Kite Powered Land Proa
 by Leon Close
Featured
Inspired largely by this Instructable, here is my rough, quick and dirty attempt at building a sailing beach toy.
Step 1: Frame
The photos explain this fairly well. Some scrap Pinus Crapiata and 9mm exterior plywood make up the basic frame. I assembled these parts using self drive wood screws, a couple of roofing screws and some horrible, sticky, black polyurethane adhesive.
When you build yours, either go with a triangular structure or the same Tee shaped frame I have done, but with hollow box beams of larger section than I have used here or just better timber. While this frame seems adequate for my weight and mild conditions, the torsional stiffness of both the longitudinal and lateral members is slightly lacking. It is mildly disconcerting to have your seat twisting around as you sail along. I reckon probably the best way to go for most people would be a triangular structure welded up from steel RHS.
The nerdling says: May 3, 2011. 7:38 PM
10000\5 awesome
teslafan100 says: Jun 12, 2010. 12:51 PM
cool 5/5 im try to make one :)
TSC says: Apr 19, 2010. 11:32 AM
Cool!!!!!!!!!!!!!!
AngusNotSoYoung says: Sep 3, 2008. 6:56 AM
Where do you find a kite big enough to pull it and how much does it cost?
kd1uc in reply to AngusNotSoYoungSep 16, 2008. 8:26 AM
There are probably more than 100 kites you can buy over the counter to power such a rig, however, many are not cheap. To list a few Quadrafoil, Flexifoil, Revolution and others I cannot think of right now. You would be surprised how small of a kite you need if the wind is right but a six to eight foot wing span has quite a bit of pull. I go sand-surfing with a 6 foot Quadrafoil in a 12 MPH breeze. Into The Wind kite company is one source but look around, you might do better.
AngusNotSoYoung in reply to kd1ucSep 23, 2008. 6:20 PM
thanks
Leon Close (author) in reply to AngusNotSoYoungSep 4, 2008. 6:56 PM
I sewed the kite myself, it's really easy and fairly cheap if you have a sewing machine. A decent set of lines is the expensive part. Search for nasawing or NPW or NPW5 or NPW9 for instructions. The kite I used here is actually pretty small, only 2.4m2.
your dog in reply to Leon CloseApr 18, 2010. 8:23 PM
 could u use paracord?
Leon Close (author) in reply to your dogApr 19, 2010. 3:42 AM
Not sure, I've never used paracord. If it's polyester braid then possibly, but the strength of it is probably overkill for kites like this. That makes it heavy and draggy, which means the kite won't fly well. Most people prefer the lightweight and low-strech fibres like spectra and dyneema.
AlexTheGreat says: Dec 21, 2006. 8:02 PM
you should make a kite propelled air cushion vehicle.
ak49er in reply to AlexTheGreatMay 15, 2008. 7:42 PM
It would only go down wind. It needs wheels to move cross wind.
BorisTheSpider in reply to ak49erJul 23, 2008. 6:46 PM
Wonder if you could use a single (or a row, like from in-line skates) wheel on a caster in the middle of the underside. It wouldn't technically be riding solely on the air cushion, but it would allow better steering (including cutting cross-wind) and I assume only the purists would take offense.
maxpower49 says: Jun 22, 2008. 2:43 PM
how big of a kite do u use
The BeastSpawn says: Feb 10, 2007. 5:08 PM
OMG i would LOVE to make one, maybe I will. I wud make mine of alluminium I have everywhere, then I would do jumpys. I dont have a kite tho... That wud be so kwl. Im gonna start designin right away.
Leon Close (author) in reply to The BeastSpawnFeb 11, 2007. 3:55 AM
Definately do it, you'll be glad you did. But have a go at making a kite, it's not that hard. Try a nasawing for your first kite, probably about 3 square metres.
BobertXXL says: Dec 28, 2006. 11:25 PM
how fast does it go
Tool Using Animal says: Dec 22, 2006. 5:15 AM
I'd love to see an NPW construction tutorial.
Leon Close (author) in reply to Tool Using AnimalDec 25, 2006. 1:41 AM
Good idea, though that's pretty well covered elsewhere. Search for "nasawing" and "npwbill" for some good info.
Tool Using Animal in reply to Leon CloseDec 25, 2006. 10:30 AM
Actually, in the last three days, I've read myself to death on the subject, and downloaded all the programs. when I've finished my wifes bookcases, a smallish npw9 is my next "big" project. Def. "big" have to buy something. "small" all the parts are in my junk box.
Leon Close (author) in reply to Tool Using AnimalDec 26, 2006. 3:47 AM
Sounds good. I have a 4.3 metre NPW9 on the go at the moment. All my others have been npw5 so it should be interesting to see the difference.
wombat7 says: Dec 21, 2006. 8:55 PM
cool
theRIAA says: Dec 21, 2006. 1:33 PM
whats you longest/fastest run?
Leon Close (author) in reply to theRIAADec 21, 2006. 3:23 PM
Dunno exactly, no speedo on this thing yet. I'd guess I didn't get much past about 25km/h but I had a clear reach for over 800 metres which was nice.
Wade Tarzia says: Dec 21, 2006. 12:51 PM
Definitely neat. I was once published a science story whose end featured land proas (though I didn't know they were proas way back then), and I've been fascinated with land proas ever since. So wheels that size will go through hard sand, OK, good, but do they dig in and capsize you in the soft sand, should you be blown onto soft sand unavoidably, or should you need to veer away from romantic walking couples?
Leon Close (author) in reply to Wade TarziaDec 21, 2006. 3:05 PM
The wheels are pretty marginal really. They're fine on hard, wet sand but bog down quickly if I leave the narrow strip near the water. It's just going to stop in really soft sand rather than capsize. Bigger wheels would help but I wonder how far this can go? A more efficient kite would be useful to provide a bit more vertical lift to get past soft spots. As far as romantic walking couples go, the best plan would be to see them coming a long way off and land or park the kite. Kite lines are by far the most dangerous part of this setup to bystanders.
PetervG says: Dec 21, 2006. 12:32 PM
Neat
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
