3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kite + Ice + Butt + Board
Your screaming steel blades carve the ice.
Your straining kite hurls you along at incredible speeds.
You are mere inches above the ice. Or suddenly wiping out all over it.
If polo is the "sport of kings", then surely kite-ice-butt-boarding is the sport of gods.
This week's Instructables TV episode shows you what you've got to do this winter.
For details and inspiration memorize, chew and swallow the following instructables:
Howtoons Ice Skate - Skate Board
ewilhelm's Ice Proa
radiorental's Convertable All Terrain Board
Step 1Ice Awls - Important Safety Equipment
Also called "ice claws", these enable you to crawl back onto the ice if you break through.
Without them you'll be in big trouble. You'd have to go up and over the edge of the ice, continually breaking the weak edge or sliding back and falling back in. These awls let you drag yourself back onto the ice, staying low and spreading your weight out more. These are standard equipment for ice fishermen along with life jackets and sleds big enough to be used as a boat.
This pair of awls was made by drilling an undersized hole, pounding a nail in, cutting off the head and filing a point on it. The nails are off-center so you can drill a larger hole in the other awl and plug them together so one sheaths the other. Very slick. Wear them around your neck. These were made from chunks of broom handle and stainless steel ring nails.
28 comments
Oct 9, 2010. 6:19 PMmatt09 says:
why dont u call it kibb boarding
Feb 3, 2011. 5:58 PMFoaly7 says:
K.I.B.B. Boarding would be redundant. "Kite Ice Butt Boarding Boarding". Plain old K.I.B.B. or K.I.B. Boarding would work.
Oct 9, 2010. 6:20 PMmatt09 says:
wheere is this?
Apr 3, 2010. 8:16 PMM F says:
air and speed, cooool. How about sky dive  canoeing?
Do you think it would work?
May 13, 2009. 11:19 AMDerin says:
BLING!!!!!!! Kite powered ultralight ice golfcart.
Jan 24, 2009. 11:24 AMsunderman says:
i built a type of this with wood and a sail.. its pretty cool
Dec 19, 2006. 10:42 AMTool Using Animal says:
That does it! You folks are completely destroying the publics perception of nerds. As punishment, I want you to go to your mom's basement and think about what you've done, and when you've compiled a list of every remaining gopher server you can have some Mountain Dew and Doritos. Oh and another thing, I'm inviting my fat, clumsy butt along next time.
Jan 15, 2008. 6:46 AMRussian Bear says:
that is my "icebugy" What do you think about my invention?
May 22, 2008. 8:25 PMewilhelm says:
Post more pictures, or a full Instructable!
Sep 25, 2008. 6:36 PMschneidp20 says:
I tried making your butt board a couple years ago. Mixed results. - it pulled me off the board a lot. When it didn't, hiking with the wind turned the board into the wind too much. I tried making an outrigger foot rest, but that didn't work too hot either. I'm going to try your Ice Proa this winter.
Sep 26, 2008. 3:35 AMschneidp20 says:
The ice was great and the wind was a little gusty I guess(this was 2 years ago). I was flyin a 5M Frenzy in Minnesota. If the conditions are right I'll give it another shot.
Sep 7, 2008. 5:55 PMtemp says:
Where do you go kite+ice+ but+ boarding? Meaning... What type of climate do you use to get a frozen lake with no snow on it? (does this make sense?)
Jun 19, 2008. 6:42 AMcasey321b says:
i got an idea but u have to see in my next instructable
Mar 8, 2008. 4:36 PMbowmaster says:
I am going to make a completely tricked out ice buggy with flotation bladders (so I can use it on water), brakes, a way to switch the blades for wheels (to use on land), and a padded seat!! (instructable coming soon[maybe])
Dec 23, 2007. 10:26 PMNor-tea-a says:
awesome video. after i saw this i bought a 5m pansh kite and made a ice skate board out of one of my old skateboard decks.
Mar 12, 2007. 9:15 PMRakkan says:
I saw something similar on a late-night tv show where someone was skiing down a hillside, using a hang-glider to pull of some gravity-defying stunts. It wouldn't take any tinkering, but alot of skill to pull it off.
Dec 19, 2006. 11:48 PMtrebuchet03 says:
That, looks totally fun! More so than cable boarding :) <<-- in which I found my limit on where the helmet camera goes... Not where it can get completely submerged :P Where did you go for the ice?
Dec 20, 2006. 3:38 PMewilhelm says:
The video was shot on a couple of outings to Quaboag Pond and Lake Quannapowitt in MA. The video in my ice canoe Instructable was shot entirely on one Tuesday on Lake Quannapowitt where the zeroprestige team went to Lake Q for a morning session, and then went to work. None of us could focus at work, and the wind was still blowing, so we just went back to the lake for the rest of the day. I still get shivers of pleasure down my spine just thinking about that day!
Dec 21, 2006. 6:27 PMtrebuchet03 says:
Ahh - very cool (ha! a pun :P) It had me confused for a bit -- considering the temps in SF :P
Dec 20, 2006. 1:48 PMTool Using Animal says:
the howtoons, to my eye, contains a rather bad error, anyone who had never ice skated before might be led into putting a 45 degree bevel on their blades.
Dec 20, 2006. 3:22 PMewilhelm says:
Our blades are different from ice skating blades for two reasons: 1) ice boats use this same type of blade 2) it's much easier with commonly available hand-tools to make this type of blade. I'm no ice skating expert, but I do consider myself an ice-butt-boarding expert and these blades work perfectly. They grip the ice when you want, but still can be broken free for power slides and quick turns. I've never tried ice-butt-boarding with ice-skate blades, but would definitely like to try.
Dec 20, 2006. 6:19 PMTool Using Animal says:
I stand corrected, seems to happen often ;-) Useless trivia...I was born inside the I-95/128 loop.
Dec 20, 2006. 1:39 PMwombat7 says:
fond memories of the zeroprestige days :)
Dec 20, 2006. 12:50 PMCorvos says:
If the blades are hollow-ground (rather than 90 degree square edges) performance will be much better. You can do this by hand with a round dressing stone held in a spring clip arrangement; these are available from places that sell ice skates and most skaters have 'em.
Dec 20, 2006. 8:15 AMventifact says:
Wear a helmet and look out for holes in the ice!
Dec 19, 2006. 1:59 PMTheCheese9921 says:
fun fun
Dec 19, 2006. 1:05 PMWade Tarzia says:
Fantastic, an ice-proa! Instructables guys make life worth living even more than it was before.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1251
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
