3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kite Aerial Photography (KAP)
Design and manufacture your own mechanical intervolamerter trigger for your old digital camera.
In this project we'll see how to make your own camera trigger from recycled, reused, and re-purposed materials, many you may find laying around your home!
Prologue:
One starry night of sleepless lasagna-tummy, my mind wandered to my bloated Bolognese belly.
After the third antacid and mouthwash I had an epiphany. Maybe it was the double chese and garlic turf war, maybe the chalky effervescence creating a toxic nerve-gas, I don't know. I lost track of everything over the last 5 glasses of red.
I had a vision of my expanded belly carrying me upwards, all I was able to grab before my feet left the ground was my sunglasses and camera. I was carried to the sky photographing my way upwards. I had broken into the stratosphere when.... *blink*
It was over.
A quick look on Google the next morning revealed that apparently more than just me has a reaction to a cocktail of food, alcohol and medicine, and as far back as 100 years. Intrigued, I checked Instructables to see if anyone had done something similar, to my surprise (and to date of publish) they had not. I was inspired to create my own aerial photographs. Since I am not familiar with the methods of making my trigger from 555 timers, I needed to make a mechanical trigger. As a twist I would use recycled and re-purposed materials and combine it with an old abondoned digital camera to take photos from my kite.
While electronics may be second nature to some, to others (myself included) they are a mystery. I did not want wiring or programming to be a deterrent, for this project this element is removed entirely. In addition I wanted a design that would not compromise the camera housing. This rules out opening the camera to solder on a trigger.
My guidelines for this project were:
  • use as much recycled content as possible
  • budget of around $50
  • able to function with any digital camera
  • no special camera function (or special plug)
  • no specialty knowledge (eg: no electrical / arduino / 555 timers etc.)
With the ideas laid out, I was set to take some aerial photography, and maybe have an adventure along the way.
Enough talk...... let's build!
Step 1The kite
The kite
Researched pointed me towards a few possible options to ahieve the required height. The original idea was to use a balloon filled with helium to generate the lift. This idea is still good, however I wanted to make something portable, and riding the bus with a giant balloon isn't a great way to make friends (or is it?). Instead I opted for the more passive method of a kite.
Kite design is everything. There are countless varieties of kites, and luckily there are a few that lend themselves well to this application. I suggest doing your own research to determine which style fits your needs best. I chose a design that was simple, easy to fly, able to achieve lift in any wind, and large enough to accept a payload. The delta conyne satisfies all my criteria. With a little sleuthing you may find dimensioned plans online that you can use to build your own.
As I was on my way to find materials to make my kite (rip-stop nylon and wooden dowels), I happened upon a kids store nearby which had the exact kite I was looking for, in the size I needed (6'+ or 1.8m+ from wingtip to wingtip), and was on sale!
An actual quote from the cashier "I can't believe you're buying this, it's been in that corner of the store for years."
really??!
The kite cost $30. The remainder of the budget was spent on the line, more on that in step 9.
The only downside is that the kite is kinda pink.
36 comments
May 2, 2012. 10:59 AMrread says:
I've made a device to help steer a single line kite.
http://youtu.be/Q1o4mw0ug14
This is a really easy make and may help you with launch and landing.
It can also help put your kite in just the right spot to get the view you need.
Apr 24, 2012. 5:53 AMrread says:
Brilliant stuff, well done. This may help you get the prefect view angle... I needed to build a remote control to steer a single line lifter kite. http://youtu.be/Q1o4mw0ug14
I
'm hoping to use this in order that I can lift an airborne wind generator into the sky.
wish me luck
Apr 24, 2012. 1:47 PMrread says:
Ah yes thanks, Makani. Indeed. I think they even have a related instructables article on airborne wind energy.
Even though they're backed by google and ARPA-e, I fully intend to wipe the floor with that design.
May 2, 2009. 10:51 PMheladoxa says:
We did a similar exercise for a school project, and considered using a weather balloon or a kite. We tried both and the result was interesting and un-expected. With NO wind the balloon went up and was pretty stable. The kite did not go up, of course. On a windy day the KITE went up and with a smooth wind was stable, but the balloon wanted to be blown by the wind to the length of its tethering string and was therefore blown DOWN and was useless. Its horses for courses!
Mar 2, 2012. 3:55 AMroland985 says:
Well, why didn't you just attach the weather balloon to the top of the kite? Kit keeps things stable when windy, but when the wind dies, the weather balloon holds things up.
Feb 26, 2010. 5:48 PMkcls says:
Can you post a video of the button-pushing mechanism working? This is a great instructable!
May 5, 2009. 10:14 AMFrivolous Engineering says:
You might want to use an inexpensive camera at least until you get the hang of it...
May 3, 2009. 1:21 PMMarcos says:
Now that's my kind of Instructable! Fun idea, clear, if somewhat arbitrary parameters, low budget, and simple. But couldn't you at least get some Knex or flashing LEDs in there? ;)
I built my bamboo monopod with similar parameters. All materials except the bamboo had to be on hand, no trips to the hardware store! I like the challenge of doing things that way, if forces me to think up solutions I might not have otherwise.
Apr 19, 2009. 10:19 PMdchall8 says:
Your said, My choice was the delta conyne, if you follow the link you will see the plans I was going to use to build my kite.
Where is the link?
Where would you have found the rip stop nylon?
I know where I can get a delta conyne, but I was hoping to find a deal like you did. Only I was going to ask for a big discount being as how it was an old kite. I made a double delta conyne (my own design) about 10 years ago. It only flew successfully for about 10 seconds. It flew unsuccessfully for about a minute in all. I was very surprised at the power the kite had. Once I got it tuned up and aligned (nearly impossible), it shot up like a rocket. It went nose down hard into the ground many times in its brief life and finally was not reparable. I think the standard DC would be a good choice for carrying a relatively heavy load like a camera.
May 2, 2009. 11:01 PMheladoxa says:
Try looking up KITE SUPPLIES in yellow pages. Or a sailmaker, but their stuff might be too heavy. What about an umbrella manufacturer?. It's not ripstop, but it is strong, wind-tight and light. There you go, three places to try!
Apr 30, 2009. 8:59 AMpdub77 says:
you can get rip stop nylon at larger fabric and craft stores like joanne fanrics. we have those in indianapolis. don't know if they are country wide.
May 3, 2009. 1:22 PMMarcos says:
Has anyone tried Tyvek as a kite material? It's probably heavier than nylon, but it'll never rip.
Apr 21, 2009. 9:20 AMJoe426 says:
Don't miss out on this awesome kite info and pics:
http://hacknmod.com/hack/incredible-diy-aerial-kite-photoraphy/
Apr 20, 2009. 2:24 PMglennl says:
I notice some water in your photos. Sail lofts (sailmakers) that make spinakers for sailboats are a good source for 3/4 oz resin coated ripstop nylon, the best kite material ever. The bright colors and odd shapes of the large baloon spinakers makes for a lot of waste material. I used to buy it by the pound here in Portland, Or. and 10 lbs of scrape makes you a lot of kites. My Delta-Conyne I made was 6 feet across the base and i used it to go sand skiing. I'm a little weeny guy at about 150 lbs. and in 20 mph wind you had to be careful not to launch youself too far in the air as it woud be a while for you to gat back to terra firma. Delta-Conynes are cool!
Apr 20, 2009. 10:34 AMcheeto4493 says:
I've tried this a few times with a disposable film camera, and a 5' Delta Conyne kite I made out of dowels, the plastic made from disposable tablecloths (the kind that comes on a roll for banquets) and packing tape. The kite worked rather well for a number of times. It had such great lift, that I kept breaking cross beams. And finally the tape got brittle and came apart. One of the best things I've heard of for kite material is Tyvek. I found some scrap material at a worksite (the stiffer type is used for house wrap), and am planning on making a 6' Delta Conyne. I've also got a digital camera that someone gave me that has a broken LCD, still takes pictures though, so I don't have to worry about breaking it much more.
Apr 20, 2009. 7:58 AMdchall8 says:
Thanks for that link. It was the Twin Delta Conyne I made. No plans to build another. I'll check price at a kite shop near our condo and, if the price is under $50, I'll get it from him. Otherwise there is http://www.kiteandwind.com/Hazard_Delta_Conyne_p/nt50172.htm
May 2, 2009. 10:57 PMheladoxa says:
CONTINUED We did this before digital cameras. We used a Brownie Bos with 120 black and white film, a pice of cotton to hold the shutter closed, a piece of fuse to burn through the cotton and an elastic band to work the shutter. Even a 1/30th second at f 8 the results were remarkably crisp
Apr 30, 2009. 12:37 PMdgrc says:
Very cool. If you want to get the price closer to zero, build the kite from garbage bags (or some similar source of plastic sheeting) and wooden dowels. "Sew" the sails with tape. For connectors, use short lengths of tubing. I've built delta conyne kites for about US $0.30 that carried loads up to about a pound and flew stably in 5-15 mph winds. I'm working on trains for more lifting power. At some point, I'll do an Instructable. This approach is great for fast, cheap kite design prototyping.
Apr 30, 2009. 11:22 AMhalfblinddado says:
Excellent Instructable. I am really impressed with what you have done with the materials you used. I made a KAP about six months ago with a basic stamp homework board and a digital camera so I somewhat know what you had to do to make this work.
http://forums.parallax.com/forums/default.aspx?f=21&m=331526&g=331882
I'd like to see more of your pictures,
Mike
Apr 28, 2009. 10:31 AMbenjaminhill says:
I DO NOT suggest doing what I did: Take an old video-capable cameraphone with broken buttons, duct-tape it to a 2-string kite, and fly in excessive wind.
Apr 29, 2009. 11:40 AMbenjaminhill says:
Thank you! (But those weren't tricks. Those were frantic struggles to stay aloft)
Apr 25, 2009. 10:01 PMRavenShadow519 says:
wow! thats way awesome! its intense how you made that thing out of tacs! and your prologue was inspirational! keep up the good work!
Apr 25, 2009. 5:52 PMfwjs28 says:
its so simply complex...but it works! great, 5/5
Apr 24, 2009. 12:39 AMSinAmos says:
The simplicity of the mechanical gear from re-purposed pushpins hits close to home; as I am the consummate recycler of unused items. Your narrative qualities brought a lite, amicable touch to the piece. As far as the end result, I find it hit or miss, so if you intend to take the aerial photography to the next level, I suggest building a remote controlled plane from scratch for that one. I'd use a wireless camera and a range extender for the feed. Other than that, good first, and continue on. There truly are so many things to build.
Apr 20, 2009. 7:45 AMDainiusGB says:
Epic idea mate! But if you wanted to make a more serious version you could get a tiny but good quality camera and then make it like bluetooth or somehow rc to a little screen and then you could take pics or even vids! For the trigger stystem you could make it simpler by putting small rings along the kite string (this could take a while) and then have a string going through those and have that attached to some sort of trigger for the clicker and you pull on the string that goes through the loops to trigger the camera. It would be a hell of a lot lighter. I think i am really going to give this a shot!
Apr 20, 2009. 8:13 AMchrisreeve says:
I got two 50m kite lines with a 700lb breaking strain off ebay for £6 (about $10). These can easily lift me up in 25mph plus winds, so your camera would be fine!
Apr 20, 2009. 6:34 AMrimar2000 says:
Excellent!
Apr 19, 2009. 11:18 PMSinAmos says:
Quality stuff, but I don't have time to truly evaluate your work right now.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
758
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
