Step 8Putting it all together
By adjusting the slider and swivel arm the camera can be placed directly under the nib of the pen. I have found the best success by turning on the camera and engaging the shutter slightly, thereby only requiring the slightest increase in pressure from the pen to complete the action and take a picture.
Attaching the rig to the kite:
I aimed to make my rig as light as I could, however the heaviest load will be the camera itself. My camera was about 3 times heavier than my rig. Assembled the entire rig with camera weighed less than 700g (1.5lbs). If you have a strong, consistent wind you can mount the rig wherever you chose. In many instances though you will need to get the kite in the air before attaching your payload. Through trial and error I determined that there is a threshold of turbulent air from the deck to around 15 m (50'), past this the air seems to move faster and smoother. This was my marker.
The assembly is hanging about 15m (50') from the kite, around the threshold mentioned. In the picture you can see that the rig is suspended between 2 points on the line in an attempt to add stabilization by allowing the rig to swing independently of pulls in the line.
The solution is to have a cradle capable of suspending the rig and allowing it full travel regardless of any fluctuations or turbulence, however I was not able to complete a more comprehensive stabilization cradle for my rig. See the last step of this instructable for links to more information on cradles.
http://youtu.be/Q1o4mw0ug14
This is a really easy make and may help you with launch and landing.
It can also help put your kite in just the right spot to get the view you need.
