3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kid's Stormtrooper Costume
Kid\
This is my cheap attempt at stormtrooper costumes for my 4 and 6 year olds. It's made to be lightweight and flexible for comfort but still hold true to the movie armor and look cooler than the store-bought stuff out there. Because of the materials used, these costumes won't hold up to rough play or prolonged wear. Actually, they got pretty beat up after simply trick or treating. Within the steps I'll tell you how I did certain things and what I would do differently. My son's costume was my first attempt and spent about 18 hours on it, not including drying time for paint and glue. My daughter's costume took less time because I based it on my son's templates just smaller and I gave it a little less detail (and I was less careful with cutting and glueing). Anyway, hope you find the instructions helpful. The result was a ton of fun and the kids got a lot of attention. Cheers
Step 1Materials
Materials
 I used foam sheets from Michaels. The larger costume for my 6 year old to 9 of the 12" x 18" sheets. He's 50" tall and weighs 50 lbs. I used a combination of a glue called Quick Grip (which held very well and stayed flexible but is messy and needs to dry overnight) and hot glue (for adding some of the detail work.) By the time I got to my daughter's costume I got a little impatient and used the hot glue for most of the glueing. I worked ok as long as you are quick with getting the pieces together quickly. But it does deform the foam a little and it is not flexible. You're also gonna need a couple of packages of white velcro strips (18" in length). And you'll need a length of 1" wide black elastic for the upper arm pieces - both for a strap around the arm and to attach them to the shoulder straps. I also used some to hold the thigh pieces up - one end hot glued to the thigh piece and the other has a velcro piece that attaches behind the belt.
57 comments
1-40 of 57next »
Oct 31, 2011. 9:22 AMgigibugs says:
THANK YOU for this- I followed these instructions fairly closely and made my 3- year old an awesome costume this year. Looks great! I did have to modify a few things simply because he is three. I made the helmet and he won't wear it (bummer) so I ripped it back apart and he's better with just the mask.
Thanks again! Will add images soon!
Sep 15, 2011. 4:19 PMcpalmer3 says:
I had the same idea! I wanted to use craft foam to make the armor for my boyfriend's stormtrooper costume, but I didn't know how well it would work. Now I have a guide to help me along! Thanks for sharing!
Sep 12, 2010. 2:23 PMMagicScarf says:
would you be able to tell me what website you bought an astronaut helmet from? so this isn't a motorcycle helmet but a real helmet an astronaut would use in space? i was really surprised to hear you bought it for under 10 dollars....i thought something like that would be worth a fortune...
i don't have much money this year for a costume and really want to try making this stormtrooper costume for myself. i'm an adult but i think by following your instructions i'll be able to figure out something that will have an impressive result.
please let me know where you got the astronaut helmet? : )
the costumes you made your children are fantastic. :)
Aug 8, 2011. 1:54 PMgrey_starr says:
http://www.birthdayinabox.com/party-supplies/productdetail.asp?prodsku=11867&SSAID=91948
Oct 12, 2010. 5:33 PMTheInventor1997 says:
probably a costume helmet, looks fake, no seals fake, ya fake
Sep 21, 2010. 11:18 PMExtinct says:
Haha I thought that about the astronaut helmet too when I read it. But I think she bought a Halloween astronaut helmet. (not appropriate for outer-space use)
Jun 9, 2011. 12:20 AMhalo 3 says:
I am such a stormtrooper fan!
Apr 25, 2011. 6:34 AMCluainnFhada says:
I thought that this'd take ages and be super expensive... you certainly proved me wrong.
Nov 17, 2010. 2:41 PMmcneilre says:
Did you say you made that out of fun foam!!??!! That's beyond amazing!!!
Oct 28, 2010. 7:52 AMkenbob says:
Brilliant!
Oct 23, 2010. 1:28 PMbrodycyn says:
Im trying to make this costume now. Love what you have done. But you didn't lable the different patterns & I am having difficulty figuring out some of the pieces. (where do the go on the body) I need some help!
Oct 17, 2010. 9:10 PMScreamo says:
Pink ruinds it 5/5!
Oct 12, 2010. 6:26 PMMagicScarf says:
yeah i found the helmet, but it's only in kids size, it's a costume prop....nothing came close in adult size though.
Oct 12, 2010. 5:36 PMTheInventor1997 says:
not too acurate, i mean, where's the canister, the belt, the place where you put a thermal detonator
Sep 4, 2010. 11:21 AMjgderuvo says:
Aside from the pictures above (which work really well), did you by chance create templates? Can you post them? Great job.
Aug 22, 2010. 2:09 PMpofoke says:
How long did it take you from gathering all materials to completion? I'm going to attempt to put one together for my son for halloween this year, only as one of the clone troopers.
Feb 2, 2010. 9:52 AMdearfion says:
haha ..pretty cool ah..
Nov 8, 2009. 3:52 PMNaesDraw says:
Yeah, it seems like you could make any armor like this, I'll have to remember this. Props dude!
Jan 14, 2010. 12:17 PMNaesDraw says:
Other idea. I was messing around with foam, and was thinking of a way to make it holdup better. I don't know how effort-wise effective it would be, but a test piece of foam laminated with clear packing tape on both sides became tougher and shinier.
Dec 28, 2009. 9:08 PMsirtom68 says:
Thats just way 2 kool....i wannabe a storm trooper!!!
Dec 22, 2009. 7:23 AMblindskate says:
cool!
Nov 23, 2009. 8:03 AMSpeedmite says:
"Arnt you  little short to be a stormtrooper?" or somthing like that. =P
Great job!
Nov 12, 2009. 5:07 PMjenniferdowns says:
What an amazing Dad to do this for his kiddos.  They'll remember these always!! (especially if there is a scrapbook page dedicated to it!)
Nov 12, 2009. 12:36 PMsedica says:
holy crap! that is so clever and such a cool kids costume!
Nov 9, 2009. 4:56 PMSpycrab says:
sweet!!
may actually have to try this for next halloween, or the next con i go to >.>
may the force be with you
Nov 6, 2009. 8:24 PMKarroo Oakey says:
Great costume, Great effort, Superb result  - Great Dad!
Nov 6, 2009. 4:53 PMchwbcc says:
Very NICE!  I love the simplicity.  Very clean and of course everything looks great in PINK!
Nov 6, 2009. 2:33 PMphalanx447 says:
That is something to be proud of! Very nice work. And your kids will remember that for a long time to come, as well. You are definitely a cool dad. :)
Nov 1, 2009. 2:09 PMCasabamelon says:
"Aren't you a little short to be a Stormtrooper?"
Nov 5, 2009. 12:52 PMsoapbox derby car says:
you just made my day!
Nov 5, 2009. 7:26 AMljdarten says:
hehe
Nov 1, 2009. 9:01 PMcanida says:
:D
Nov 5, 2009. 12:18 PMVery Interesting says:
How cute is the pink? Barbie, eat your heart out.
Nov 5, 2009. 8:19 AMKryptoCleric says:
The Pink Heels rock!
Nov 5, 2009. 8:15 AMsammcj says:
 These are great!  Nice work!  Your kids must have been thrilled.  Obviously the costumes are far and above what you would buy at the store but better yet theres that added dimension of having a parent spend the time and effort to make their halloween so memorable.
Nov 5, 2009. 8:07 AMhugedom says:
They look awesome and the idea could be transferred to the clone troopers and many others.   Very sweet.
Nov 5, 2009. 7:06 AMteejayhanton says:
Fantastic work! So the bulk of the armor just literally wraps around and velcros on? Excellent. I'm going to apply this to Clone Trooper armor, since my son loves the clones.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:hirerob
