Introduction: Kindling Box
I needed a box to store small (cut up pallet) sized pieces of wood to burn in my wood stove. My chimney has an area for wood storage built into it. I had previously made a wooden insert to organize the space but there still was not enough room for kindling. So I decided to build a custom wooden box to resemble one of the old soda box crates I had seen in antique stores. I knew I did not want any screws to show on the outside and I also needed a space to store a bellow and fireplace gloves.
Step 1: The Space, Materials, and Assembly
I don't have many pictures from this part of the project but in the picture you can get the idea of how it all went together.
I measured the space where the box would sit and decided on the height. I chose to use a 16 ft piece of 1 x 6 pine from Lowe's. Using my miter saw I cut the pieces to the length I needed. I then decided I wanted 2 sides of the box to have 4 slats and the other 2 sides to have 6 slats. I milled the 1 x 6 into 4 and 6 equal width pieces. Next I laid out all of the pieces for each side and attached scrap strips of wood using screws to form 4 panels. I also found a scrap piece of ply wood and cut that to size to make the divider for the glove/bellow space. I then took the two 4 panel sides to the drill press where I drilled 5 holes using a fostner bit to cut out the handle holes. I chipped away the excess using a chisel and mallet.
Finally I attached all of the pieces together to form the box and screwed it together from the inside.
Step 2: Stain
I sanded all sides with a random orbital sander at 240 grit and then stained the entire box both inside and out. After applying the stain I wiped it off with a rag to remove the excess stain.
Step 3: Embelishment
The wife thought the box needed something and suggested the initial of our last name. I printed out the letter in the size and font I liked and cut the paper out. I then traced the paper letter on a piece of copper I had lying around.
Step 4: The Letter
I then cut the copper letter using my band saw. I also used a grinding wheel and sander to clean up the rough edges from the cutting process. I then used the polishing wheels and a dremel tool to buff the copper to a nice shine.
Step 5: The Finished Project
I drilled holes in the copper letter where I wanted them. I laid the letter out on the box and attached it using small copper nails. The pictures show it up close and in place on our hearth.
That turned out very nice! Much better than a cardboard box or an old bucket!
