Step 10Add the Buckles and Straps
For this kilt, I used 5/8" buckles, so I cut two strips of 5/8" x 3.5" leather to secure the buckles, and cut 2 5/8" x 8" strips for the straps.
For the buckle pieces, fold in half, round the open ends, and make 2 parallel 1/4" cuts into the fold. Unfold, and use small scissors (such as the thread scissors), or an x-acto knife to complete the half circles at the ends of the cuts, as pictured below. Add buckle as shown, and about 1/8" from the end of the slot, sew a straight stitch to secure the buckle in the leather. If using a sewing machine, a zipper foot would be ideal here.
Trim the 8" strips round on one end, and a rounded point at the other. Using a leather punch or drill, make holes along the strip 1-1/2" from the rounded end, about every 3/4" or what ever interval works for you.
At this point, test fit the kilt, and mark where the ends of the aprons are on the kilt.
On the front apron side, at the mark you made, you will need to make a slot for the strap to come through from the under apron and attach to the buckle. I used the one-step button hole maker on my sewing machine (After quite a few test runs), with the button foot set to about 1.5 times the width of my strap. There are also other instructions on the website on how to do this without the button hole maker. (Image 3)
To the right of this hole, attach one buckle setup about 1/4" away. (Image 3)
On the under apron side attach the buckle 1/4" to the left of the mark you made. (Image 4)
Attach the first strap to the right edge and the outside of the under apron, and sew through the entire apron. If the kilt is too loose, adjust the placement of this strap to pull more of the under apron around, and cinch it up. (Image 5)
Attach the second strap to the left side, inside of the Front Apron, but only sew through the hem and the interfacing. No threads should show on the outside of the Front Apron for this strap. (Image 6)
Add Comment
