not finish) and be ready to go for the next race.
The ESP8266 serves up an HTML page which it substitutes in values from the timer/sensors as they come in. This is great because it allows a tinkerer to change the colors, display, text, and other options very quickly and easily. Because it's just HTML, you can make a very dynamic and graphical display if you'd like!
Next up we'll look at wiring...
Step 3: Wiring
Good news...it's really straightforward to wire up these sensors...and we only need to wire up a single button!
Before wiring up the sensors, find the ones with only two wires. These are the 'senders' and only require power to activate. The others, with three wires, are receivers...they have two power wires and a sensor wire. See the image above for the overall idea on how these get wired in.
What you'll want to do is mount all of the senders (2 wires) under the track, facing upwards. Drill a small hole through the track, then from below, using a spade bit slightly wider than the sensor, drill out a space for the sensor to mount, with the led portion facing upwards through the hole. Hold it there with something temporary...double stick tape for instance.
From the top of the track, the portion that goes 'over' it, you'll want to drill holes facing downwards, and place the matching sensor facing downwards. This is the portion of the sensor with three wires.
For both the upwards facing, and downwards facing sensors...connect all of the Red and black wires together. These are your power wires, and you'll want them run into your Arduino for power. The third wires on the top should all run to separate Arduino pins...I recommend using pins 12, 13, and 14 on the Huzzah Feather.
Place a button on your starting gate such that when the gate opens, but button gets hit. This will depend on your starting gate setup...for us we had a dowel we turned, so we added a piece of wood into that dowel that would hit the sensor when the gate was down. The main thing is when the gates open...the button needs to get hit. Since the start of the track is on the other end from the sensors you just mounted, you'll want to run two wires from the start button, down the sides or under the track, to the bottom.
Protip: For Dan's track, it separated into three pieces for ease of storage. But this meant that the wiring had to separate as well. Using Molex connectors here will allow you to unplug the wires if your track needs to be taken apart for storage.
The picture shows a small mini breadboard...if you're not great with connecting wires, I recommend using one of these to get the circuits going and tested. Long term you'll want to either epoxy the wires in to keep them there, or solder/heatshrink the wires together.
Next lets look at code...
Step 4: The Code...
The codes attached here. All configurations were moved to the top so that it's easy to edit, but here I'll go over them:
<p>#define LANE1PIN 12<br>#define LANE2PIN 13
#define LANE3PIN 14
#define STARTBUTTONPIN 5
#define MAXRACETIMESECONDS 7000  //maximum time a race may take in seconds before timing out
const byte        DNS_PORT = 53;          // Capture DNS requests on port 53
IPAddress         apIP(10, 10, 10, 10);   // Private network for server
DNSServer         dnsServer;              // Create the DNS object
ESP8266WebServer  webServer(80);          // HTTP server
int mode = 0; // 0 Ready 1 Started 2 Ended 3 Error</p><p>int sensorState = 0, lastState=0, StartButtonState = 0;
int NUMRACERS = 3;</p>
In the code, the lane pins are the pins that the sensors are hooked up to. You can change this, but please be careful and understand the pins on the Huzzah that are special. For instance, pin 2 and pin 0 have special behaviors when pulled high. If you're not familiar with Arduinos, then please stay with the recommended ones, upload the code, and you should have a working setup 'out of the box'.
The Maxracetimeseconds is the timeout value in milliseconds (so 7000 is 7 seconds). Most races on our track took under 6 seconds (most were under 2 even!) so 7 seconds seemed like a good number. You may want to adjust that part.
The apIP(10,10,10,10) is the IP address of the display. This means if you navigate a browser to http://10.10.10.10 while connected to the tracks wifi, you'll get the display. I chose that IP because it was easy to use and remember, but you may want to choose another.
Next we have the wifi config:
<p>// Wifi Config<br>  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
  WiFi.softAP("Layton Lanes");	</p><p>
The softAP is the access point name...this is what shows up when people try to connect to the lanes via Wifi.  You'll want to name this something personalized for your race track!
Next we'll look at the output, and how to truly personalize this...</p>
Step 5: The Website...
In the code you'll see the line:
String responseHTML = ""
This starts the HTML portion of the display, and you should edit this how you see fit. This will let you customize the colors used on the display, the text to change it to your name, and gives you an area for a small fun quote. That being said, you should feel free to go wild on this! You can add whatever text you want, names of racers or family members, or whatever you'd like! This was customized for Dan's favorite team, the Miami Dolphins.
Two tips here..
If you want to do something similar and match the colors to a favorite sports team, this site can give you the HTML color codes: https://teamcolorcodes.com/
If you want to add an image...well there's no file system, so you have to use an image source which is base64 encoded. This site will help you with that: https://www.base64-image.de/
I think that one of the most fun parts of this project, besides it being wireless, is that the display can be totally customized! The default layout is shown in the image above.
Note: The webpage has debug text at the bottom...this should allow you to quickly test the lanes (place a hand under each one to see the numbers change) and lets you know, as an operator, what is going on. You can also remove this if you'd like to clean up the output, but we've found it incredibly helpful sometimes.
Step 6: Usage!
Ok, finally, how the heck does this work, and how do we use it!?
Very simply:
  1. From a device which can connect to wireless, look for your access point (Layton Lanes if you didn't change the name)
  2. Connect to that access point, and then navigate to http://10.10.10.10
That's..it. You should see the three lanes with dashes to indicate the race hasn't started. When you hit the button, you should see the timers going as the page auto refreshes. When each lane gets 'tripped' by a car, the timer will stop and time will be recored. when all three are done (or it times out!) you'll see the final race results.
You can use a phone, a tablet, a smart TV, a computer...anything with a browser that can connect to wifi can connect to the race track! You can even do things like connect a cell phone to it, and then use the wireless display from the phone to a TV (Miracast or airplay). This works with iphones, ipads, android tablets, windows devices...heck even a raspberry pi could be used if you wanted!
Troubleshooting:
1) The first thing I check is the sensors...make sure that they're pointing at each other correctly, and that they register a '1' in the debug spew on the screen you're displaying on. If so, put a hand in the beam and make sure they switch readings to a '0'.
2) If you're having problems connecting, try unplugging power and replugging it in to reset the 8266. I've had this happen once in 10 hours of use, and I THINK I fixed the issue, but it's so tough to reproduce it's hard to say
3) If you can't see the access point, please make sure the chip has power. If you changed pins...make sure you're not using 2 or 0, as these may hold the Arduino in an off state.
4) Post in the comments if you're still stuck and I'll help where I can.
Step 7: Future Ideas / Advanced Stuff
For those comfortable with Arduinos, here's some easy mods that could be done that I just haven't gotten to yet:
  1. Add in neopixels above the lanes...you could use blue/red/white like ribbons to indicate who came in first/second/third if you want to bypass the display portion
  2. Use a servo or other method to start the race automatically...our design depended on hand turning the start, but this easily could've been a servo. you'd use the web page to then start the race, which would make the entire system tablet activated
  3. You could get fancier with the website if you wished, adding animations possibly
  4. The speed timer I use is an average over the whole course, you could use a point to point measurement for speeds
  5. You could use break beam sensors at the start as well as the end...then do auto configuration of the UI based on how many racers are there
  6. The quickest time of the night would be a good thing to track and keep. I may add this soon myself, as we found ourselves racing for hours trying to beat the quickest time vs. caring about 1:1 type races.
  • Make it Move Contest
  • Clocks Contest
    Clocks Contest
The easiest way i found to do this project, is to sucker a buddy (who is way smarter than you) to do the tech stuff. It's a piece of cake to do the rest!
One the track side, I used pine because it's both light and relatively inexpensive. As Joe said, I wanted this to be easy to set up and take down.
I bought a 12' plank and ripped it into 3 sections with a skill saw and guide.
I made the molding and lane dividers out of a 2x4 on my router table, but that can be purchased if got prefer.
Then came the sanding. There was sanding. There was a lot of sanding. I'm not sure if I'm done sanding yet.
I glued and all the track pieces before using my bread nailer to put them in place.
I chose 3 lanes, simply because on the 12' plank, that would allow for (nearly, not counting the width of your dividers) 3, 4" wide cars, which I figured would be fun for the Lego cars.
I made dowels out of a steel rod (for durability) which I then used to join the individual pieces of track. Each piece is connected on the underside by latches, that pull the pieces together as they're latched (like a dining room table uses with the leaves. )
All the wires and components are hidden underneath or in the box at the finish line. The box has a kid that closes with a piano hinge.
Then Joe came over and we wired everything up. Awesome project, and a lot of fun for the kids.
4 Comments
Thankyou! I’m working on an update tonight to add a video of it “end to end”. Just need to get where I can upload it :)
Awesome, I look forward to seeing it. I was wondering if there could be a way you could store the quickest time, "high score" if you like. I guess that would involve storing a small piece of retrievable data between power on/off. Slightly more complicated I guess, but would be cool. You could probably do it with a micro SD card module, I've used one like this before was fairly easy to setup:
https://www.ebay.co.uk/i/391599342582?chn=ps&adgroupid=49962971442&rlsatarget=pla-380395540450&abcId=1129946&adtype=pla&merchantid=10120294&poi=&googleloc=9046888&device=c&campaignid=974960578&crdt=0
Yeah, we actually talked about adding a high score section, and it's on my 'todo' list :) We were just wanting one for the session, but to persist it there is a way using the EEPROM (You can store a very small amount of data in it, but a high score and a name should be perfect). Here's an example from GitHub:
https://github.com/esp8266/Arduino/blob/342c4ae6fb847bfc787f80b89a2bb888d942dc32/libraries/DNSServer/examples/CaptivePortalAdvanced/credentials.ino
If you add the microSD card, then one thing I think would be really sick is to be able to store web pages onto it. This whole setup serves a website, but to do images I had to use base64 encoding, so the website couldn't be as fancy as I may have wanted. With a microSD card that MAY open up a lot of possibilities! Also a high score table with a name entry should be possible as well. This project really could be modded in so many different directions...race heats, bracketing for tournaments, etc.
I got a sizzle video up, with a second uploading, but it won't finish for a few more hours. But I tried to make the one I upped fun :)
