The kimono that I so desperately wanted at 18 has been living in my closet for a few years now. Every time I found it, I couldn't help but admire the fabric and the hand stitching- even though I didn't display it any more, I couldn't see parting with it. I finally plucked up the courage to cut off the beautiful bottom portion off the kimono and turn it into a corset. To keep costs low, I used left over heavy duty cable ties as boning. This project was all about recycling something old (yet beautiful) and dusty into something a little more fun and actually wearable.
I drafted the pattern based on an awesome tutorial . I hadn't done much in the way of pattern matching before (solids FTW!), so it took a night of trial and error to get to the point of cutting into my beautiful but extremely limited supply of fabric. I ended up drawing each pattern piece on tracing paper, adding seam allowances, and then cutting two of each piece. I knew I wanted a crane at the center front, and I happened to have a crane that spanned two pieces of fabric. I made that seam line my center front opening and traced the main elements of the kimono's pattern onto each of my two center front pattern pieces so that I would know where to lay them out when cutting the fabric. Even though I wasn't necessarily matching the rest of the pieces to each other the way I matched the center front, I still used the tracing paper method with the rest of the corset. I wanted the center back to match up the same way the front did, and I wanted the side panels to be exactly the same as each other, with the side front and side back panels at least closely relating to the front and back pieces.
I might have gotten a little frustrated by the end of the process and not ended up with perfect matches or symmetry, but I hope the finished product will inspire others to recycle old pieces into fresh, wearable art.
duetconsignment says: Oct 5, 2012. 7:57 PM
Spectacular. So very beautiful.
divaz says: Nov 11, 2011. 4:22 PM
This is so beautiful and shows your creativity and vision! Thank you.
maullove says: Jun 16, 2011. 7:32 PM
Beautiful! I love how well the panels display the image, five stars.
jadekikyo says: Jun 13, 2011. 7:31 AM
Voted. :-)
mdel_giorno (author) says: Jun 15, 2011. 6:55 PM
Thank you!
cafeeenee says: Jun 15, 2011. 5:18 PM
Lovely!
melissagabbano says: Jun 14, 2011. 9:06 AM
Voted :) Came from the Jaxofalltrades FB page.
nliedel says: Jun 3, 2011. 2:50 PM
You can use heavy duty zip ties for boning. It's more comfortable than the steel I use in most of my ren wear, but will still give you sleek lines and allow you to pull your corset tight. I make corsets in four layers. Two inner layers of a heavy material that holds the boning and a layer next to my skin, with the final layer of the fabric I want on the outside. It's not as high temp in summer, as it sounds and the fit is perfect.
You can get the large zip ties at Home Depot, K-Mart, Lowes, etc.
The corset rocks. It's fabu and you look amazing in it.
mdel_giorno (author) says: Jun 3, 2011. 10:31 PM
Yup! Those heavy duty zip ties are what I used, actually. I discovered them back in high school when I was dead set on making an Elizabethan corset and had no way to get steel bones. I love them!
khenkel says: Jun 1, 2011. 9:36 AM
Love how it is recycled and "green"! Looks amazing!
sunshiine says: May 31, 2011. 5:15 PM
Very nice!
dgriffith1 says: May 31, 2011. 3:37 PM
Clever, gorgeous, and (if you don't mind me saying) wicked hot.
mdel_giorno (author) says: May 31, 2011. 3:44 PM
Thank you for the kind words! ^_^
dezer says: May 29, 2011. 7:53 AM
Simply stunning! Beautiful work!
mdel_giorno (author) says: May 29, 2011. 9:55 AM
Thank you!
ladycroft108 says: May 29, 2011. 8:39 AM
This is Gorgeous!!! I've always wanted to try making a corset, but i'm too a) broke to buy a pattern, and b) didn't know to find the boning locally. Thanks so much for the link, too, definitely going to try this!
mdel_giorno (author) says: May 29, 2011. 9:53 AM
Thanks! I discovered cable ties back in high school when I wanted to make an Elizabethan corset but didn't have access to (or funds for) steel boning.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
