3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kite Aerial Photography (KAP)
Step 3Material modifications
A few of the materials I used required minor modifications to allow this assembly to work.
Paint sticks:
These act as the spine of the assembly. The wood is soft, light and workable. Since I wanted the assembly to be used with any camera it needs to be adjustable.
Simply mark out an elongated rectangle on the paint stick and use a hobby knife to cut through.
paint sticks can be found free in your local paint store
Push pins:
The pins will act as teeth for our motor to grip on to. These push pins have plastic heads which are not needed. The heads can be easily removed with a set of pliers.
During operation, the teeth may catch on the motor during rotation, this was solved by grinding each tooth with a slight angle, allowing the motor to slip into the grooves of the teeth easier.
Camera mount nut:
Most mounts will have plenty of thread to allow a firm grim between your camera and the mounting surface. However you may need to add a small collar (or washers) to the threads for a snug fit.
Clicky pen:
In the interest of having a smaller assembly I chose to cut the pen down to size. Originally the pen measured 20 cm (8"), and was reduced to around 7.5 cm (3"). It's vital that the pens' clicky mechanism still work. It should be a stubby, operable, pen.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
759
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
