Kite + Ice + Butt + Board by TimAnderson
Step 1: Ice Awls - Important Safety Equipment
Also called "ice claws", these enable you to crawl back onto the ice if you break through.
Without them you'll be in big trouble. You'd have to go up and over the edge of the ice, continually breaking the weak edge or sliding back and falling back in. These awls let you drag yourself back onto the ice, staying low and spreading your weight out more. These are standard equipment for ice fishermen along with life jackets and sleds big enough to be used as a boat.
This pair of awls was made by drilling an undersized hole, pounding a nail in, cutting off the head and filing a point on it. The nails are off-center so you can drill a larger hole in the other awl and plug them together so one sheaths the other. Very slick. Wear them around your neck. These were made from chunks of broom handle and stainless steel ring nails.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
