Step 6Closing the assembly / testing the teeth
The top of the cd spindle conveniently screws to connect with it's base. To ensure the motor engages with the toothed spool a piece of large gauge tubing was placed under the spool. The size of the plastic tubing collar is important, not enough and the teeth will not engage, too tight and the spool will not turn. I estimate a tubing length of 25mm (1"). Luckily the tubing is forgiving and has some give, just don't overcut or you will need a new collar.
Testing:
Video of the motor engaging the teeth. On the center of the spindle you can see the metal tabs acting as my cam, slowly stepping towards the pen.
Other projects that incorporate mechanical non-destructive methods to achieve time-lapse:
this one using an old servo
this one made from k'nex
this one using a small motor
Rigs:
Ive seen KAP rigs that use the typical, to the MacGyver, to the bizarre.
Check out what other people have done and find one that suits you. I made this prototype with a $50 CAD budget and found materials. Who knows, maybe you have enough to make your own too!
Add Comment
