Step 6The Pleated Length
Earlier, you chose the pleat length (in the example 1-1/32"), and the the under pleat length (in the example 4-1/8"). Mark the pleat length from the right edge of the Front Apron, and mark the under pleat length from there. Because I used the pattern, It was already marked for me. Now, pinch the first mark, and fold over to the second mark, forming a Z fold. Make this a completely straight fold from top to bottom, parallel with the Front Apron right edge, and pin. (Image 3)
Continue this in the same fashion as the first, measuring off the previously completed pleats edge. Because I used the pattern as a template, I can use it to make sure I'm making the correct folds, as in image 4. I suggest you pin all your pleats before doing any sewing (I made that mistake too). Every few folds, check, by flipping over, and making sure all your under pleats are the same size.
It is during this process that you will need to make the adjustments to the Waist Line so it is the correct length. For example, if your Hips were 36", and your waist, was 30", then you need to make the waist 6" smaller than the Hips. 3" are removed by putting the taper into the apron, leaving 3" more to be removed. Equally spaced in the pleats you will need to make enough 1" tapers to remove the difference in the waist. When you have pinned the pleat you want to taper, mark 1/2" left and right from the pleat fold, and bring these two lines together, adding the extra fabric to the the pleat. Remember when folding the next pleat, that there will not be your pleat width at the waist line, but 1/2" less. From the Hip to bottom is unaffected. (Images 5 and 6)
When you have completed 1/2 the pleats, do a test fit, placing the Front Apron evenly on your front, making sure that the last pleat is about to your middle back. If necessary, add or remove the total number of pleats, to make up any difference.
Continue until all but the last pleat has been pinned.
With a sewing machine, sew the pleats, but only from the top edge to the hip line.
Add Comment
