Kilo-Lumen bike headlight
I started biking to work this summer and needed a good headlight and taillight. I didn't want to spend a lot, but I wanted extreme visibility. For about $150 I ended up with a headlight that puts out somewhere around 1200 lumens, and a really effective tail light. The power source is an 18 volt Ryobi power tool battery which is both easily replacable, and quickly charged.
Warning! This project is not a beginner's project. As such I'm not documenting it as such. This will be more of a guide and list of critical elements rather than a comprehensive How-To.
Step 1Design Choices, thermal considerations
The first step is to determine what you want/need for your bike light. Total light output and beam shape will determine the type, number, and configuration of LEDs needed. Additionally mounting, portability, weather resistance, and access to machine tools will weigh in.
I started out with the intention to build the brightest lights around for the purpose of being noticed. This means for the headlight over 1000 lumens (although there are a few 1000+ lumen bike headlights commercially available, they cost close to that amount in dollars).
I settled on using 6 Cree XR-E LEDs, which from the appropriate bin will put out in the range of 180 - 230 lumens each at a 1 amp drive level. (UPDATE: The new R2 bin XR-E LEDs put out up to 275 lumens) This gives me a headlight which (ignoring losses from the lenses) will put out between 1080 and 1380 lumens. A number of considerations have to be made when using an array of LEDs of this magnitude.
- At 1 amp, these LEDs will requrie about 22 watts of DC power, carefully regulated to avoid over current and overvoltage conditions.
- With the LEDs running somewhere under 50% efficiency, the array will dissipate somewhere between 10 and 15 watts of heat. This must be disposed of properly to keep the LEDs within their rated junction temperature limits.
- Having 6 emitters will allow customization of the beam pattern. Each LED will have its own lens. The end result is a superposition of narrow spots, medium spots, and wide angle oval. This ensures side visibility, while providing good, even lighting towards the path ahead.
- A suitable power source needs to be provided. The array is a series connected string of 6 LEDs, each with a Vf in the 3.7v range, meaning that a power source in the range of 15 to 25 volts is required (This is to keep the regulator from working too hard to boost or buck the native supply voltage.)
- With the weight of the 6 LEDs, a suitable heat spreader, and heat sinks the headlight is going to have a pretty decent mass and needs a solid, adjustable mount that allows for quick dismount when parking the bike outdoors.
- Brightness control is handy so that when you are riding towards oncoming cars you don't piss off drivers by blinding them. This light is so bright that in darkness it can be blindingly bright. A measure of caution and restraint is needed when using a light this bright.
77 comments
1-40 of 77next »
Mar 22, 2011. 9:17 AMReble_45 says:
Looks like the store you got the LED's from might be out of business.
Aug 29, 2010. 7:26 AMhogey74 says:
Great project. I'm a cyclist and I find the commercial BLTs etc are too bright when riding towards them. Much brighter than cars! I know they're great off-road but they're a bit antisocial on bike paths. I think dipping lights should be the next development, just as on cars. Maybe you have to go for reflectors and rear-pointing bulbs? I am going to give it a go.
Aug 6, 2010. 1:58 AMcrunchie1000 says:
i would like to make something like this for my motorbike, running it off the bikes battery. could it be done?? thanks crunchie
Jul 4, 2009. 12:03 PMKT Gadget says:
I just ordered my Cree leds for an old overhead projector I'm converting to video. Instead of the thermal epoxy, will regular thermal grease work if I used screws to hold the leds down? because I might use the leds for a different project later and be able to swap them out.
Jul 8, 2009. 10:00 PMKT Gadget says:
Alright, cool. Just got my lens, drivers and holders in the mail, just waiting for the LEDs now. And as for a power supply, would a laptop charger at 15V 4 Amps work ok even though its built for (either lithium or polymer) ion batteries? Because I have a couple lying around the house and there not being used since the laptops have been recycled.
Jul 8, 2009. 11:59 PMKT Gadget says:
I am only going to put around 5 LEDs, give or take an LED, for each of the 3 series I am making. I am going to use copper caps that match the diameter, or a bigger cap, and use aluminum soda cans to dissipate the heat more, if needed since I do not have access to a milling machine. If i need to, I will probably get 3 5W resistors (gotta determine the value again) to drop the voltage down to 12V. Other than that, i should be able to make the projector work once more, if not better than before.
Jul 9, 2009. 12:04 AMKT Gadget says:
Oh, these are the http://ledsupply.com/buckpuck.php which run at 1000ma output, and I got the ones that were prewired, but do not have a dimmer since i do not need it in this case.
May 14, 2009. 11:16 PMsensoryhouse says:
Nice, I used my Ryobi batteries all the time for projects - like this
Mar 18, 2009. 8:49 PMsangchinok says:
i'm just wondering... with a lot of 12V 1.0A 10W warm-white 600 lumens LED making it ways to international market from China, is it possible to imitate your rig and attach it to my motorcycle and replace its 12V 1.25A 25/35W halogen bulb? Or more importantly, are the figures advertised realistic? BTW, The stock headlight is not bright enough for cloudy dark night on dark street, and your creation seems marvelous...
Mar 20, 2009. 5:43 PMsangchinok says:
thanks for the vote of confidence but my main concern would be the ability of the battery and/or engine to keep up with the electrical requirements. Having no experience with electricity in practice (and i did flunk physics!), I'm afraid i might blow up the 12V 3Ah acid-lead battery! or stall the 110 c.c engine. About legality, over here in Malaysia, we don't have the luminence value of headlights written down, or what type of illumination we use for that matter, so that's not a big problem: unless it's HID/Xenon bulb in non-xenon/HID calibrated headlights which is illegal. So, I plan to fit the LED assembly into the stock headlight assembly, hoping it won't blind anybody... and make holes for some air. But the electrical supply issue bugs me. Big time.
Mar 23, 2009. 7:29 AMsangchinok says:
so, it's not gonna blow but i need clean voltage source... hm... this gonna be harder than i thought. (rub hands, giddy with excitement etc., etc., etc...) ;P
Mar 11, 2009. 2:19 AMmortso says:
Why didn't you use a "T" cutter end mill to cut your mounting slot?
Nov 26, 2008. 11:46 PMaburton says:
I'm sorry, but I'm not quite sure what you mean when you say "Bare aluminum is not as good a conductor as one might think." Do you think you could explain this a little further? As it is currently worded, this is a deeply misguided statement.
Nov 27, 2008. 6:36 AMroosta says:
this is because dark surfaces radiate heat far more effectively than a shiny surface. its stated in one of the laws of thermodynamics, but i hate physics, so im not going loking for it :P i cannot understand why people dont paint their radiators matt black. far more efficiant than white.
Mar 11, 2009. 2:17 AMmortso says:
So the inverse of Solar radiation is happening, where Black absorbs more solar heat than shiny or white surfaces. I never considered the reverse to be true, very cool thing to know. thanks!
Mar 11, 2009. 4:22 AMaburton says:
Right, but in this case it is not a strong mode of heat transfer. You're better off leaving the aluminum uncoated.
Nov 30, 2008. 9:36 PMtherian says:
how many car driver was blinded and killed ?
Dec 27, 2008. 12:19 PMEvil Bike says:
the world may never know...
Feb 18, 2009. 10:18 AMBeanGolem says:
And even if we did know... who says less car drivers is bad! haha. I jest...... maybe.
Feb 18, 2009. 3:50 PMEvil Bike says:
that inspires deep thought on my part...
Feb 18, 2009. 4:21 PMBeanGolem says:
On a related note, I was thinking of making a bike-mounted harpoon launcher.
Jan 31, 2009. 8:16 PMWhatnot says:
I don't think you need a stipulation in some local code to cover this, this just falls under the header 'reckless endangerment', and not just other people by the light but also yourself from the reaction people might show, there's a good change someone takes matter into their own hands without consulting brightness regulation websites and you should take that into consideration too.
Jan 29, 2009. 12:36 PMhg341 says:
overkill but well done(if only i had 150 dollers and a bike)
Why do you need this. the point is for people to SEE you, not be blinded by you...
Jan 27, 2009. 5:23 AMPyroMonger says:
yes but its also for them to see the road themselves....if there are no cars around then brightness can be increased so there is less strain on the eyes while riding
Dec 2, 2008. 2:30 PMgoodgnus says:
Congrats on the win!
Nov 24, 2008. 2:21 PMdrakedm says:
This is without question the king of all bike light builds. I have seen people use MORE lights, and even car headlamps, but this offers the bst of everything. I suspect that this light is actually illegally bright, which is about the best thing you can say about a home brew project. Cheers for over-engineering. Also, I'd love a tail light demo photo, akin to the head light demo photo, just for reference.
Nov 28, 2008. 7:11 AMMyself says:
Where would I get info about what constitutes "illegally bright"? I love this concept.
Nov 29, 2008. 11:58 PMdrakedm says:
Well, I worked for a scooter importer for a while, and there were a whole series of regulations covering every aspect of any vehicle allowed on public roads, I suspect this is a state-by-state issues, but I know there is a maximum allowable luminosity for car headlamps, and this bike light is decidedly above high intensity car headlamps. I would probably look at the NHSA (National Highway Safety Admin). or possibly to the NYSB (National Transportation Safety Board) for these regulations- I know they exist and they probably have to do with luminosity, color and height from the ground.
Nov 28, 2008. 11:51 AMYerboogieman says:
Cops get mad at my Cold cathodes, its funny.
Nov 29, 2008. 10:36 PMuberchoob says:
Any restrictions on the brightness of car headlights will be applicable to any vehicle that is road legal, including a bicycle. You might have gotten lucky with that cop, or he may have not considered it to be to bright, or maybe he was just to awed by the insane ingenuity of this instructable that he couldn't possibly ticket you!
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:kc6qhp
I'm an electrical engineer. By day I design chips, by night I like making stuff that is unnecessarily complex.
