3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kitchen PC with laptop twist
I wanted to build a Kitchen PC, but needed it out of the way. I saw the Sony undercabinet tv's and had this idea. The brackets are simple L brackets that I put in a vice and hammered into the shape you see in pic 1. It looks pretty ugly from this angle but no one over 4' will ever know. I drilled the holes down from inside the cabinet so it doesn't have screws pointing up.
Step 1Mount laptop upside down
This picture doesn't show the cords, but they were hidden under the cabinet lip with zip ties and double sided tape.
I also mounted a USB Hub with DS tape for the wireless adapter and wireless keyboard/mouse.
68 comments
1-40 of 68next »
Nov 26, 2011. 11:30 PMminus5252 says:
I love the simplicity of this project. Easy-peasy, living greasy!
Nice idea with the mounting of the USB ports.
Apr 23, 2007. 8:55 PMeternelboredom says:
Awesome project! I built mine with a rail system, and the computer can slide into the rails. Also, I bought a TV tuner and now I have a 17" LCD TV for $36.00. My problem is that there is no way to spin the display on the nVidia GeForce FX Go5600. I found Pivot Pro, but is there a free hack i could use?
Jul 16, 2011. 8:14 PMdmoreno2 says:
maybe you can use the VLC media player since you can rotate what your are playing and also have an option to enable a capture device maybe your TV tuner can work with it. + is free
May 24, 2008. 4:59 PMsee-saw says:
Great idea - you could add this keyboard with integrated touchpad so you could lose the mouse.
Jul 16, 2011. 8:11 PMdmoreno2 says:
Nice idea...since lots of people have their cellphone with them all the time; use a mobile app to control the pointer and keyboard from your cellphone btw I'm using "sensor mouse" for Android.
Jan 25, 2011. 10:37 PMajs1980 says:
You can find inexpensive tablet pc's on eBay now running under $100 at times which would allow you to position the screen closer to the front edge of the cabnets making it easier to see. It also would have the added benefit of a touch screen or atleast stylus controle.
If not slap a magnet to the back of http://www.thinkgeek.com/computing/keyboards-mice/e0e7/ and stick it on the fridge when not using it. keyboard and touch pad together makes for a great kitchen PC and its the size of a standard remote.
Mar 22, 2007. 3:57 PMprestron says:
In Windows XP you can enter Ctr+Alt+Up/Down/Left/Right to orient the monitor on any side. I don't know if there is any XP compatible graphics cards that can't do it, but I've never seen one that can't.
Dec 23, 2010. 12:15 AMkbhasi says:
for me, it only works on Intel graphics cards because the drivers are the one that give the ctrl-alt-arrow, as i saw in the control panel for it.
Jul 6, 2009. 12:09 AMDerin says:
My radeon 9600 seems to be unable with Catalyst installed.
Oct 30, 2007. 5:45 PMaussie2u says:
I did something similar (inverted laptop) for a long car trip we were taking. I thought it would be a great DVD player for the kids. Everything looked great and Windows XP inverted the image properly until I actually got onto the road and played the DVD. It seems DVD's (on many laptops) bypass the rotate functions and "talk directly" with the hardware! Point here is that if you want to look up receipes, surf the net, AND watch a DVD while it's under the counter, check your laptop out first to make sure both functions remain inverted.
Jul 23, 2010. 6:45 PMjrgallion says:
I like you kitchen PC. Has anyone made something simple like this? http://recipetesterblog.com/kitchenpc/ It's simple but, it would be interesting to make something of my own. Cheers, Jason
Jan 9, 2010. 11:13 PMYerboogieman says:
Now I'm jealous, The wood under my cabinets is clearly not strong enough.
Jan 9, 2010. 11:08 PMYerboogieman says:
Nice! I just need to fix the power port on my old laptop.
I added this instructable to my group "Featured".
Aug 13, 2009. 6:51 AMjhalel says:
Only note, she asked how YOU did it.
Aug 7, 2009. 7:51 PMLilFairman95 says:
if you need good software to rotate your screen search google for "irotate" i used it on my old laptop
May 26, 2009. 3:04 PMlifelike27 says:
Here's an idea, Why not add two magnets on the top of each corner of the keyboard and two more on the wall above so then when in the kitchen and you need some extra space for cooking just snap it up there or put them directly on the fridge. Same goes for the mouse, but put the magnet somewhere on the side. You can then use the scroll wheel or the up and down keys of the keyboard to view a long recipe that doesn't fit on the screen
Jun 13, 2008. 9:23 PMaz1995 says:
Nice idea =) I would do that.... but I'm only 13... Anyways, instead of installing some software thingy, I found that if you press ctrl, alt, (down arrow key)... it turns everything upside down. To undo this, press ctrl, alt, up arrow key. You can also use the left/right keys. =P
Jun 15, 2008. 9:47 PMgeterkikzkid says:
WTF??/ Which OS do you use?
Feb 20, 2009. 12:16 AMawang8 says:
Intel and nVidia notebook GPUs allow you to do this.
Jun 16, 2008. 4:36 PMaz1995 says:
Not sure what "OS" means, but I'm typing on a Vista... When you press ctrl, alt, (then an arrow key)... it turns the screen that way... =)
Sep 7, 2008. 10:47 AMakumahai says:
OS means Operating System, so yes. Vista is the correct answer. It doesn't work on all computers.
Sep 6, 2008. 9:18 AMmoopet says:
That's an atI thing, not an OS thing.
ATI driver, sorry for the typo.
Jul 6, 2009. 12:05 AMDerin says:
It won't work on my PC with CCC (ati's control center) installed.
Sep 21, 2008. 3:49 PMearlvanze says:
It's also an Intel thing. And an nVidia thing.
Nov 11, 2007. 8:00 PMCartuner55 says:
you can also use DesktopX to use widgets
Jul 19, 2008. 4:49 PMsiman880 says:
thats what i use
Mar 17, 2008. 2:52 AMThomas82 says:
Very nice, but wouldn't it be cool to have a screen built into your countertop? Covered with hardened glass?
Mar 1, 2007. 2:44 AMDanAdamKOF says:
I saw this project outside of instructables before, I swear. Nice!
May 27, 2007. 11:26 PMjammaki says:
You did. Popular Science or Mechanics did an article about using a laptop in this way. I'll search through my archive and see if I can't dig up the issue month/year. or you can probably search their sites.
Jan 28, 2008. 7:20 PMjammaki says:
For sure. I really like your under the cabinet approach better.
Jan 28, 2008. 6:54 AMltkrause says:
This was a great idea and you inspired me! Instead of the brackets, I used small plant hooks and really small bungee cords to hold the laptop up. I also put velcro on the bottom of the keyboad to put it under the counter out of sight when not in use! Thanks for the inspiration!
May 5, 2007. 11:13 AMrucket says:
couldn't you use velcro instead of drilling holes and using brackets ?
May 8, 2007. 1:05 PMC-glenny says:
Yeah that seems like it would make it much easier! No damage to the cabinets.
Mar 11, 2007. 12:51 AMmisty_bishop says:
Maybe I am not up to date, but how did you get the screen upside down?
May 17, 2007. 3:30 PMphreakin says:
there are several progams you can use to do it some laptops already come with the program in the video cards stuff try right clicking on your desktop and clicking properties and look around in there for it
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:project109x
