Step 6Set in Sleeves
- Pin the sleeve into the armhole. If you're using fabric with a "right" and "wrong" side, make sure you're pinning the wrong sides together, so when you pull the seam open, the pretty side will be on top.
- Place your pins well away from the edge if you intend to serge the seam with the pins still in. You want to make sure they're far away from that cutting blade! Alternatively, you can just pop the pins out before they get to the needles, but don't overlook any!
- Repeat the steps from before to finish the seams.
- Now do it again with your other sleeve!
Add Comment
