Step 3Mark pole, cut and drill
Mark a line where the bottom of the handle will sit on the pole (1" up from the green coupler), the hole to drill (1/2" up from the line closest to the green coupler), the line where you will cut the pole at (3 7/8" from the green coupler), as well as the notch that will be in the end. You should double check your handle measurements just in case mine were off. After marking the pole with all the measurements it should look something like the picture below.
It is pretty important that you try to make sure the markings are all at the top of the curve of the pole while it rests flat. If you don't line up the hole an notch the handle may not re-assemble correctly. Also, if it doesn't match the original placement the handle could be skewed and your kid will end up walking in circles, the cord will wrap around them like a python and, well, you know how that will end.....
Cut the pole with a hacksaw 3 7/8" from the green coupler. You should have a very short pole.
Drill the hole all the way through using a 5/16 drill bit.I started off by using a center punch to dent the pipe slightly and allow the drill bit to center in the hole. I also used a 3/16th bit first as starting with the large drill bit could lead to mistakes. Make sure you ream out the hole well as the handle is a tight fit and you will end up pounding it like I did and almost break it.
Last task is to cut the notch. Since you marked the notch before cutting and drilling you lessen the risk of making the notch on the wrong side, which is exactly what I did. I used a hacksaw to cut the notch but if you have tin snips that would probably be easier.
Add Comment
