3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kipkay's Video Tips & Tricks
Kipkay\
Here are 5 easy and cheap tricks for anyone who uses a camcorder. Total cost for all 5 is under $10!
Step 1Tip #1
Tip #1
Pick up a cheap rubber doorstop at your local hardware store or grocery store (about $2) This little handy guy works great under your camera for low floor shots. You can adjust the height of the angle just by moving the camera forward or back on the doorstop!
47 comments
1-40 of 47next »
Jan 27, 2008. 5:14 PMjudelizowski says:
That doorstop is amazing! It works great! And the eye bolt, BRILLIANT! thank you Kipkay, kudos to you....
Nov 25, 2011. 4:31 PMtechboy411 says:
Yea! You can do COOL stuff w/junk
Jan 28, 2008. 6:55 PMjudelizowski says:
True... :)
Jan 15, 2011. 9:45 AMaar0nc0le says:
What kind of camera do you use most often?
Feb 21, 2008. 4:53 PMadriandilena says:
I would caution that despite it being a good idea for an impromtu steady shot, one must be careful as it doubles as a sling shot that would send your camera hurtling towards your feet if ever dropped. yikes!
Oct 23, 2010. 9:12 PMPuzzledd says:
Definitely put the camera strap around your neck first - and maybe tie a loop in the other end of the bungee cord to slip your foot into so it doesn't dislodge when you move your foot and fly up to hit you in the face;P
This is a great idea tho (don't have a bolt handy so I may try putting a loop at the top to put my hand in, to steady it - or a couple of loops at different lengths to use for shots at dferent heights) :)
Oct 13, 2009. 2:18 PMxproplayer says:
so for tip 5 wouldn't it be a little embarrassing to be taking a shot and have the camera slip and fly towards the floor with a bungee cord aided fall
May 15, 2009. 8:33 PMArbitror says:
Tip #3: Red and Green would not be proud!
Oct 13, 2009. 2:17 PMxproplayer says:
agreed!
May 25, 2009. 11:33 PMCybergothiChe says:
Apr 3, 2008. 2:35 PMdbarak says:
Most camera tripod sockets are "1/4 20", meaning 1/4 inch in diameter, with 20 threads per inch. That last number is important so you don't strip the threads on your camera. Fortunately, that's a pretty common size for nuts and bolts in hardware stores, so you can make all sorts of rigs. Some bigger cameras use a larger size, but I don't remember what it is. Something like 5/16 inch, but more than likely you won't have to worry about that.
Mar 20, 2009. 2:15 PMRyan Damm says:
3/8"-16
Jan 5, 2009. 3:50 PMtheoffice101 says:
i think kipkay is awsom
Mar 16, 2009. 1:24 AMjames.mcglashan says:
same he rules
Dec 12, 2008. 7:41 PMIW5 Industries says:
i saw you kipkay on the tv show, Brink , on the science channel for your air blaster horn
Jun 28, 2008. 2:14 PMwethecom says:
very good stuff thanks before i die i want to make a film and a album this info was awsome
Jan 30, 2008. 7:39 PMAT says:
Nice tips!
Do you happen to know what the thread of a tripod mount happens to be?
Here is my easy tip: If you don't have a fluid pan head for your tripod and you want a nice smooth pan, there are two simple things you can do to get a nice pan shot.
  • I find that many cameras don't like to pan smoothly when you have image stabilization turned on. So turn that off.
  • Your neck is a great fluid pan head on your body tripod. Hold your camera along the side of your head or on top of your head and make your shot. You should be able to do the pan with your head and it will turn out nice and smooth. And it is quite a bit cheaper than a good fluid pan head for your tripod.
Jun 1, 2008. 10:47 PMcool! says:
Just wondering, but how do you get those bullets?
Jun 2, 2008. 6:05 PMAT says:
That is a good question. I wish I remembered what I did. I have tried a few things and am unable to repeat that. I think I might have cut and pasted from Word but when I tried that again, it didn't work. Maybe someone smart could figure it out.
Feb 3, 2008. 11:02 PMThe Real Elliot says:
Camera-mount screws are 1/4"
Apr 29, 2008. 4:11 PMcoolz says:
I hope you dont mind that I added this to my group
Feb 5, 2008. 1:17 PMemac says:
The Norm of video camera and camera tripod mounts is 1/4 diameter
Mar 28, 2008. 11:31 AMJoanassie says:
and how long is a diameter? 10m? try using units next time please.
Mar 20, 2008. 12:26 AMcavtrooper says:
Better than the bungie cord, I built an inexpensive steadicam camera mount using pvc pipe and fittings from the local home improvement store. The whole thing didn't cost more than ten bucks and it works like a charm! It looks like I paid lots of $$$ for it too. I stuck it all together using pvc cement... and if you've ever worked with pvc, you know that the pvc cement welds the parts together permanently. I used half-inch pvc pipe, a half to one inch coupler, a piece of one inch pvc pipe about four to six inches long with a pvc cap on the end (this is to hold the lead weights at the bottom). I used lead fishing sinkers inside the 1 inch pipe and left a whole big enough where I can dump or add weight depending on the camera I'm using. After I got the whole thing cemented together, I used Krylon Fusion (for plastic) black satin finish spraypaint to make it look like I paid big $$$ for it!
Feb 18, 2008. 3:40 PMcubester808 says:
nice tips, but y on earth do you have a pantyhose ? ?
Jan 30, 2008. 9:20 PMtechnodude92 says:
kinda off topic but is does anyone know of good free video editing software? Or if anyone is good with virtDubMod?
Feb 2, 2008. 6:02 PMStonerKitty says:
Well a good operating system would be Ubuntu Studio...it has good video and audio editing software
Jan 27, 2008. 5:02 PMbumpus says:
haha the cat
Jan 30, 2008. 8:27 PMxproplayer says:
my would just hurdle towards the treat and mess it all up ps also you should make a pet lie detector like you tried lol jk pss keep the Instructables coming!!
Jan 30, 2008. 4:54 PMrichelton says:
Okay, now the eye-bolt bungee monopod is a clever idea.
Jan 28, 2008. 3:36 PMltx says:
1/4" for most cameras.
Jan 28, 2008. 3:33 PMltx says:
Great video, I love all your Instructables and your stuff on Metacafe. Question though, how do you get such great sound? I see that boom mic on your camera with something else, is that what you use? Where can I get those and for how much? Thanks, Josh
Jan 28, 2008. 1:58 PMmrdspecs says:
Awesome. I'd be worried about that bungie cord snapping back up at me though.
Jan 28, 2008. 7:59 AMPhoghat says:
Liked you tips, but the portable tripod-cord thingie is more useful IMO if not bungied. I use either rope or thin strong chain. That way I can step on it at the level I want and then "Dynamic Tension tm" keeps it steady at that height. Otherwise liked all your tips. Keep 'em commin'.
Jan 28, 2008. 6:01 AMcomodore says:
Cool tricks. When is the volume 2 coming out? :)
Jan 28, 2008. 4:15 AMBrennn10 says:
Nice ideas KipKay, nice video!
Jan 27, 2008. 7:33 PMalvincredible says:
alvincredible <3's you. great instructable and video! hahah i like your instructables, they're all well done and useful! keep it up!
Jan 27, 2008. 6:44 PMdchall8 says:
Your video tips are long awaited, thank you! We are also interested in your editing to make your videos interesting, informative, and compact.
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2397
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
