Step 9Seal the Plastic Sheeting to the PVC Tube
Press the plastic sheeting down so it fully seals against the cement on the top rim of the tube. Then, use a knife to carefully cut slits in the plastic sheeting over the hole in the PVC, so you end up with little triangular flaps that you can push down into the tube and press against the cement.
You want to end up with an open hole from the plastic into the tube, but it needs to be watertight, or drainage water can leak under onto the wood and down the wall.
This step takes some patience and a steady hand, but luckily since it'll be in the back, it doesn't matter if it looks messy when you're done.
Add Comment
