iImage Information
This is a simple Kitchen Automation project. A Firgelli Automation FA-400-12-18" stroke linear actuator was used to pop up this spice rack. Of course the top would typically be the granite square that was cut out originally, and the spice rack could be a coffee machine, microwave, TV, wine rack or anything else you wish to hide in your kitchen.
The actuator sits pointing upwards and as you can see the middle of the spice rack has a sort of hollow column, this is where the other end of the actuator fits inside. It's not required if you use the Firgelli Automations column lift which is a ready to go remote control lift mechanism.
Step 1Kitchen grannite top
iImage Information
This customer wanted to have the spice rack lift up from the Kitchen island. 1st thing they did was cut a square hole in the granite top, the granite maker can do that for you. Typically you would use another square piece to fill the hole so that when the rack drops the granite becomes flush with the top lid to look like a single piece of granite
1. One critical problem I see is spices falling over and or other things obstructing the unit from moving up and/or down correctly. I know how easily spices can fall over or get knocked over and it would be a pain to have the rack get stuck when your trying to cook.
An easy way I see to fix this is to add a hollow plastic cylinder that fits snug around the edges of the circler shelves in the spice rack. The plastic would stay down underneath the countertop when the spice rack is raised so that you don't see it above and it doesn't get in the way of accessing spices. The plastic hollow cylinder would be angled or curved at the top and adhered to the underside of countertop to ensure it doesn't move and so the spice rack does not get caught on it when it lowers or raises.
I love this idea and i might even consider 2 like this in the future. I would also probably making the spice rack it self a lazy suzanne. Theres no need for an electric motor to run it. I think this is much a much better solution for corner cabinets that people have lazy suzanne in and have to bend down and spin through it.
Stacie G.
Summit Design Remodeling
Home Remodeling for Metro DC: VA and MD
Let me know if I'm not describing it well enough..
Looks VERY handy. and swooshy _
